Yes, you would simply put the media_content_id
as the url.
So like this:
media_buttons:
- name: Whatever name you want
type: playlist
url: 2
as the url.
So like this:
media_buttons:
type: playlist
url: 2
Is your card usable with css styles, colors and so on? I mean is the card moddable just like the custom modder-card does?
Iâm not really sure what you mean. CSS is used to style the card and yes, you can use card-modder to add your own CSS declarations
As for colors, most elements of the card change color based on the color variables set in your theme.
So adding a theme to the view, the cards of mini-media-player will change accordingly?
@kalkih It will be great if you can submit this to the official repo. This has been adequately tested and seems to be a popular card.
Two questions:
Yes, if I got some time over during the holiday Iâll try to get it done.
Or if anyone else wanna take a stab at it, they are very welcome to do so.
I donât know, youâll have to try, If itâs possible to achieve through the media_player.play_media
service on the platform you use, it will work through the card.
Sure, why not?
Already tried, not working⊠actually it works only for playlists and tracks⊠no artists and no albums⊠Itâs a pityâŠ
I just tried and it actually does work for both albums and artists.
media_buttons:
- name: Album
type: playlist
url: spotify:album:1qsQOC4Jn0fnaUZLAbs4dz
- name: Artist
type: playlist
url: spotify:artist:15UsOTVnJzReFVN1VCnxy4
Ah, yes, i was wrong putting âmusicâ as type⊠GREAT!!!
I tried also to set more than one card and it was working⊠only little problem is the same full-cover showing to both the cards. How to avoid this, but always have the full-cover option set to both the cards?
Not possible, if you set full-cover it will render the artwork in full-cover
if artwork exists, as it should?
Yes it is how itâs working now⊠maybe i was not clear⊠here it is an actual screenshot of my spotify media player:
As you see both cards show the same cover also if i choose a playlist from only one cardâŠ
What iâd like to see is the full cover only in the card i am actually usingâŠ
As I said, Itâs not possible, both cards are the same media player, they contain and will display the same information.
I think you would be better off by using one mini-media-player and an arrangement of Entity button cards to call the media_player.play_media
service.
Hmmm⊠sorry donât understand what you mean⊠i donât want to not use your mini media playerâŠ
How to use entity button to call a playlist into spotify?
Yes and no. While card-modder
does work, it only attempts to style the very base element that creates the card ha-card
. As there are more and more elements with the media player, so things may not work as intended when trying to style. I found this out earlier on. See here.
You will just have to experiement and see what works and what doesnât.
Hey, trying to get the buttons to work, but nothing happens and it throws:
Error on play_media with UPnP Error 714 received: Illegal MIME-Type from 192.168.x.x
Any ideas on why this happens? Play and pause in the controller works like a charm, just not the button
Code is:
- type: 'custom:mini-media-player'
entity: media_player.sonos_kontor
artwork: cover
show_source: full
media_buttons:
- name: Test
type: playlist
url: 'spotify:user:username:playlist:36nJCbrozVo9J3ulxsInE2'
Looks like you are trying this on a Sonos?
The URI is component dependant and a Spotify URI will only work through the Spotify component.
Hey @kalkih one question. Your Github repo says that whenever you reuse things like media_list, media_buttons or sonos_grouping you can put them in an external .yaml-file. Since HASS 0.84 Iâve switched to the new storage-mode to manage lovelace-ui but for this reason I think I can no longer import external yaml-filesâŠ
This media_playerâŠ
- icon: 'mdi:speaker-wireless'
toggle_power: false
artwork: full-cover-fit
show_shuffle: false
media_buttons: !include bosepresets.yaml
show_source: true
hide_volume: false
entity: media_player.soundtouch_room2
group: true
power_color: true
⊠Iâve tried to include the following bosepresets.yaml
- type: playlist
url: 1
- type: playlist
url: 2
- type: playlist
url: 3
- type: playlist
url: 4
- type: playlist
name: Mix der Woche
url: 5
- type: playlist
name: Autobahn bei Nacht
url: 6
But it does not work. Am I missing something?
That seems to be the thing Iâve read since posting this as well⊠But I can run it as a Spotify component and use Sonos as the location?
