kalkih
(Karl Kihlström)
July 30, 2019, 6:29pm
1079
Did it work even on mobile after you did that or just on desktop, and which browser(s) did you see the issue in?
Here’s my thoughts on the issue.
The card uses a kinda new feature in web dev called CSS custom properties, we use these to decide & set the colors the card should use. But when we add several fallback values to these custom properties, things start to behave strange in some browsers.
tc23
July 30, 2019, 7:15pm
1080
It worked just on desktop using Chrome, it continued to disappear on mobile after I added the aforementioned to my theme. Both were using Chrome as the browser. No worries if it’s a wonky behavior, just wasn’t sure if there was something I was doing wrong.
servido
(NICOLAS ORTUZAR)
August 6, 2019, 11:01pm
1081
Same thing here, please can you post your fix to make this work? thanks
Leonka93
(Michele Bernazzani)
August 8, 2019, 3:23pm
1082
Hi everyone,
I’m a beginner with Ha,
I’m using hassio v. 96.5,
I installed ‘mini media player’ through hacs,
but I can’t get it to work.
when I enter the ‘maual card’
and insert:
- type: custom:mini-media-player
entity: media_player.primo
icon: mdi:spotify
artwork: cover
hide:
volume: true
source: true
power_state: false
I get the error:
No card type found
"type": "custom:mini-media-player",
"entity": "media_player.example",
"icon": "mdi:spotify",
"artwork": "cover",
"hide": {
"volume": true,
"source": true,
"power_state": false
I inserted in the raw text editor:
resources:
- url: /local/mini-media-player-bundle.js?v=1.2.2
type: module
title: LeonkaHome
- badges:
- binary_sensor.door_window_sensor_158d0002eb621e
- binary_sensor.motion_sensor_158d0002b60c02
- binary_sensor.cube_158d00029ba5bf
- binary_sensor.switch_158d00020dae05
- binary_sensor.remote_ui
- sensor.hacs
- sensor.humidity_158d000309b137
- sensor.temperature_158d000309b1d9
- sensor.humidity_158d0002b541f4
- sensor.illumination_158d0002b60c02
hacs has downloaded the files to me:
mini-media-player.js e mini-media-player.js.gz
in the folder: /config/www/community/mini-media-player
I don’t understand where I’m wrong, can you help me?
thank you
If you installed via HACS the resource url should be
url: /community_plugin/mini-media-player/mini-media-player.js
cjsimmons
(Chris Simmons)
August 12, 2019, 3:09am
1085
Hey all, long time user of this, but have just got myself another google home mini and now looking to group them together, though I can’t work it out. I see in example media_player.multiroom_player
, is this something people have setup or an actual device?
Can anyone help me out? Thanks.
kalkih
(Karl Kihlström)
August 12, 2019, 11:42am
1086
The media_player.multiroom_player
in the example is actually a forked-daapd instance.
What you can do if you have multiple Google homes / cast devices is to create a speaker group though the google home app, this group should then automatically get picked up by the cast component and will show up as a media_player in HA.
cjsimmons
(Chris Simmons)
August 12, 2019, 11:45am
1087
Thanks @kalkih . That should do the trick. Didn’t think to look there, I just figured I was missing something with this card.
Hi guys I just installed this awesome card and looking to configure it a bit more
This is what I have now and I would like to keep it as that but also display the volume slider on it’s own row so it is wider than in the pic above, the thing is once I add the buttons below it goes at the top and smaller.
Any idea?
nickrout
(Nick Rout)
August 14, 2019, 11:48pm
1089
Dansker
August 15, 2019, 1:12am
1090
Like this?
Use multiple instances of the mini-media-player (in the same card).
> cards:
> - card:
> cards:
> - attribute: sound_mode
> entity: media_player.erik_receiver
> group: true
> hide:
> controls: true
> icon: true
> info: true
> power_state: false
> sound_mode: false
> source: true
> volume: true
> info: short
> label: Sound Mode
> shortcuts:
> label: Sound Modes
> sound_mode: full
> type: 'custom:mini-media-player'
> type: 'custom:vertical-stack-in-card'
> conditions:
> - entity: group.all_automations
> state: 'on'
> type: conditional
> - card:
> cards:
> - entity: media_player.erik_receiver
> group: true
> hide:
> controls: true
> icon: true
> info: short
> power: true
> source: true
> max_volume: 70
> min_volume: 25
> source: icon
> group: true
> hide:
> controls: true
> icon: true
> info: true
> power: true
> source: true
> volume: true
> info: short
> name: Erik Receiver Source
> shortcuts:
> attribute: source
> buttons:
> - id: Chromecast
> type: source
> - id: DirecTV
> type: source
> - id: FireTV
> type: source
> - id: Front
> type: source
> - id: PC 1
> type: source
> - id: PC 2
> type: source
> columns: 3
> conditions:
> state_not: 'off'
> type: conditional
> - card:
> cards:
> - entity: media_player.erik_directv
> group: true
> hide:
> controls: false
> icon: true
> power: true
> progress: true
> volume: true
> info: scroll
> shortcuts:
> attribute: source
> buttons:
> - id: 4
> type: channel
> - id: 5
> type: channel
> - id: 7
> type: channel
> - id: 202
> type: channel
> - id: 360
> type: channel
> columns: 3
> hide_when_off: false
> label: Favorite Channels
> conditions:
> - entity: sensor.erik_receiver_source
> state: DirecTV
> type: conditional
Works great! Thank you again Karl!
I almost have it like I wanted (thanks to the code above)
The only thing is that the whole card disappears when the AVR is off which I am guessing is due to this:
How to fix that so that I get something like this when off?
kalkih
(Karl Kihlström)
August 15, 2019, 8:09pm
1093
Remove the conditional cards completely, alternatively wrap the volume slider part inside a conditional card and remove rest of the conditional cards.
maxweb80
(massimilian0)
August 27, 2019, 7:12pm
1094
Hi to all!
I’m using hassio and I’m a beginner!
I installed ‘mini media player’ with hacs, but it not works!
when I made the manual card like
this:
entity: media_player.player1
icon: mdi:spotify
artwork: cover
hide:
volume: true
source: true
power_state: false
the error is:
No card type found
“type”: “custom:mini-media-player”,
“entity”: “media_player.player1”,
“icon”: “mdi:spotify”,
“artwork”: “cover”,
“hide”: {
“volume”: true,
in raw text editor lovelace:
resources:
- type: module
url: /community_plugin/mini-media-player/mini-media-player-bundle.js
hacs dowload in www
mini-media-player-bundle.js e mini-media-player-bundle.js.gz
WHAT I'.M WRONG?? :frowning:
maxweb80
(massimilian0)
August 27, 2019, 7:35pm
1095
Ciao Exus! me la passi questa card/panel?
Kemicalg
(Gabe)
August 29, 2019, 8:12pm
1096
Hello all
I am a newbie
Im having the darndest time with adding or seeing this mini player
Im just trying to do the basics with it
Here is my lovelace yaml
title: Martin Home
badges:
sun.sun
sensor.moon
device_tracker.huawei_mate_10_pro_e93543_lan
device_tracker.melissa_s10_lan
device_tracker.ipad_2_lan
device_tracker.galaxy_tab_a_lan
device_tracker.android_734e7dcc8d6562cf_lan_2
device_tracker.galaxy_note9_lan
device_tracker.huawei_mate_se_15c16f7c60_lan
cards:
entities:
entity: light.basement
entity: light.front_bedroom
entity: light.brandon
entity: light.girls_room_2
entity: light.living_room_2
entity: light.fish_tank
entity: light.frontbed_room
entity: light.fishtank_ls
entity: light.basement_2
entity: light.basement_1
title: Light
type: entities
entities:
entity: camera.kids_room
entity: camera.living_room
entity: camera.extra_cam
show_header_toggle: false
theme: Backend-selected
title: CAMs
type: entities
entities:
entity: media_player.master_bedroom_tv
entity: media_player.living_room_tv
title: CHROMECAST TV
type: entities
entities:
entity: media_player.basement_home
entity: media_player.master_bedroom_speaker
entity: media_player.basement_audio
entity: media_player.kitchen
entity: media_player.basement_audio_group
entity: media_player.total_home_audio
entity: media_player.upstairs_audio_group
entity: media_player.upstairs_kitchen_speaker
entity: media_player.girls_room_speaker
entity: media_player.living_room_home
entity: media_player.basement_bathroom
title: CHROMECAST AUDIO
type: entities
entity: weather.home
type: weather-forecast
entities:
switch.fish_tank_light
title: Switch
type: entities
panel: false
path: default_view
resources:
type: module
here is my WWW
Im using hassio --0.98.0
What am i missing or not doing correctly
been racking my brains for a week already
kalkih
(Karl Kihlström)
August 29, 2019, 8:56pm
1097
Try removing the dash (-) before “type: custom:mini-media-player”
Hello and welcome!
Sorry I don’t understand your lovelace config, please post it inside a code block.
Your resource reference doesn’t seem to match with the files in your www folder.
Should probably be:
- type: module
I also don’t see anywhere in your config where you actually use the mini-media-player card.
abhilabhila
(Abhilash Mohan)
September 3, 2019, 11:39am
1098
Is it possible to group LMS media players with this?
kalkih
(Karl Kihlström)
September 3, 2019, 12:01pm
1099
Not at this time, if support is added in the backend (HA component) we could support it.
