Lovelace: Simple thermostat card
When installing via HACS the url must be: - url: /hacsfiles/simple-thermostat/simple-thermostat.js
I would like to find a way to hide setpoint temperature when in mode eco (to reflect the behavior of my thermostats - eco mode is frost protection in KNX and temperature is set in programming).
Any idea how I could do ?
Thank you
This works but need card templater:
type: custom:card-templater
card:
  type: custom:simple-thermostat
  entity: climate.sdb
  layout:
    step: column
  header: true
  setpoints_template: '{{ "true" if states.climate.sdb.attributes.preset_mode == "eco" else " "}}'
  control:
    preset:
      eco:
        icon: mdi:snowflake
      comfort:
        icon: mdi:sun-thermometer
entities:
  - entity: sensor.time
However it was verry laggy.
I tried instead config-template-card which works just fine:
type: custom:config-template-card
entities:
  - climate.salon
variables:
  - states['climate.salon'].attributes['preset_mode']
card:
  entity: climate.salon
  layout:
    step: column
  header: true
  setpoints: ${if (vars[0] === 'eco')  {true} else { }}
  control:
    preset:
      eco:
        icon: mdi:snowflake
      comfort:
Is there a way to control the setpoints such that when:
Mode = ‘auto’
   setpoint:
      target_temp_high:
      target_temp_low:
Mode = all others (Heating, cooling, fan,…)
   setpoint:
     temperature
Anyone else seeing problems with this custom card since updating to 2023.1?
Yeah me after 2023.1 update
Had to name it manually:
control:
  preset:
    _name: Preset Mode
here how I override the naming:
control:
  swing:
    _name: Swing Mode
    _hide_when_off: true
  hvac:
    mode:
      icon: false
  fan:
    _name: Fan Mode
and when it’s off:
waiting for the update to fix it.
That fixes it - many thanks!
I’ve attempted to read this entire thread looking for a solution to my issue, but I can’t seem to find anything that resembles my issue! I can’t even find anything with a search.
My issue: The ‘up’ and ‘down’ buttons on my thermostat card are invisible. The buttons are there, and I can press them, but the “+” or “-” icons are literally not visible. It’s not a huge issue, as I can still use the card, but it makes it a bit tougher for others in the house to use properly. Can I change the color of those buttons somehow?
Also, this issue is present on both my web browser (firefox), and my HA app - (iPhone)
Can anyone help me conditionally format the card?
I have some TRVs which appear as climate devices but don’t actually set a state.
What I want to do (for now) is simply have some visual indication (card background colour) of whether the current temperature < set point.
Also how do I hide the state in compact view?
@jameson_uk This might help you. Here’s what I did to style the background red when the heater is active.
style: |
  ha-card {
    {% if is_state_attr("climate.mysa_bathroom_thermostat", "hvac_action", "heating") -%}
      --ha-card-background: rgb(255, 130, 130)
    {%- else -%}
      --ha-card-background: rgb(255, 255, 255)
    {%- endif %}
What theme are you using?
Using the default theme and struggling to get anything to work…
just trying
entity: climate.bedroom_trv
style: |
  ha-card {
    --ha-card-background: rgb(255,0,0);
isn’t setting the card background colour (nor any of the alternative I tried) let alone making things conditional.
What I am missing?
That question was for @austinmeier :slight_smile:
entities:
  - climate.salon
  - binary_sensor.fenetresalonknx
variables:
card:
  version: 3
  layout:
    step: row
    mode:
      headings: false
  header:
    faults:
      - entity: binary_sensor.fenetresalonknx
        icon: mdi:window-open-variant
        hide_inactive: true
  sensors:
    - id: state
      label: mdi:water-boiler
      template: '{{hvac_action|translate(''state_attributes.climate.hvac_action.'')}}'
    - id: temperature
      label: mdi:thermometer
      template: '{{current_temperature}}'
      unit: °C
  control:
    preset:
      eco:
        icon: mdi:snowflake
      comfort:
  style: |
    .sensors.with-labels.as-table {
        justify-self: left;
        margin-left: 40px;
Could you share your full code for the fan modes?
I was not using any theme. No idea why it wasn’t working. But it works now, and I haven’t changed anything. Maybe a reboot or two later had fixed it.
Thanks anyway! This card is perfect.
Finally, got around to setting up this card, any idea why I see ui.card.climate.fan_mode when setting up the fans?
probably because your AC has a fan only mode your unaware of
Cant see any other modes
hvac_modes: heat_cool, heat, dry, fan_only, cool, off
min_temp: 7
max_temp: 35
fan_modes: low, medium, high
current_temperature: 25
temperature: 22
fan_mode: low
friendly_name: AC Daikin
supported_features: 9
your “heat pump” has a fan only mode and this card will be showing you what its picked up and available to use
