Lovelace: Mini Media Player
Thanks a lot for your quick response. Looking forward to the update.
Karl,
Thank you for your pointer re template sensors, very handy. Wrote software for 30 years in maybe 15 languages, still getting into yaml.
Been trying out the latest, it works great. Some comments:
Noted the accent color comments above, good to hear fix is coming. Nice if on/off colors could be set.
Using conditional cards is working out to be better than state-switch for my needs. See https://github.com/thomasloven/lovelace-state-switch for more details.
Conditional card problems:
  • Left and right margins change (become smaller) when your player is used in a conditional card. That is, narrower than the Lovelace defaults (not at all sure this is the player). That means, to line up elements, every player instance must be in a conditional card (with sometimes always true condition), or the margins will not line up.
  • the simple “type: section” line throws an error if used. Really need something to break up various sub-menus. How about a “draw_line” option, “none, top, button, both”.
Would be really handy to be able to hide an entire player, in addition to the shortcuts.
Would be nice if the sound modes pick list could go left of the power button
The attribute is working for source and sound_mode. Tried “channel” not supported, correct?
I have seen the control buttons become spaced out far if the info line is short.
Still working on a few things, will post a few samples in a few days,
Again, sorry for the (endless) UI tweaks suggestions, does not matter what you do or not, still more to come
, as you well know.
GREAT PLAYER !
You can set the accent color by setting the theme variable mini-media-player-accent-color in your theme. The accent color defaults to the theme variable accent-color if not set.
I don’t notice any difference in my setup, can you provide a screenshot?
Sorry, I don’t get what you mean, is this related to the mini-media-player card?
The conditional card could be used to achieve this.
As discussed before, the space is very limited in the top row, especially in busy configurations.
Noticed as well, thanks for repoting will take a look!
Thanks once again for the feedback, appreciated!
Is it possible to apply card-modder styles to the mini-media-player itself?
I have the mini-media-player inside a card-modder, which is inside a conditional card (to display if the sonos source is ‘TV’, which is inside a vertical-stack.
The border radius and shadow are appearing behind the artwork, but don’t seem to be applied to the artwork itself.
card:
  type: vertical-stack
  cards:
    - type: conditional # TV Media Player Display
      conditions:
        - entity: binary_sensor.sonos_playing_tv
          state: "on"
      card:
        type: custom:card-modder
        style:
          border-radius: 20px
          border: 2px solid rgb(55, 62, 68)
          margin-left: 8px
          margin-right: 8px
          box-shadow: 0px 4px 5px 4px rgb(66, 74, 82) #x offset, y offset, blur size, spread size, color
        card:
          type: custom:mini-media-player
          entity: media_player.living_room
          more_info: false
          icon: mdi:television
          artwork: cover
          source: full
          hide:
            power: true
            volume: true
            controls: true
55
Card modder styles only apply to the root element of the card, the mini-media-player has a few nested elements to get the artwork to display properly.
Anyway, you could utilize the border-radius theme variable ha-card-border-radius.
You could set that in your theme (apply to all cards) or in card-modder (apply to specific cards).
This should do the trick.
# card modder
style:
  --ha-card-border-radius: 20px
Although, I found an issue where the border-radius would not apply to “collapsed cards” (when controls and/or volume is hidden)
Fixed the issue and will roll out a new release tonight, and then the card-modder example above should work.
Awesome setup btw, digging it a lot!
Wow, fantastic work, thank you!
It works great on my desktop if I remove the hidden elements so I look forward to the new release!
Interestingly it doesn’t seem to render on my iPhone (Beta 2.0 app, original app or chrome app on the iphone). Don’t suppose you know why?
Desktop:
iPhone:
Yeah, seeing the same on Safari (macOS), will take another look and see if it can be fixed!
The developer of the HEOS component is working on integrating grouping into the component. What would it take to add support to Mini Media Player for grouping with HEOS?
Karl,
Here is an example of the conditional card margin issue; the top card is all conditional elements, the bottom just using plain mini-media-player:
In order to keep the margins consistent all elements are conditional in the top card.
The issue with “- type: section” is related to conditional cards only. It simple gives “Custom element doesn’t exist: hui-section-card.” when used inside a conditional card (even if that is the only item). Works fine if not using conditional card. Likely not your issue, the reason for the line suggestion inside mini-media-player, was to get the line capability back when using conditional cards. Similarly, if an entire player could be hidden, then the issues would go away as well, -along with the margin issue.
Re sound mode in top line: understand space limitations, but but but
, if not using controls or source, then really a nice spot for it
Also, is channel attribute supported when used with the attribute option?
Thank you again for your quick responses. Do you accept donations/gratitudes for your contributions?
Was apparently a known WebKit issue.
New version v1.1.1
Fixes various :bug:s and issues
Changelog
Fixed
  • Incorrect spacing between media buttons
  • Incorrect spacing between volume buttons
  • border-radius not applying when card was collapsed
  • icon colors not changing correctly with icon state
Awesome! It really depends on how it’s implemented, if it’s implemented similar to Sonos or yamaha_musiccast it would be really easy to add.
Interesting, not able to recreate that, are you sure you aren’t using the group option in the mini-media-player config (that would remove paddings), if not please pm me your whole configuration and I’ll see if I can recreate the issue & potentially fix it
I’ve actually not played around with the conditional card that much so not sure about the section issue, sorry.
Haha yes, it’s indeed the superior location, could probably add an option for it, similar to source, but leave it as false by default.
All attributes should work as long as the entity exposes the attribute, what kind of device is it?
Sure you could always PayPal me @ [email protected], but absolutely not necessary, I do this for fun :nerd_face:
Karl,
Yes, groups were on, see same card group: true/false below. Nothing else changed.
Re “channel” and attribute
The source and sound_mode is working great. When I try to use the new attribute feature (shortcuts is using "type: “channel” along with “attribute: source”), then I get the default label. The device is DirecTV (the largest satellite TV service in the US), per the entity info panel, it is called source and contains an integer. Here is the entity info:
Capture
And the lovelace:
  - card:
      cards:
        - attribute: source
          entity: media_player.erik_directv
          group: true
          hide:
            controls: false
            icon: true
            power_state: false
            progress: true
            volume: true
          info: scroll
          shortcuts:
            list:
              - id: 4
                type: channel
              - id: 5
                type: channel
              - id: 7
                type: channel
              - id: 202
                type: channel
              - id: 360
                type: channel
            columns: 3
            hide_when_off: true
            label: Favorite Channels
          type: 'custom:mini-media-player'
      type: 'custom:vertical-stack-in-card'
    conditions:
      - entity: sensor.erik_receiver_source
        state: DirecTV
    type: conditional
@kalkih Thank you, I’ve modified the theme as you suggested. BTW this workaround fixed also the color of active shortcut button
Karl,
Yes, the color of active shortcut button works, and the occasional control button spacing is now consistent.
Also, the report about channel not working is “fake news”. It does work just fine. The attribute was in the wrong place, sorry.
Now, for some configurations, I have implemented automatic power on/off based on what devices is being used, using scripts. No active button when using scripts, could the active button be highlighted using the “name” key when using scripts? I do realize this is a bit different than using an entity variable. (Edit: I can trigger automations off source changes and eliminate using scripts.)
Just like scripts above, when using a Sonos Connect to play a playlist, the name of the playlist does not show up as a Sonos entity attribute.
I can imagine other shortcut types have similar issues, the same hack suggested for scripts and Sonos could fix that. Do recognize that on startup, the state would not be obtainable from the entity, to bad.
Hi Karl,
Are you willing to add min_volume as an optional setting? I have some music players that aren’t audible until about 60% of my max_volume setting. I would really like to adjust the min_volume to use more of the slider bar.
Oh yeah, group option saves a lot of space :laughing:
Could you send me an example configuration that has the margin issue when nested/not nested inside conditional cards?
Yeah, the problem with scripts, in particular, is that they are different entities (as you said) and I really don’t want to watch for changes in other entities (other than the card entity).
I would really recommend doing something like @lukenn a few posts above for more advanced button states.
As for the playlist, yeah I’m not exactly sure how/if Sonos exposes the active playlist in its attributes, but I fear it might be similar to the Spotify component.
If I, for example, start a playlist from the Spotify component it won’t expose the playlist uri in its attributes but instead expose the current track uri, making it impossible to know if a playlist is active or not.
Edit: Wow, thank you for the donation/tip Erik, really :pray:
Great!
Yes, all accent color was essentially gone :slightly_frowning_face:
Latest release should fix this and shouldn’t require the theme variable (although, it can still be useful).
Sure, great suggestion.
Karl,
A simple layout, First is using conditional cards, 2x yaml follows:
cards:
  - card:
      cards:
        - entity: media_player.erik_receiver
          group: true
          hide:
            controls: true
            icon: true
            info: true
            power_state: false
            source: true
            volume: true
          info: short
    conditions:
      - entity: group.all_automations
        state: 'on'
    type: conditional
  - card:
      cards:
          group: true
          hide:
            controls: true
            hide_when_off: true
            icon: true
            info: true
            power: true
            source: true
            volume: true
          name: Erik Receiver Sound
          shortcuts:
            attribute: sound_mode
            columns: 2
            list:
              - id: ALL_ZONE_STEREO
                name: All Zone Stereo
                type: sound_mode
              - id: AUTO
                type: sound_mode
              - id: DOLBY_DIGITAL
                type: sound_mode
              - id: DTS_SURROUND
                type: sound_mode
              - id: GAME
                type: sound_mode
              - id: MCH_STEREO
                name: Multi Channel Stereo
                type: sound_mode
              - id: MOVIE
                type: sound_mode
              - id: MUSIC
                type: sound_mode
              - id: PURE_DIRECT
                type: sound_mode
              - id: STEREO
                type: sound_mode
              - id: VIRTUAL
                type: sound_mode
          group: true
          hide:
            controls: true
            icon: true
            info: short
            power: true
            source: true
          source: icon
          group: true
          hide:
            controls: true
            icon: true
            info: false
            power: true
            source: true
            volume: true
          info: short
          name: Erik Receiver Source
          shortcuts:
            attribute: source
            buttons:
              - id: Chromecast
                type: source
              - id: DirecTV
                type: source
              - id: FireTV
                type: source
              - id: Front
                type: source
              - id: PC 1
                type: source
              - id: PC 2
                type: source
            columns: 3
    conditions:
        state_not: 'off'
    type: conditional
  - card:
      cards:
        - entity: media_player.erik_directv
          group: true
          hide:
            controls: false
            icon: true
            power: true
            progress: true
            volume: true
          info: scroll
          shortcuts:
            attribute: source
            buttons:
              - id: 4
                type: channel
              - id: 5
                type: channel
              - id: 7
                type: channel
              - id: 202
                type: channel
              - id: 360
                type: channel
            columns: 3
            hide_when_off: false
    conditions:
        state: DirecTV
    type: conditional
No conditional cards:
entities:
    group: true
    hide:
      controls: true
      icon: true
      info: false
      power_state: false
      source: false
      volume: true
    info: short
    name: Erik Receiver Plain
    group: true
    hide:
      controls: true
      hide_when_off: true
      icon: true
      info: short
      power: true
      source: true
      volume: true
    shortcuts:
      columns: 2
      list:
        - id: script.ui_erik_sound_all_zone_stereo
          type: script
        - id: script.ui_erik_sound_auto
          type: script
        - id: script.ui_erik_sound_dolby_digital
          type: script
        - id: script.ui_erik_sound_dts_surround
          type: script
        - id: script.ui_erik_sound_game
          type: script
        - id: script.ui_erik_sound_mch_stereo
          type: script
        - id: script.ui_erik_sound_movie
          type: script
        - id: script.ui_erik_sound_music
          type: script
        - id: script.ui_erik_sound_pure_direct
          type: script
        - id: script.ui_erik_sound_stereo
          type: script
        - id: script.ui_erik_sound_virtual
          type: script
      hide_when_off: true
    group: true
    hide:
      controls: true
      icon: true
      info: short
      power: true
      source: true
    group: true
    hide:
      controls: true
      icon: true
      info: short
      power: true
      source: true
      volume: true
    info: short
    shortcuts:
      attribute: source
      buttons:
        - id: Chromecast
          type: source
        - id: DirecTV
          type: source
        - id: FireTV
          type: source
        - id: Front
          type: source
        - id: PC 1
          type: source
        - id: PC 2
          type: source
      columns: 3
      hide_when_off: true
    group: true
    hide:
      controls: false
      icon: true
      power_state: false
      progress: true
      volume: true
    shortcuts:
      attribute: source
      buttons:
        - id: 3
          type: channel
        - id: 5
          type: channel
        - id: 7
          type: channel
        - id: 202
          type: channel
        - id: 360
          type: channel
      columns: 3
      hide_when_off: true
type: entities
Okay, the first example doesn’t seem to be wrapped in an entities card while the second config is, could that be it? The entities card adds a padding of 16px (I believe?). I don’t notice anything strange otherwise, but I might be blind, so you might have to point it out for me :laughing:
That would explain it, thank you for taking a look.
