I donāt see a āsummaryā field in your feed, I see a thumb in ācontent:encodedā instead. Did you try that instead of summary?
Youāll have to manually add it. The card really needs a refresh and my plan was to add it once that was done; life has gotten in the way on that rewrite, however.
Well obviously Iām doing something wrong here LOL Being still new to HA Iām having a bit of trouble figuring it out hereā¦ any help would be much appreciated!
This is my ui-lovelace entry:
- type: custom:list-card
entity: sensor.nfl_feed
title: NFL Feed
feed_attribute: entries
columns:
- title: ''
type: image
add_link: link
field: image
- title: Title
field: title
style:
- white-space: nowrap
- title: Description
field: description
This is what I see from the sensor:
this is what my page looks like:
So what am I doing wrong? I have restarted this thing so many times and still nothing is showing.
Thank you for a great News reader
Not sure if it will absolutely correct it, but the field in image is not Ā“imageā but rather Ā« link Ā»
an item had to be between < and > to be considered an item. In your case, the image is just an attribute to the link.
edit: wait, maybe i am wrong. did not look correctly at your picture at first
I found this error and not sure how to fix thatā¦
Setup failed for feedparser: No setup function defined.
I canāt find list-card in HACS
Other custom components from @iantrich are visible for me in HACS. I am not looking at the right spot (searched for ālist cardā and Ianās name, but no luck)?
Just tried it. no such luck. Any other ideas?
if 'image' in self._inclusions and 'image' not in entryValue.keys():
images = []
if 'content:encoded' in entry.keys():
images = re.findall(r"http(.+?)\.thumb", entry['content:encoded'])
if images:
entryValue['image'] = images[0]
else:
entryValue['image'] = "https://www.home-assistant.io/images/favicon-192x192-full.png"
Thereās apparently a lot of issues with thisā¦ with no help in sight.
Anyone? I have read and re-read and went to githubā¦ someone has to know how to fix this.
Have you tried removing the Ā« style: Ā» and the Ā« whitespace Ā» lines altogether? i donāt remember seeing them before for this cardā¦
You have description
listed in the card but I see no such field in your sensor. Also the style
is not properly formatted. Look at the example again
Hi I have a direct installation of home assistant on a RPI +3B. I am currently running 0.115.0 - it works very well. I have been looking at this thread as I wanted to add a RSS feed - http://feeds.bbci.co.uk/news/world/rss.xml.
I have added HACS to my installation but have stalled at trying to add feedparser or list card. Is there a description of the steps needed to add this feed to my Lovelace UI? I am still learning about HA so I need instructions that assume I am a novice at this! Any help much appreciated. Thanks.
Iāve been using the feedparser for a while now to process a number of RSS feeds. Iāve had some issues with extracting the data, but I had it basically working which was good enough for the time being. Iād like to go back and workout some of those issues, but recently Iāve started having issues with my Craigslist feeds no longer working even though I havenāt changed anything. Thus it led me to believe that perhaps they have changed something in their feed which is causing the issue. My sensor looks like:
- platform: feedparser
name: CL Buffalo Bicycles
feed_url: 'https://buffalo.craigslist.org/search/bia?format=rss'
date_format: '%a, %b %d %I:%M %p'
inclusions:
- title
- link
And an item snippet from the feed looks like:
<item rdf:about="https://buffalo.craigslist.org/bik/d/tonawanda-chrome-spaceliner-26tires-1/7206223241.html">
<title>
Chrome Spaceliner 26"tires 1 spd w/Coaster Brake $600
</title>
<link>
</link>
<description>
like new Original vintage/classic/antique 1964 Sears JC Higgins Ladies' Spaceliner road/cruiser bicycle.. ..chrome frame, fenders, forks, chainguard, handlebars, spokes, rims, fender struts, front truss bars and crank assembly..99.99% straight..100% ...
</description>
<dc:date>2020-10-01T10:57:47-04:00</dc:date>
<dc:language>en-us</dc:language>
<dc:rights>copyright 2020 craigslist</dc:rights>
<dc:source>
</dc:source>
<dc:title>
</dc:title>
<dc:type>text</dc:type>
<enc:enclosure resource="https://images.craigslist.org/00000_dYkLmTGWPAG_0x20oM_300x300.jpg" type="image/jpeg"/>
<dcterms:issued>2020-10-01T10:57:47-04:00</dcterms:issued>
</item>
The only difference between this feed and others that are working appears to be the item tag has that ārdf:about=ā information. I donāt know if that was there previously or not so perhaps thatās the issue. The sensor for that feedās state attributes shows no items:
entries: []
friendly_name: CL Buffalo Bicycles
icon: 'mdi:rss'
Anyone have any ideas of what Iām doing wrong here?
I was able to add it manually to my HA setup and it is working fine for me.
oh wow, my reddit post made it to here did not noticed that.
I have an updated styling for my Netflix feed.
It now looks like this: 5 Images a row. Title on mouse-hover on top, with a nice frosted-glass hover-effect.
Description Text is scrollable.
It just works with the vodspy-feed-structure tho.
I hope it helps someone
MyYAML looks like this:
feed_url: "https://www.vodspy.de/netflix/rss.xml"
inclusions:
- title
- published
- summary
- image
My Dashboard-YAML: (In on view set in Panel mode)
columns:
- field: title
title: ''
- field: published
title: ''
- field: summary
title: ''
entity: sensor.netflix_feed
title: Neu bei Netflix
type: 'custom:list-card'
Since the List-Card did not get an update since then, I included my Stylings directly into the .js file, so I dont have to deal with long styling rules in yaml.
Let me paste my styles here:
You can also add them via card-mod and styles attribute directly in yaml I guess.
tbody {
display: grid;
grid-gap: 2em;
grid-template-columns: repeat(auto-fit, minmax(250px, 1fr));
@media only screen and (max-width: 768px) {
tbody {
grid-template-columns: repeat(auto-fit, minmax(180px, 1fr));
grid-gap: 0.5em;
table {
width: 100%;
table * {
box-sizing: border-box;
font-family: sans-serif;
th {
display: none;
tr {
display: flex;
flex-direction: column;
position: relative;
width: 100%;
margin: 0;
overflow: hidden;
border-radius: 10px;
.summary img {
width: 100%;
height: auto;
vertical-align: middle;
tr .title {
position: absolute;
text-align: left;
top: 0px;
padding: 35px 10px 10px 10px;
height: 100%;
width: 100%;
margin-left: auto;
margin-right: auto;
font-size: 24px;
line-height: 24px;
font-weight: bold;
color: #fff;
background-image: linear-gradient(rgba(0,0,0,1), rgba(0,0,0,0.5), rgba(0,0,0,0.5));
border-top-left-radius: 5px;
border-top-right-radius: 5px;
opacity: 0;
backdrop-filter: blur(3px);
visibility: hidden;
transition: opacity 0.1s;
tr .published {
position: absolute;
text-align: left;
font-size: 14px;
top: 0px;
color: #fff;
padding: 10px 10px;
opacity: 0;
tr:hover .title,
tr:hover .published,
tr:hover .summary p:first-of-type {
opacity: 1;
visibility: visible;
tr .summary p:first-of-type {
position: absolute;
bottom: 0;
padding: 0 10px 10px;
width: 100%;
margin: 0 auto;
font-size: 16px;
font-weight: 400;
color: #fff;
height: 50%;
z-index:1000;
opacity: 0;
overflow-y: scroll;
border-bottom-left-radius: 5px;
border-bottom-right-radius: 5px;
text-align: left;
tr .summary p:last-of-type {
display: none;
How can I add a horizontal line between the rows in the list card? can somebody help me please?
Thanks,
Vlad
How about multi-level tags in RSS feed? ātittleā and ādescriptionā are easy, but my RSS has image as following (from sensor output)
media_content:
- url: 'https://is.mediadelivery.fi/img/468/f27ac06cd454459c9bc5a35ab545fa76.jpg'
type: image/jpeg
width: '468'
If I use āmedia_contentā in lovelace_ui, it will output [object object]. If I use just āurlā, it doesnāt show anything.
How to pick the image URL from this XML?
Love this RSS parser!
But, iām trying to get <catregory term=> in the list but with no luckā¦
This is a part of the feed:
- <entry>
<id>rss:sr.se/traffic/8407999</id>
<title type="text">Stockholms lƤn (Halkvarning)</title>
<summary type="html"><p>Rapporter om mycket halt vƤglag pƄ mƄnga hƄll i lƤnet just nu. HalkbekƤmpning Ƥr pƄ gƄng, men kƶr fƶrsiktigt.<br/></p></summary>
<published>2020-12-30T21:29:30+01:00</published>
<updated>2020-12-30T21:29:30+01:00</updated>
- <author>
<name>Trafikredaktionen Stockholm</name>
</author>
<link href="https://sverigesradio.se/sida/trafiken?id=8407999" />
<category term="VƤg" />
As you can see the is not listed in my sensor.
Having this in conf.yaml
inclusions:
- title
- summary
- published
- updated
- author
- link
- category
Whatās wrong?
Is list-card removed form HACS ? Cannot find it.
You need to add it as a custom repo. Itās never been in the default repo.
