Yeah man, same here, fully and the latest Fire HD8 with Fully Browser. So annoying, just got it all set up only to find out I canât use it with my tablet thatâs mounted.
Yeah, I am using an older version of this card, before lit-html was used. So it is working on my FireHD tablets, just not with the latest and greatest features. But I can live with that for the time being.
@kalkih hey mate, any chance of a modification to the background images so that they donât overlay the card? Iâm trying to use card-modder to add some rounded corners to my card, but the background images are on top of the border and the rounded corners are not visible.
@skynet01@philhawthorne, Yes this is unfortunate.
However I now compile the source through babel, so you could give it a shot again with the latest bundle version.
You would need to change type: module to type: js in your resource reference, since I believe es modules isnât supported in the WebView version running on the fire tablets.
Oooh yeah⊠that issue was actually introduced with the fix for the paper slider pin included in the last update. For the pin to not be cut off, overflow has to be set to visible, which is what causes the background to overflow the border radius you set to ha-card.
Currently, overflow is only allowed when either hide_controls and/or hide_volume is set to true, so you should technically be able to have rounded corners if you skip those options, I believe.
Iâm not sure what to do to fix this, since this is a custom modification your issue is related to, I think I would have to prioritize the paper slider pin over this. But Iâm open for suggestions.
Iâve not looked into card modder, does it only allow styling of the ha-card element?
I know some people had this error after an update before, clearing cache/restarting browser solved it I believe.
If that doesnât help, you could try downloading the js file again, if you use custom_updater double check the file so nothing wonky happened while updating.
Otherwise try restarting HA.
Depends on what media player you are using and what media you want to play.
If itâs spotify, like in my example you can get the playlist or song url by right clicking the playlist/song -> Share -> Copy playlist URI. In the Spotify desktop client.
If itâs a song you specify type as music, if itâs a playlist, you specify type as playlist.
Ok thatâs clear, but what to put after the url: option? Just the URI ?
If i right click over a playlist i get only three options: Start Radio, Save and Copy Playlist link, no Share option.
Maybe i need a Premium account?
But yes.
A track would look like this: spotify:track:285pBltuF7vW8TeWk8hdRR
A playlist would look like this: spotify:user:kalkih:playlist:3aCOlJJ3OrOrM5FzdAt1eZ
Check your card configuration, looks like you have type: media_player_thumbnail?
Should be type: custom:mini-media-player
