šŸ“° Lovelace: RSS Feed Parser Plugin/List Card
Hi There,
Having issues setting up my first card. I am using the list-card plugin and it seems to be working fine for txt and links but having issues with images. I donā€™t have a lot of CSS style experience and canā€™t work out how to resize my image. I am trying to set up a Netflix card like the example given below.
Image size way to large and canā€™t reduce it
Feed seems to be working fine
Are you able to post your lovelace code for the below example for me to take a look at please
Thanks Nick
I donā€™t use these anymore, actually :slight_smile: I created a component for trakt and feed that into the upcoming-media-card
Thanks. I donā€™t have this up and running on my machine any longer, hopefully someone else in the community has some insight.
This works under Templates:
{{ state_attr(ā€˜sensor.feedparser_android_autoā€™, ā€œAndroid Auto - Google Maps, Media & Messaging 4.4.5923 by Google LLCā€)|regex_replace(find=ā€™- Google Maps, Media & Messaging ā€˜, replace=ā€™ā€™, ignorecase=False)|regex_replace(find=ā€™ by Google LLCā€™, replace=ā€™ā€™, ignorecase=False) }}
Hope somebody can help me out, thnx!
Version 0.0.8 Released:
Warning: This is a breaking change for the https://github.com/custom-cards/list-card
I donā€™t have an expected date on when Iā€™ll get around to fixing it. If youā€™re using the list-card, do not upgrade to 0.0.8 for now.
  • Preserve timezone information
  • Display entries in a list instead of an object for easier use in templates
Quick update - I have taken a look at trakt offering and the free version is very limited for what Iā€™m after, but I came across a great post on Reddit which helped me sort out the image size issue I was having.
type: vertical-stack
cards:
  - columns:
      - field: title
        title: ''
      - field: published
        title: ''
      - field: summary
        title: ''
    entity: sensor.netflix_feed
    title: Netflix
    type: 'custom:list-card'
    style: |
      ha-card {
        max-width: 750px;
        margin-left: auto;
        margin-right: auto;
      img {
        float: left;
        height: 200px;
        margin-left: 10px;
        margin-right: 15px;
        margin-top: 10px;
        margin-bottom: 15px;
        box-shadow: 5px 5px 5px 0px rgba(0,0,0,0.5);
      .title {
        font-weight: 700;
        font-size: 22px;
        line-height: 1.2;
      td:first-child {
        padding-left: 10px;
        padding-top: 10px;
        display: block;
      td:nth-of-type(2) {
        padding-left: 10px;
        opacity: 0.7;
        display: block;
      td:last-child {
        min-height: 230px;
        display: block;
      tr {
        display: block;
      th {
        display: none;
      p {
        margin: 10px;
Nice work!
Hi. after updating to latest feedparser all my feedparser sensors return like this:
entries: [object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
friendly_name: lsm radio
icon: mdi:rss
Am I missing something? Thanks.
Yes, you missed the breaking changes
If your using list-card just add feed_attribute: entries that should bring it back to life.
Derp, I should have know that :man_facepalming:
Thanks, @dcshoecomp! Iā€™ll add that to the list-card readme.
I do think it breaks styling still though as that was based on keys, previously
Lol glad I can help. It just so happens today is the first day I ever used either of these components. Glad I didnā€™t give up so easy and ignored the breaking changeā€¦
:joy: Thatā€™s excellent
Apologies in advance for silly questions but new to this type of coding and Iā€™m a slow learner.
Not following, on the feed_attribute fix. Iā€™m using the list-card plugin and can see it needs a string type but what do I put in there, could someone please add an example?
This is what Iā€™m seeing come from the feed
entries Is what you need
Thank iantrich, silly me, I did see that in the post but didnā€™t know that i had to add the whole line ā€œfeed_attribute: entriesā€ added the entries bit and got it working again
Thanks Nick
This isnā€™t working for me. What am I doing wrong?
          - type: custom:list-card
            entity: sensor.met_office_weather_warnings
            title: -- Met Office Weather Warnings --
            columns:
              - title: Title
                field: title
              - title: Kind
                field: metadata_warningkind
              - title: Level
                field: metadata_warninglevel
              - title: Type
                field: metadata_warningtype
Thanks all. I was not using List card, now I added list card, and I got the entries.
Next question, how can i read these specific fields which consists of these conents:
<item>
					<title>A</title>
					<link>B</link>
					<description>C</description>
					<pubDate>D</pubDate>
					<guid>E</guid>
					<comments>F</comments><itunes:summary>1
</itunes:summary><itunes:image href="https://x" /><itunes:subtitle></itunes:subtitle><itunes:author>2</itunes:author><itunes:duration>3</itunes:duration><enclosure url="mp3" length="31278836" type="audio/mpeg" />
				</item>
I am unable to read the part with the mp3 part of the podcast, it gives me blank
can it be done somehow, or it is over the limitations of the plugin?
Basically I want to make a list of the mp3 files from the podcast RSS, and somehow stream them to media_player.
Maybe someone has any ideas. Thanks. :slight_smile:
Downgrade to previous version
I actually made a component/card specifically for that: https://github.com/custom-components/gpodder
