any ideas on what domain i need to use ??
ta
Lee
ta
Lee
either weather.harrisdale or weather.jandakot
If you donāt see one of those in dev-tools you might need to make sure you have the latest version, remove the integration and add it back again. It definitely works you just might have an older version of the integration)
Thanks David
mmm seems the simple card is not working with BOM anymore ā¦
after inspecting the raw HTML i get
<simple-weather-card></simple-weather-card> ==$0
not sure if the weather domain is formatted correctly for the card ā¦
my Domain (weather.) looks like this
temperature: 21.7
humidity: 51
wind_bearing: SW
wind_speed: 30
attribution: Data provided by the Australian Bureau of Meteorology
forecast:
- datetime: '2020-11-20T16:00:00Z'
temperature: 25
condition: clear-night
templow: null
precipitation: 0
precipitation_probability: 0
- datetime: '2020-11-21T16:00:00Z'
temperature: 29
condition: sunny
templow: 13
precipitation: 0
- datetime: '2020-11-22T16:00:00Z'
temperature: 35
condition: sunny
templow: 16
precipitation: 0
- datetime: '2020-11-23T16:00:00Z'
temperature: 33
condition: sunny
templow: 18
precipitation: 0
- datetime: '2020-11-24T16:00:00Z'
temperature: 27
condition: sunny
templow: 13
precipitation: 0
- datetime: '2020-11-25T16:00:00Z'
temperature: 25
condition: sunny
templow: 12
precipitation: 0
- datetime: '2020-11-26T16:00:00Z'
temperature: 24
condition: cloudy
templow: 13
precipitation: 0
- datetime: '2020-11-27T16:00:00Z'
temperature: 27
condition: sunny
templow: 13
precipitation: 0
precipitation_probability: 20
friendly_name: Harrisdale
icon: 'mdi:weather-night'
is this correct format ?
HA : 0.118.0
Ta
Lee
Mine seems ok.
Is it possible to somehow change/replace the icons of this card?
Thanks a lot!
@tismondo:
Is it possible that you send/post your config to get this third row working?
This is it what Iām searching for. to have the possibility for different tap_actions in one cardā¦ the other way around you need thisā¦
Thanks in advance!
Iām having some trouble with this card not showing up. I installed it through HACS and added this to my cinfiguration.yaml
- url: /hacsfiles/simple-weather-card/simple-weather-card-bundle.js
type: module
Iāve restarted several times but still get this:
The test code i did was this:
type: 'custom:simple-weather-card'
entity: weather.hjem
backdrop: true
I have the same issue. At the same time, I have over 20 added custom cards.
Also, Iāve tried changing the type to ājsā and cleaning the cache as well. I have also tried adding resources to Configure and to ui-lovelace file as the instruction says.
+1 for some help here. @Vintage89 Have you fixed your error?
I tried it again a couple of weeks later, and then it worked. Not sure if I did anything to solve it though. Sorry I canāt be more of help
@kalkih Love this card!! I was wondering if there is any way to use this āunbundledā? I want to make a couple tweeks and donāt see anyway to do it with the bundled version?
My goal would be to change the current card into this to better fit the style of my dashboard:
As far as I can tell, Iāve followed the github install simple-weather-card via HACS, but when I go to add the card to a Lovelace dashboard, it doesnāt appear on the list. Is it supposed to be added manually? When I try that approach, the card doesnāt appear in the live version. Help!
im having the same issue. cant get this to work.
Got mine working, somehow, but for the life of me, at this point in time I donāt remember how, sorry.
@kalkih I saw there is 1 issue āfeature-request/enhancementā in the backlog, regarding Wind_Speed, many card seems to hard-code km/h
so my question is, shouldnāt it be fairly easy to implement a āpickerā where we could choose which unit ( i mean the following text) to (ATTR_WEATHER_WIND_SPEED_UNIT = āwind_speed_unitā) , as one could expect any weather integration reports correct in what ever āunitsā developer/api decides to deliver.
but im not a developer, and im not too familiar with how the javascript code in ha-cards either
Below is from (weather-chart-card) github,
and i believe this is the code (or maybe partly) , as i dont know how similar your code is to this card
renderAttributes({config, humidity, pressure, windSpeed, windDirection} = this) {
if (this.unitSpeed === 'm/s') {
windSpeed = Math.round(windSpeed * 1000 / 3600);
show_attributes: true
units:
pressure: mmHg
speed: m/s
BƤst Regards
Edit: or simply skip the render, and just apply choice of āunit - txtā, ( km/h or m/s )
PS: The weather integration āTrafikverketā (API) actually reports windspeed in m/s, i believe HA-defaullt weather met.no(API) also reports in m/s
Never Mind, i assume you lost interest for this card, or otherwise not have time for it ā¦ i change it my self in the .js, ā¦ as mention atleast here in āNordenā , windspeed is regularly mentioned as m/s
Is this card compatible with the weather services of the latest Home Assistant 2023.11 version ?
the UI integration donāt show up the forecast temperatures anymore
