Lovelace: Simple thermostat card
I am using compact mode with step_layout: row, and it works but it keeps the up and down arrows rather than the + and - icons. I’ve cleared my cache etc. Any idea what the issue is?
Has anyone succeeded in adding Haptic / Vibration to the buttons?
If you find a solutions for this please let me know, I have the same issue.
modes:
  heat:
    include: false
Is this not implemented anymore? Because I’m trying to get rid of all modes, but I can’t even get rid of one.
EDIT:
Never mind, found the solution:
control:
  heat:
    include: false
hello, can you tell me as i can have temperature horizontal central and + - horizontal
now i have vertical , if very good for my have all horizontal and central in the card
this is my code inside card
control:
  fan: true
  hvac:
    'off':
decimals: 0
entity: climate.condizionatore
horizontal_vane: null
sensors:
  - entity: climate.condizionatore
step_size: 1
style: |
  ha-card {
    --st-font-size-xl: 40px;
    --st-font-size-m: 20px;
    --st-font-size-title: 22px;
    --st-font-size-sensors: 0px;
    --st-spacing: 2px;
    --border-radius:0px;
    --primary-text-color: ;
    --secondary-text-color: ;
    --paper-item-icon-color: blue;
  header {
    margin-bottom: 0px !important;
    padding-bottom: 0px !important;
swing_mode: vertical
type: 'custom:simple-thermostat'
vertical_vane: swing
I want to use this card for my evohome thermostat.
Evohome has A climate entitie for every room and an overal entitie With the modes and preset and the avarage temp of the whole house. But you can not set the temperature.
I want to use this Overal entitie for only displaying the modes and preset.
But it shows n/a for setting the temperature, because it is not possible.
Is there a way to remove this from the card?
Compact mode.
Is it working for you guys? I always used the standard layout with arrows up and down but now I am trying to create another view and failing to have the compact size.
HA 108, simple-thermostat 0.34.1
hello , i use this and work " step_layout: row" i have horizontal now :slight_smile:
Can you tell me as i put central in card
thx you
Screenshot_2020-05-02 Prova - Home Assistant
I was having a similar issue, I went in the folder and deleted the .js and replace with the one in the git!
\\192.168.X.X\config\www\community\simple-thermostat
Replaced with this:
https://github.com/nervetattoo/simple-thermostat/releases/download/0.34.1/simple-thermostat.js
Maybe uninstall and install again works? Not sure, replacing the content of the file worked perfectly! :slight_smile:
Yep.
I reinstalled via HACS at Sunday and it immediatelly fixed itself :slight_smile:
I’am making a lovlace interface for my iphone, so makeing evrything smaller en set it in vertical/hortizontal stack.
I’ve installed the card mod plugin and added this style:
style: |
  ha-card {
    --st-font-size-xl: 20px;
    --st-font-size-m: 12px;
    --st-font-size-title: 20px;
    --st-font-size-sensors:12px;
    --st-spacing: 2px;
  .mode-item {
    flex-direction: row !important;
    font-size: 80%;
In my browser it is working, but on my iphone app only the st-font-size-xl is not working.
It stays the same, is there a way to solve this?
Hi all, there is a way to set an icon instead temperature text?
thanks
Well, question and a hint at once :wink:
How did you implement those two icons bellow?
Same apporach can be done I think. Together with hide: temperature
I can do as you suggest but temperature is an attribute of climate.entity so I need to add another sensor or template to read the temperature and display it. I try with secondary_info with no luck
entity: climate.salone
hide:
  state: true
  temperature: true
icon:
  cool: 'mdi:snowflake'
  heat: 'mdi:fire'
  'off': 'mdi:power'
sensors:
  - entity: climate.salone
    secondary_info: current_temperature
    icon: 'mdi:home-thermometer-outline'
Ok I solved myself reading more the help
hide:
  state: true
  temperature: true
icon:
  heat: 'mdi:fire'
  'off': 'mdi:power'
sensors:
    attribute: current_temperature
  - entity: sensor.salone_velocita_motore
    icon: 'mdi:fan'
  - entity: sensor.salone_temperatura_batteria
    icon: 'mdi:coolant-temperature'
    name: Battery Temperature
step_size: 0.1
control:
  _headings: false
I have Mose electrical thermo via Tuya have summary digit tem_set and temp_current as temperature in C. Im create 2 sensors for correct digit as:
but it does not have the desired effect to the fullest
curren device
Love the card. Wondering if it is possible to hide the min temp for those of us with a thermostat that displays both high and low set points. I don’t typically care to view the low set point, only the high. Sorry if it was covered in the thread somewhere, I missed it if so.
with update HA 0.110 i see lost button - + in temperature in the card . need update card?
The card needs to be updated, there are already two issues open for that on github #127 #123
