Lovelace Restriction Card - Client-side Security
That tells me that you are 100% using an older version then as that was changed in release 1.0.8. Try opening with a different browser or private session to confirm.
Edit: I just put out version 1.1.1 that will print out to the browser console which version is running
interesting.
I had checked the version installed via HACS, and it was showing 1.1.10, then I did cmd+shift+f5 to reload, which I supposed was going to ignore the cache, but the lock/card wasnt ok, but reading your last comment I did what you suggested, I opened in a private session and it shows correctly.
so, to understand why cmd+shift+f5 didnā€™t work, I learned something new:
Hard reload is not exposed directly in the UI of the browser. You activate the function with the keyboard shortcut Ctrl-Shift-R, Shift-F5, or by holding down Shift before you activate the reload button.
Chrome ignores the cache and will load all resources from the web page again.
Google Chrome supports a third reload option and a somewhat hidden reload menu as well. You need to open the browserā€™s Developer Tools with the keyboard shortcut F12 first as it is a prerequisite for it.
Right-click on the reload button afterward to display the reload menu. It includes the empty cache and hard reload option that you may use. What it does, is clear the browser cache before the hard reload is activated.
Google Chrome: hard reload vs. normal reload - gHacks Tech News
so, it might help other people reading the forum.
Thanks again!!!
Anyone else getting console errors after updating to 1.1.1?
I am having trouble applying styles to this card. I am using a custom:button-card which is embedded in the restriction-card via an !include using lovelace-mod.
This is my not working config:
              - type: custom:restriction-card
                row: true
                card:
                  !include
                  - includes/button_boolean_check_box_with_entity_icon.yaml
                  - entity: input_boolean.announcement_in_progress
                    card_font_size: 14px
                style: |
                  :host {
                    --restriction-regular-lock-color: red;
Which results in this:
The style works with a simple entity:
This is the included button ā€˜templateā€™;
type: custom:button-card
entity: {{ entity }}
icon: {{ icon | default('') }}
name: {{ name | default('') }}
size: {{ size | default('40%') }}
lock:
  enabled: {{ lock_enabled | default('false') }}
styles:
  lock:
    - color: {{ lock_color | default('red') }}
  grid:
    - grid-template-areas: '"i n" "l l"'
    - grid-template-columns: 25% min-content
  card:
    - height: {{ card_height | default('') }}
    - font-size: {{ card_font_size | default('12px') }}
    - border-radius: {{ card_border_radius | default('10px') }}
state:
  - value: 'on'
    styles:
      card:
        - background-color: {{ card_background_on_color | default('var(--primary-background-color)') }}
  - value: 'off'
    styles:
      card:
        - color: {{ card_off_color | default('var(--secondary-text-color)') }}
        - box-shadow: 0px 0px 1px 2px {{ box_shadow_off_color | default('var(--primary-background-color)') }}
      icon:
        - color: {{ icon_off_color | default('var(--secondary-text-color)') }}
0.106 Support
Is the background color of the dialogue box that asks for the pin set by the card or by the theme of HA? No matter which dark theme I choose I still get a prompt with a white background. Is there a way to fix that and have the background dark and the text light for the dialogue box?
Hello.
I installed this card as replacement of toggle-lock-entity-row extension which stopped working recently.
And the newone seemed to work well at the first glance. But I cannot unprotect the switch. When I click (or double click depending on action settings) the lock icon is pulsing a few times, but thatā€™s all. The switch remains locked.
Can I lock/unlock it on demand? I donā€™t need to use PINs or so.
Here is how Iā€™m using it:
type: 'custom:hui-entities-card'
show_header_toggle: false
state_color: true
title: test
entities:
  - card:
      entity: input_boolean.home_occupied
    restrictions:
      block: true
    type: 'custom:restriction-card'
    row: true
    action: double_tap
block:true literally blocks it. Remove the restrictions section
Yep, now it works. Thank you.
Iā€™m thinking about changing appearance of locked switch. Is it possible to replace icon of a switch by lock icon? So switch appears only when is really unlocked. Otherwise locked is shown.
The restriction is just an overlay, it doesnā€™t modify the card below in anyway; so no, you canā€™t update the icon of the switch using this
Can I change overlay image to cover the switch then?
Yes, take a look at the theme variables: https://github.com/iantrich/restriction-card#theme-variables
I meant to make the switch invisible by covering it by non-transparent object. It might be lock icon but it has transparent background so itā€™s not what Iā€™m looking for.
thanks for your help.
Where would I put that bit of code to add it to the default theme?
I use yaml mode. I tried to put it in right before views but it doesnā€™t seem to take.
title: Home Assistant
restriction-lock-row-margin-left: 95%
  - !include '/config/lovelace_views/lovelace_main_view.yaml'
If I put it into a separate theme file it works fine. I just donā€™t know how to modify the default theme with one change.
no, that is not an option
You should be able to put it in a css file and include it in resources I thinkā€¦I think I tried that once before but am on mobile right now and unable to test.
Do you know of any documentation on that anywhere? I looked around in the docs (nothing at all) and on the forums (nothing definitive) but I havenā€™t found a god explanation on how that is done in HA.
You could try using https://github.com/thomasloven/lovelace-card-mod
Havenā€™t tested that
It doesnā€™t seem to work on the card or entity level.
Iā€™ve tried it a couple of ways:
  - type: entities
    title: Urgent Announcements
    style: |
      ha-card {
        restriction-lock-row-margin-left: 95%;
    entities:
      - type: 'custom:restriction-card'
        card:
          entity: input_boolean.tts_announce_1
        row: true
        card:
          entity: input_boolean.tts_announce_2
        row: true
and:
- type: entities
    entities:
        card:
          style: |
            :host {
        row: true
        card:
        row: true
the lock icon always stays on the left.
should be
--restriction-lock-row-margin-left: 95%;
