Hi there, how did you get the larger artwork cover?
You could utilize conditional cards to decide what cards to render depending on different states.
E.g. if the speaker group is playing you could use conditional cards to hide the individual speaker cards and vice versa.
You could also try creating a universal media player of the three entities, start with the speaker group as the first child followed by the two individual google speakers.
Then use the universal media player entity in the mini media player card.
artwork: full-cover
or artwork: full-cover-fit
Is it possible to use something like this?
icon: â{% if source(âNetflixâ) %}mdi:netflix{% else %}mdi:pc{% endif %}â
I have a chrome cast where multiple content is played (youtube / netflix / spotify / etc)
Can the card detect the source and adjust the icon - or can we implement something like above?
(Iâve tried
source: icon
but it does not work on netflix )
Hi @kalkih
Thanks for the update! As far is i can see I should be able to theme the buttons now.
I have tried to put the following line to my theme.yaml file. (Addition to the theme I am using) and it seems it does not theme the buttons.
I use:
paper-card-background-color: 'rgba(46, 46, 46, 0.5)'
mini-media-player-button-color: 'var(--paper-card-background-color)'
Can you point me in the right direction?
Tried to refresh the theme, rebooted Home Assistant, cleared cache, etc.
Thanks a bunch!
Rutger
Seconding heartkingz request for button theming. Similarly added the line to the theme.yaml, reloaded HA and cleared cache but to no avail so far.
Sadly, this makes the picons unreadable on a light theme. Other than that a great card and pretty easy to customize even for somebody with little coding experience.
Is there a way to keep it âalways onâ?
I have a LG TV without a way to know if itâs on or off, and i have the TV and the MMP in the opposite state (one off and one on). I prefer to have MMP always on, showing the commands.
What state is your TV reporting?
Try creating a universal media player and map the on state attribute to be always on.
I double checked and theming of the button works fine for me through the new theme variable.
Did you perhaps install the card through HACS? HACS is having serious issues with updating cards, it will display the updated version but in reality the file on disk isnât updated.
Try reinstalling the card through HACS or try to install it manually.
Hey,
Have any one else experienced when casting your Spotify Content to a Chromecast and wants to use the âButtonsâ, to start a Playlist, then nothing happens. But, this is only the case when casting. If I listen to music on my phone and then presses the button, then it changes just fine.
I know for sure that it has worked before, but Iâm not sure when exactly this stopped working
Did installed it via HACS. Reinstalled the media player and it starts working. Stupid I havenât tried that ;D
While this works, lower buttons does not theme the same way. Do I need to use another variable to theme these?
Thanks!
How did you make the round corners on the buttons?
Thank you.
Ok, will look into it.
Edit: found the issue, fix in next release.
They should be rounded by default: border-radius: 4px
Thanks again! @Kabala, indeed, didnât change a thing Maybe the variable âha-card-border-radius is overwritten by another value in your theme? Must say that i donât know for sure if this value also affects the rounded corners for these buttons.
Hi
I use 4 buttons to play preset internet radio stations on my Linkplay ceiling speakers. Problem is that no cover art/logo or media info is displayed and i have no idea what station iâm listening to.
If I play spotify or use my phone app to play the same stations from Tunein then the artwork and info is displayed correctly.
Is there any way to show the station logo from the internet stream like the way Tunein shows?
Or is there even a way to manually specify stations logos for the 4 buttons so when a particular stream is playing a specified logo is shown instead of the cast icon in the player?
I am currently using Google Dark Theme and border-radius: 15px is the default. But apparently not for the buttons
What could be the reason?
Thank you
Media metadata such as artwork and track/station/artist is handled in the component. What component are you using? The card is simply exposing the attributes coming from the component.
Not really, you could try to achieve it with config-template-card by dynamically changing the cardâs background option, but if the component doesnât expose whatâs playing I donât know how you could know whatâs playing.
has nothing to do with the buttons, itâs the border radius of the card itself.
But your buttons doesnât look like they have a border radius at all, should be 4px in later version of this card.
Try updating/reinstalling the card maybe?
that was itâŠ
Thank you.
On HA 0.105 with the new Spotify integration, Iâm having a problem with the progress bar.
The duration of the media is the right one but I have a factor of approx. 2 between the real position of the media and the one indicated by the card.
(The âmedia_positionâ shown by the media_player entity is the correct one)
