Playing with time was fun.
This is what I got for maths:
seek_position: " {{ ( as_timestamp(now()) - as_timestamp(state_attr(entity, 'media_position_updated_at')) + state_attr(entity, 'media_position') ) | float + interval }} "
Haha, thatâs a long line
Ok, I need some help. I have really tried to get rounded corners on my artwork in mini media player. But I cant!
Here is the code:
- card:
artwork: full-cover
entity: media_player.spotify
hide:
controls: false
icon: true
info: false
mute: true
power: true
power_state: true
shuffle: false
source: true
volume: true
info: scroll
style: |
ha-card {
background: none;
box-shadow: none;
border-radius: 20px;
overflow: hidden;
width: 60%;
margin: 0%;
padding-top: 0px;
left: 8%;
top: 30px;
type: 'custom:mini-media-player'
And this is what I get:
It seems like none of background, box-shadow, border-radius, overflow is affected when changed. Only width, left etc makes a difference.
As you can see my artwork dont have border radius 20px, its only 10px as set in my theme!
Any help is appreciated!!
Latest version of mini media player.
- resources: null
- type: module
url: /local/mini-media-player-bundle.js?v=1.4.1
Seems like a bug, when the card is in collapsed config (e.g. volume and/or controls are hidden).
The only thing you should need to set is ha-card-border-radius
in your theme.
Iâll fix it tomorrow.
Should now be fixed in the latest release.
I have a very simple configuration that adds a button to play a local radio station that uses m3u8:
- type: custom:mini-media-player
entity: media_player.suite_speaker
artwork: cover
info: short
shortcuts:
buttons:
- name: Eldorado
icon: mdi:radio
type: music
How can I add a second button with a TuneIn radio station ?
Still same issueâŠ
Actually it seems to be a google chrome problem. It works on my ipad with safari, and on my android with edge and firefox but NOT on my computer or android tablet running google chrome? :o
Just installed the latest release and added the play_stop option, but when running the card and pressing the stop button i get the following:
Fallita chiamata a servizio media_player/media_stop
Is it my fault in something or what?
Iâm not sure about tuneIn, but to add another button, just do like this.
Media content is platform dependant so the id, type and even supported sources may vary between components.
artwork: cover
info: short
shortcuts:
buttons:
- name: Eldorado
icon: mdi:radio
type: music
- name: Second station
icon: mdi:radio
type: music
Clear cache maybe? Works as expected for me on Chrome after the latest update (which had the same issue as you had before).
Is it possible that your media player doesnât support the stop service, what component is it?
Yes, I can add more buttons but can`t get them to play from TUNEIN.
Does anybody have a sample config of Mini Media Player playing from TUNEIN to a Google Home?
Check this, itâs from 2017 but might still be relevant:
media_content_id
would be the id
and media_content_type
would be the type
in the shortcut.
Found the issue, I tried update using the HACS. But apparently that did not work.
So i did a manual update instead using the latest mini-media-player-bundle.js.
And now it works!! Perfect⊠Thank you Very much for your help!
Great!
The resource reference for the card changed in HACS a few months back so if that was the problem you might have to update it (if you want to use the card with HACS in the future).
Yes, youâre right, it seems this option doesnât work on amazon echo show⊠tried another media player and this works!
Can someone help me get the grouped cards working? Im trying to follow the example in the docs (see below) but Im a bit confused. The initial multi-room playerâŠhow do I create that? Right now, I have 3 seperate sonos speakers in different rooms that I would like to group together.
- type: entities
entities:
entity: media_player.multiroom_player
group: true
source: icon
info: short
hide:
volume: true
power: true
entity: media_player.kitchen_speakers
group: true
hide:
controls: true
entity: media_player.bathroom_speakers
group: true
hide:
controls: true
entity: media_player.bedroom_speakers
group: true
hide:
controls: true
entity: media_player.patio_speakers
group: true
hide:
controls: true
It is pretty obvious in the ha source what services the player supports.
The example youâre looking at is simply displaying how you can group several mini media player cards into âone cardâ, itâs just a layout example and wonât provide any extra features or functionality.
See the Speaker group management example instead, I think thatâs what youâre looking for.
Can anyone help with the shortcut buttons on this card:
I was hoping to add buttons to select âsourcesâ that I have set up in my SkyQ component.
I have buttons that work with this code, where switch.skyq_bbconelounge will make bbc one play on sky
- type: custom:button-card
entity: switch.skyq_bbconelounge
show_entity_picture: true
show_name: false
show_icon: false
show_label: false
show_state: false
styles:
card:
- padding: 0px
img_cell:
- justify-content: start
entity_picture: "/local/images/remote/bbconefaded2.png"
And the config for the sources is this:
skyq_bbconelounge:
value_template: '{{"off"}}'
friendly_name: 'BBCOne in the Lounge'
turn_on:
service: media_player.select_source
entity_id: media_player.skyq
source: 'BBCOne'
But no idea what option I need in the media card for âtypeâ and for âidâ
This shortcut would do the same thing as your button, but I donât really see the need for the switch, as you could just call media_player.select_source
directly.
- name: example name
type: service
id: switch.toggle # or turn_on, not sure which one you want.
entity_id: switch.skyq_bbconelounge
And if the media player entity of which source you want to change is the same as the card entity, you could just do:
type: source
Thanks. I am happy to not use the button, I just could not get the source to work. Will give that a try when I get home.
