Thank you for the kind words Stew, really appreciated!
Thank you. Your radio chanel is also working for me. But it seems that only chanels with .mp3
at the end of the url will work.
For example I try : http://www.rockantenne.de/webradio/channels/alternative.m3u but then I get the error:
ERROR (SyncWorker_1) [homeassistant.components.media_player.sonos] Error on play_media with UPnP Error 800 received: from 192.168.178.5
I tested various chanels but only urls with .mp3 at the end will work.
One question: using the group option, the artwork is disable by default?
Using group i cannot set the artwork to any option.
More: I have two Sonos One set as stereo group, but i cannot disable one of them to see only the group name. How to disable one of the two to have only the group name?
No, the group option does not affect any artwork behaviour.
# Example ui-lovelace.yaml config
- type: entities
entities:
- entity: media_player.spotify
type: custom:mini-media-player
group: true
group: true
artwork: cover
I donât understand the question, please elaborate.
Hi, great component! Works on almost al my devices, except on my windows (10) phone⊠I know it is ancient, but everything else works. I get:
Any clue?
Hey, thank you.
This worked for Fire tablet users, please give it a shot:
Let me know if that does the trick!
I guess you figured it out already, but you forgot to specify type: custom-mini-media-player
Yes, youâre rightâŠ
How you did it??? Very niceâŠ
Anyone know if its possible to put just the minimedia player inside an iframe so I could show it on a tileboard?
https://community.home-assistant.io/t/tileboard-new-dashboard-for-homeassistant/
Hi @kalkih
I somehow ended up on a non lovelace view of my UI recently and saw the old big ugly big media player boxes, it reminded me of how good your component is and how I got used to seeing it as my default one.
Do you have any plans to make this an official component?
i love the options for the media-player, nice work!
With the theme I used, the power button disappears as soon as the media player is switched on. Which parameter in the theme controls the color of the active power button?
THX
Iâve got the question before and Iâve given it some thought and I feel like it would limit me when it comes to adding features, making changes e.g. Since I wouldnât be in charge anymore.
However, if anyone wants to convert this project into typescript and contribute it to core HA I would welcome it.
Thank you!
By default the power button doesnât change color, but if youâve set power_color
to true
in the cards config and the device is on it will change to the color of the accent-color
theme variable.
hey how did you solve this issue I having the same error
The solution can be found one post below the post you replied to.
I followed those steps didnt work
Those steps worked for me.
