📰 Lovelace: RSS Feed Parser Plugin/List Card
I am trying to use this card for my electricity provider announcements page. But this page comes in json format, no rss, also having hundreds of unrelated announcements. I was able to filter those using a python script and write to a local file.
However, i have 2 problems:
  1. These feedparser and feedreader components could not read local files
  2. Not sure if they can read json dictionaries.
Do you have any suggestions?
RSS is Atom or XML based; so no JSON support. You could potentially create a template sensor for it? Not sure.
Think i found the solution. Instead of using feedparser, i used REST API to POST the filtered json to the attributes section of a command_line sensor in my python script. I also set the total number of json messages as the state of the sensor.
So, the outcome is:
11
Just like i wanted
 But I have to work on the fit of the text in the column now
 Any help with this?
EDIT: Solved it by adding spaces to the long-nonspaced words (i.e.after commas)
First, thanks for this plugin. Nice work!
But, I got a problem with a RSS-feed I try to read.
The description also contains som extra info [CDATA], and because of that, it seems that the text in the description can’t be read.
<description><![CDATA[köttfÀrslimpa potatis grÀddsÄs lingonsylt och grönsaker]]></description>
The YAML-file looks like this:
platform: feedparser
feed_url: 'https://skolmaten.se/glantans-forskola9/rss/weeks/'
date_format: '%a, %b %d %I:%M %p'
inclusions:
  - title
  - description
#    - link
#    - image
#    - language
#  - pubDate
#  exclusions:
#    - language
Only title works, not descripton.
Any ideas what to do?
I’m just using the feedparser python library for grabbing the individual fields. I know CDATA is valid XML, not sure if it is consider valid for an RSS feed :man_shrugging: Can’t think of a way around that without working with the actual feedparser library itself. I don’t see myself doing that anytime soon.
OK. Thanks for the answer.
According to this document it is valid.
http://www.rssboard.org/rss-encoding-examples
Hi @Twit
Did you manage to get thee BBC feed working? I get the same object issue as you.
@iantrich I managed to get the sensor working however I require my template to display all the available titles from my xml url. How can I do that?
I have this so far:
- platform: feedparser
  name: Sky Tech Feed
  feed_url: 'http://feeds.skynews.com/feeds/rss/technology.xml'
  inclusions:
    - title
and this:
{{states.sensor.sky_tech_feed.attributes.entries[0].title}}
but the above only shows 1 title and not all. Is there any way to get all the available titles? mmind you the number of titles keep changing and are not constant.
@petro can you help please?
thanks.
{{states.sensor.sky_tech_feed.attributes.entries | map(attribute='title') | list | join(', ') }}
thanks alot @petro. it works fine however when I try and use it in an automation it throws up an error:
here is the automation:
- id: 'news_on_led_board'
  alias: News On Led Board
  initial_state: 'on'
    - platform: state
      entity_id: switch.livingroom_lights
      to: "on"
    - delay: '00:00:05'
    - service: mqtt.publish
      data_template:
        topic: "messageboard/messages"
        payload_template: '{ "message": "BBC News UK: {{states.sensor.bbc_news_feed.attributes.entries | map(attribute='title') | list | join(', ') }}
the error I get is:
2019-11-30 10:58:47 ERROR (SyncWorker_1) [homeassistant.util.yaml.loader] while parsing a block mapping
  in "/config/automations.yaml", line 29, column 9
expected <block end>, but found '<scalar>'
  in "/config/automations.yaml", line 30, column 121
2019-11-30 10:58:47 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while parsing a block mapping
line 30, column 121 seems to be the problem which is the colon before the t in 'title'
any idea on how to resolve that?
thanks
A quick ‘side’ question
Can you please share your BBC News feed sensor?
http://feeds.bbci.co.uk/news/uk/rss.xml
You’re trying to do some odd things with your payload and it looks like your missing your last } for the json.
try this
      data_template:
        payload:
          message: >
Thanks a lot mate
I have RSS feed parser and list card working but I would like to filter the feed content and am not sure how to do it.
Config:
  feed_url: http://www.fire.tas.gov.au/Show?pageId=colBushfireSummariesRss&region=S&alertsOnly=true
  inclusions:
    - title
    - summary
This is what shows as the feed attributes in developer tools:
entries: [object Object],[object Object],[object Object],[object Object],[object Object]
friendly_name: TFS Alerts
icon: mdi:rss
If I click on the sensor I get this showing in the developer tools State attributes (YAML, optional):
entries:
  - title: Pelham and Elderslie areas
    summary: >-
      ALERT LEVEL: Advice<br /> Region: S<br /> LOCATION: Pelham and Elderslie
      areas<br /> STATUS: Going<br /> TYPE: VEGETATION FIRE<br /> SIZE: 2050
      Hectares<br /> Number of Vehicles: 14<br /> More Info: <a
      href="http://www.fire.tas.gov.au/a/81891">http://www.fire.tas.gov.au/a/81891</a><br
      /> RESPONSIBLE AGENCY: Tasmania Fire Service<br /> UPDATED: Sat, 4 Jan
      2020 13:18:04 +1100<br />
  - title: 'Broadmarsh, Black Brush and surrounding areas'
    summary: >-
      ALERT LEVEL: Advice<br /> Region: S<br /> LOCATION: Broadmarsh, Black
      Brush and surrounding areas<br /> STATUS: Going<br /> TYPE: VEGETATION
      FIRE<br /> SIZE: 2050 Hectares<br /> Number of Vehicles: 14<br /> More
      Info: <a
      href="http://www.fire.tas.gov.au/a/82195">http://www.fire.tas.gov.au/a/82195</a><br
      2020 13:19:25 +1100<br />
  - title: 'Kempton, Hunting Ground and surrounding areas'
    summary: >-
      ALERT LEVEL: Advice<br /> Region: S<br /> LOCATION: Kempton, Hunting
      Ground and surrounding areas<br /> STATUS: Going<br /> TYPE: VEGETATION
      Info: <a
      href="http://www.fire.tas.gov.au/a/82214">http://www.fire.tas.gov.au/a/82214</a><br
      2020 13:20:40 +1100<br />
  - title: 'Bagdad, Green Valley, Cockatoo Gully and Dysart areas'
    summary: >-
      ALERT LEVEL: Advice<br /> Region: S<br /> LOCATION: Bagdad, Green Valley,
      Cockatoo Gully and Dysart areas<br /> STATUS: Going<br /> TYPE: VEGETATION
      Info: <a
      href="http://www.fire.tas.gov.au/a/82215">http://www.fire.tas.gov.au/a/82215</a><br
      2020 13:14:11 +1100<br />
  - title: 'Pearce Basin, Southwest'
    summary: >-
      ALERT LEVEL: Advice<br /> Region: S<br /> LOCATION: Pearce Basin,
      Southwest<br /> STATUS: Going<br /> TYPE: VEGETATION FIRE<br /> SIZE: 2700
      hectares<br /> Number of Vehicles: <br /> More Info: <a
      href="http://www.fire.tas.gov.au/a/81562">http://www.fire.tas.gov.au/a/81562</a><br
      /> RESPONSIBLE AGENCY: Parks and Wildlife Service<br /> UPDATED: Sat, 4
      Jan 2020 13:22:39 +1100<br />
icon: 'mdi:rss'
Basically I want to filter out entries with ALERT LEVEL: Advice. Is this possible?
I think you’ll need to create a template sensor based on the alerts on
Ok I think I can work with this:
{% for item in state_attr('sensor.tfs_alerts','entries') %}
  {% if 'ALERT LEVEL: Advice' not in item.summary %}
    {{ item.summary }}
  {% endif %}
{% endfor %}
hi all,
is this broken?
I get the: entries: [object Object], on the sensor state
and I can get the sensor attribute as a template sensor
but this can’t be used with the list card right?
The resulting sensor can be used by the list card, yes. Template would to be the correct format
