I replied down below.
Based on what you previously posted:
card:
entity: sensor.frigate_coral_fps
graph: line
style: |
ha-card {
background-color: var(--primary-background-color);
border-radius: 15px;
box-shadow: {% if is_state('sun.sun', 'above_horizon') %}
-8px -8px 8px 0 rgba(255,255,255,.5),8px 8px 8px 0 rgba(0,0,0,.03);
{% else %}
-8px -8px 8px 0 rgba(50, 50, 50,.5),8px 8px 8px 0 rgba(0,0,0,.15);
{% endif %}
type: sensor
style: |
ha-card {
margin: 10px;
type: 'custom:mod-card'
I just tried it, the bottom part of the card is still not rounded.
@invinciberry Could you try this part to look like:
box-shadow:
{% else %}
{% endif %}
You could also try mini graph card.
It works! Thanks!
Self-promotion (for the sake of it): I made some themes based off of JuanMTech’s, but I added soft UI styling.
Features:
- Can instantly add soft-ui to an auto-generated dashboard, without needing to edit it (and disable auto-generation).
- Works with auto-generated dashboards and handmade ones
- Works with badges
- Gives cards in dashboards and cards everywhere soft UI
- Adds a compact header with no work required
They’re available as default HACS repos. Here’s the links on GitHub:
@N-l1 I noticed you put your old automations in a singular new one. I tried it but it gives me an error:
Says missed a comma in this line: {% if states('sun.sun') == "above_horizon" %}
I just don’t see the error though. I’m sure you do
Good work, it certainly adds a bit of flair to cards. I just started making my remote card.
I few more color choices would be nice though.
I’ve updated the automation to use the new choose feature instead of using templates, should work now (if you are on >= 0.113)
Thanks! I have a slightly shorter version:
- id: set_theme
alias: "Set theme"
initial_state: 'on'
- platform: homeassistant
event: start
- platform: sun
event: sunrise
- platform: sun
event: sunset
- choose:
- conditions:
- condition: state
entity_id: sun.sun
state: 'below_horizon'
sequence:
- service: frontend.set_theme
name: "Google Dark Theme"
default:
name: "Google Light Theme"
N-L1 already updated the code, but basically instead of
--paper-card-background-color
use one of these:
--ha-card-background
--card-background-color
background-color
To make this easier, open the raw config editor, move it into another text editor and do a find/replace.
Amazing thanks!
I may just install this lovelace. I like simple.
This looks amazing - between everyone’s hard work and little bit of personal tweaking my dashboard is looking super slick.
Great, very nice! How did you color the border around your cards?
Thanks! – Almost my entire dashboard is built with custom button cards and I make heavy use of templates. In some ways this probably makes things harder than they need to be, but my previous setup was already setup this way.
Light entities point to a ‘light’ template that says to change the border when the state is on. And my other entities that require different colors in my set up also have their own template(s).
Lovelace yaml entry:
- entity: switch.kitchen_overhead
icon: 'mdi:track-light'
template: light
type: 'custom:button-card'
And my button template is as follows:
button_card_templates:
light:
template: base
state:
- value: 'on'
styles:
card: [border-color: var(--primary-yellow), border-width: 3px, box-shadow: var(--ha-card-box-shadow-inset)]
icon: [color: var(--primary-yellow)]
state: [color: var(--dark-primary-yellow)]
name: [color: var(--dark-primary-yellow)]
Possible causes:
- Card-mod is uninstalled
- You aren’t using the right styling code - make sure to choose the right style code based on your HA version
- You’re using the night theme during daytime. If you always use dark mode, just use that for the shadows.
Another self-promotion: if you use the theme(s) I made, the shadows should match the theme automatically…
