Lovelace: Simple thermostat card
Merci, je débutais…
Oui, je me doute… j’ai un peu déterré le post…
Merci car vous avez été un grand artisan de ma progression… :wink:
I’m having the same problem, but on the sensors: section. I tried putting a _ before name but it didn’t work. Any ideas? Here’s what I have and what I get. It used to work before 2023.
    - type: custom:simple-thermostat
      entity: climate.entrance
      step_size: 0.5
      header: false
      sensors:
        - attribute: preset_mode
Can anyone help me here with the sensor template?
simple-thermostat/sensors.md at beta · nervetattoo/simple-thermostat · GitHub
I dont quite understand how to implement them. Essentially I want to change the sensor state to red when its “on” blue when its “off”
  entity: climate.heater1
  sensors:
    - entity: input_boolean.heater1
      template: "{{state.text| css({ 'font-size': '3em', color: 'red' }) }}"
  layout:
When I add
  version: 3
  sensors:
  layout:
version:3 everything disappears and I cant seem to find any examples in the forum to cheat from.
Also, do these templates respond to normal jinja templates?
You can try :
  • type: custom:simple-thermostat
    step_size: 0.5
    header: false
    sensors:
    control:
    hvac: true
    preset:
    _name: Preset Mode
Hi to all!
i’m trying to use this card with my Panasonic Etherea (integration Panasonic Cloud Comfort) but seems card cannot detect fan and swing modes: i’m trying to hide some of them without any result.
any tips?
as you can see, i’m trying, as test, to hide fan-auto, fan-slow, swing-auto and swing-up modes but all of them remains displayed.
Thanks in advance
Cattura
entity: climate.clima_camerina
layout:
  step: row
  mode:
    headings: true
control:
  hvac:
    _name: hvac
    heat_cool:
    heat:
    cool:
    dry:
    fan_only:
    'off':
  fan:
    _hide_when_off: false
    _name: fan
    auto: false
    low: false
  swing:
    _name: swing
    auto: false
    up: false
  present: false
decimals: 1
label:
  state: null
  temperature: null
hide:
  state: true
  temperature: true
header: false
card_mod:
  style: |
    ha-card {
    --st-font-size-xl: 24px;
    --st-font-size-m: 24px;
    --st-font-size-title: 30px;
    --st-font-size-sensors: 12px;
    --st-spacing: 2px;
    --st-mode-active-color: var(--contrast20);
    --st-mode-background: var(--contrast1);
    --st-mode-active-background: var(--green);
    padding-bottom: 5px !important;
    margin-left: 1px;
    margin-right: 1px;
    ha-card .mode-item {
      --st-spacing: 18px;
      border-radius: 20px;
i’m replying to myself… i’ve fixed the error, the “mode” status is case sensitive thus i’ve to write Auto and not auto . hope this will help someone else :slight_smile:
Is there a way to add sensors as a row of buttons? I would love to have my window sensors show up as a row of buttons below my presets that change based on there state. I currently have mine setup in a stack in card with simple thermostat up top, a markdown card with indoor/outdoor temps, and a mini graph card showing indoor/outdoor temps.
I am not opposed to using a custom button card below simple thermostat, but when I tried that, I could not get the style of the button cards to show over top of the style for the stack-in-card.
Hi Larry,
can you share your code?
Sure. Here it is. I am sure it can be refined, but I am still learning all of this. I also can’t get the tap-action to work to bring up the more-info dialog.
      - type: custom:stack-in-card
        card_mod:
        style: |
          ha-card {
            --ha-card-background: {{ 'rgba(255, 255, 255, 0.85)' if is_state('climate.living_ecobee_app', 'heat_cool') else 'rgba(115, 115, 115, 0.25)' }};
            --primary-text-color: {{ '#4b5254' if is_state('climate.living_ecobee_app', 'heat_cool') else '#97989c' }};
            border-radius: 10px;
            border: none;
        cards:
            entity: climate.living_ecobee_app
            header: false
            hide:
              temperature: true
              state: true
            step_size: 1
            decimals: 0
            control:
              hvac:
                'off':
                  icon: mdi:power
                heat: false
                cool: false
                heat_cool:
                  icon: mdi:auto-mode
              preset:
                Home:
                  icon: mdi:home
                Girls:
                  icon: mdi:human-female-female
                Sleep:
                  icon: mdi:sleep
                Away:
                  icon: mdi:home-export-outline
            layout:
              step: row
              mode:
                icons: true
                headings: false
            tap_action:
              action: more-info
            fallback: 'Off'
            style: |
              ha-card {
                --st-mode-active-background: rgba(255, 255, 255, 0.85);
                --st-mode-active-color: rgb(49, 130, 183);
                --st-mode-background: rgba(115, 115, 115, 0.25);
                border: none;
          - type: markdown
            content: >-
              <center><font size="5">
              Inside: {{ states('sensor.inside_temperature') }}°F / Outside: {{ states('sensor.outside_temperature') }}°F
            tap_action:
              action: more-info
            style: |
              ha-card {
                border: none;
          - type: custom:mini-graph-card
            entities:
              - entity: sensor.living_ecobee_app_temperature
                show_state: false
                show_indicator: false
                show_legend: false
                show_fill: false
              - entity: sensor.outside_temperature
                show_state: false
                show_legend: false
                show_fill: false
            align_state: center
            show:
              state: false
              points: false
              icon: false
              labels: false
            style: |
              ha-card {
                border: none;
I gave up on window sensors in my stack-in-card and just created a row of sensors below my climate control.
Side question here: may I ask what device you are using to control the valves?
I don’t know if it is a right way to handle it, but you could always try/use this:
style: |
     ha-card .mode-title {
        display: none;
But from the multiple examples in this thread actually this should be enough to remove “Werking” and “Ventillatormodus”:
    control:
              hvac:
                'off':
                  icon: mdi:power
I think you should do this:
      step_size: 0.5
      header: false
      control:
        preset:
          mode:
          _name: type what you want here
Thank you! That syntax makes zero sense to me so I never would have figured it out without your help!
Maybe someone can help me with this…
I´m trying to add controls for the fan speed etc but I just cant get it to work…
the first card is what i have but as soon as I put in the code for controls the card just transforms to the second card in the image without any of the controls and even removes the presets for cold, heat etc.
this is my yaml:
entity: climate.ac
layout:
  step: row
  mode:
    icons: true
    names: false
    headings: false
header: false
sensors: false
style: |
  background: rgba(255, 255, 240, 0.05);
  color: #a2a7a6;
    font-family: Roboto,sans-serif;
    font-weight: 500;
control:
  fan:
    _name: Fan Mode
    _hide_when_off: true
    low:
      icon: mdi:fan-speed-1
    medium:
      icon: mdi:fan-speed-2
    high:
      icon: mdi:fan-speed-3
    medium low:
      icon: mdi:fan-chevron-down
    medium high:
      icon: mdi:fan-chevron-up
    auto: true
my AC does have these options in the app so they should be available, right?
Mind the indentation for (and after) control:
Change:
style: |
  color: #a2a7a6;
    font-weight: 500;
control:
  fan:
    _name: Fan Mode
to:
style: |
  color: #a2a7a6;
    font-weight: 500;
  control:
    fan:
    _name: Fan Mode
Doesnt work and from what I can tell from previous examples in this thread the “control” part shouldnt be indented. Indenting just makes it invalid but this keeps the presets, but probably just because that part is invalid…
Is there any way to test this? Like should there be entities for these controls? Im using the Tuya integration but can only see temp and Ionizing
Well, before posting I did test the code using a valid entity and the result is, control: unindented:
control: indented:
But how does that access the fan-speed? I would want something like this:
Check for the attributes of that climate.ac-entity. If fan_modes are available as attributes Simple Thermostat Card will pick them up and you should be able to configure them via the Lovelace Card.
