Love the card to control my AC’s :).
However, how do I add the “mode” dropdown? and how can I set a background color for the card? It’s now transparant.
And for the world, I can’t figure how to hide the labels “Werking” and “Ventilatormodus” and to put custom icons in the fanspeed buttons…
Help greatly appreciated!!
- type: custom:simple-thermostat
style: |
ha-card {
--st-font-size-xl: 20px;
--st-font-size-title: 20px;
--st-font-size-sensors: 12px;
entity: climate.ac_woonkamer
name: Airco Woonkamer
header:
icon: false
layout:
step: column
mode:
names: false
control:
hvac:
heat_cool: false
icon: mdi:fire
dry: false
fan:
auto: false
medium-low: false
medium-high: false
very-high: false
RCZ
(Roelf Zomerman)
December 26, 2022, 10:05am
907
I’m trying to load this card, but it isnt working for me… I added it via HACS - but when I add it into a dashboard it goes: Custom element doesn’t exist: simple-thermostat…
Not sure what I’m doing wrong - and I’m sure its a beginners mistake…
I also added to my configuration.yaml:
lovelace:
mode: yaml
resources:
- url: /local/simple-thermostat.js?v=1
type: module
but not sure if that is required…
bouwew
(Bouwe)
December 27, 2022, 10:27am
908
When installing via HACS the url must be: - url: /hacsfiles/simple-thermostat/simple-thermostat.js
Judu
December 28, 2022, 12:36pm
909
I would like to find a way to hide setpoint temperature when in mode eco (to reflect the behavior of my thermostats - eco mode is frost protection in KNX and temperature is set in programming).
Any idea how I could do ?
Thank you
Judu
December 29, 2022, 12:27am
910
This works but need card templater:
type: custom:card-templater
card:
entity: climate.sdb
layout:
step: column
header: true
setpoints_template: '{{ "true" if states.climate.sdb.attributes.preset_mode == "eco" else " "}}'
control:
preset:
eco:
icon: mdi:snowflake
comfort:
icon: mdi:sun-thermometer
entities:
- entity: sensor.time
However it was verry laggy.
I tried instead config-template-card which works just fine:
type: custom:config-template-card
entities:
- climate.salon
variables:
- states['climate.salon'].attributes['preset_mode']
card:
entity: climate.salon
layout:
step: column
header: true
setpoints: ${if (vars[0] === 'eco') {true} else { }}
control:
preset:
eco:
icon: mdi:snowflake
comfort:
prockeo
(Paul)
January 4, 2023, 12:41am
911
Is there a way to control the setpoints such that when:
Mode = ‘auto’
setpoint:
target_temp_high:
target_temp_low:
Mode = all others (Heating, cooling, fan,…)
setpoint:
temperature
Anyone else seeing problems with this custom card since updating to 2023.1?
iBRHooM
(Ibrahim)
January 6, 2023, 2:34pm
913
Yeah me after 2023.1 update
Had to name it manually:
control:
preset:
_name: Preset Mode
here how I override the naming:
control:
swing:
_name: Swing Mode
_hide_when_off: true
hvac:
mode:
icon: false
fan:
_name: Fan Mode
and when it’s off:
waiting for the update to fix it.
That fixes it - many thanks!
I’ve attempted to read this entire thread looking for a solution to my issue, but I can’t seem to find anything that resembles my issue! I can’t even find anything with a search.
My issue: The ‘up’ and ‘down’ buttons on my thermostat card are invisible. The buttons are there, and I can press them, but the “+” or “-” icons are literally not visible. It’s not a huge issue, as I can still use the card, but it makes it a bit tougher for others in the house to use properly. Can I change the color of those buttons somehow?
Also, this issue is present on both my web browser (firefox), and my HA app - (iPhone)
Can anyone help me conditionally format the card?
I have some TRVs which appear as climate devices but don’t actually set a state.
What I want to do (for now) is simply have some visual indication (card background colour) of whether the current temperature < set point.
Also how do I hide the state in compact view?
llamafilm
(Elliott Balsley)
January 17, 2023, 5:07pm
917
@jameson_uk This might help you. Here’s what I did to style the background red when the heater is active.
style: |
ha-card {
{% if is_state_attr("climate.mysa_bathroom_thermostat", "hvac_action", "heating") -%}
--ha-card-background: rgb(255, 130, 130)
{%- else -%}
--ha-card-background: rgb(255, 255, 255)
{%- endif %}
nickrout
(Nick Rout)
January 17, 2023, 6:51pm
918
What theme are you using?
Using the default theme and struggling to get anything to work…
just trying
entity: climate.bedroom_trv
style: |
ha-card {
--ha-card-background: rgb(255,0,0);
isn’t setting the card background colour (nor any of the alternative I tried) let alone making things conditional.
What I am missing?
nickrout
(Nick Rout)
January 18, 2023, 6:34pm
921
That question was for @austinmeier
Judu
January 27, 2023, 9:58pm
922
entities:
- climate.salon
- binary_sensor.fenetresalonknx
variables:
card:
version: 3
layout:
step: row
mode:
headings: false
header:
faults:
- entity: binary_sensor.fenetresalonknx
icon: mdi:window-open-variant
hide_inactive: true
sensors:
- id: state
label: mdi:water-boiler
template: '{{hvac_action|translate(''state_attributes.climate.hvac_action.'')}}'
- id: temperature
label: mdi:thermometer
template: '{{current_temperature}}'
unit: °C
control:
preset:
eco:
icon: mdi:snowflake
comfort:
style: |
.sensors.with-labels.as-table {
justify-self: left;
margin-left: 40px;
Shivy011
(Shivy011)
February 2, 2023, 1:37pm
923
Could you share your full code for the fan modes?
austinmeier
(Austin Meier)
February 2, 2023, 10:18pm
924
I was not using any theme. No idea why it wasn’t working. But it works now, and I haven’t changed anything. Maybe a reboot or two later had fixed it.
Thanks anyway! This card is perfect.
pete.AUS
(Pete)
February 9, 2023, 3:14am
925
Finally, got around to setting up this card, any idea why I see ui.card.climate.fan_mode when setting up the fans?
fugley
February 9, 2023, 3:19am
926
probably because your AC has a fan only mode your unaware of
