Lovelace Soft UI - Simple and Clean Lovelace Configuration
That an excellent question @KTibow !
Yes, i’ve past the wrong URL, you only need to install yours :wink:
https://github.com/KTibow/lovelace-light-soft-ui-theme/
Huge thanks for pointing me that error.
Just discovered this and trying to get it work. I want it to show the state of a sensor and act on the switch for that sensor. This is because i work with pushbuttons which dont remember state.
(Pushing is enabling the sensor).
So is it possible give my state part of the config a different entitiy?
If you declare a input_boolean object, and use automations with service call input_boolean.toggle, that don’t do the job?
Hey, you wanna share some code? I really love this setup, its perfect for me. :smiley:
Hi, I uploaded your interface following your repository, but as per attachment the Home assistant tells me that the card is not present. I state that if it refers to the Button Card or Card MOd or Soft UI they are all present on my system. Could the error refer to the fact that I have not changed entities?
Hi @claudiovillani58.
Did you copy the content of button_card_templates.yaml file to the main
On your main dashboard, on the left side, click on the 3 vertical dots > Panel Config > Edit Main Source Code
If should be something like this
Hello here I am again I took a few steps forward thanks to your suggestion now but I have this situation as you can see below what can it depend on?
Claudio, show us your first lines of lovelace yaml config
i hope i understood correctly i used your example attached in github. I am attaching the text file as I uploaded it to lovelace. All the tips reported in the github I have followed to the letter. Thanks for your patience
  - title: New
    path: new
    theme: Light Soft UI
    badges: []
    cards:
      - type: vertical-stack
        cards:
          - content: |
              # Garage
            style:
                ha-card {
                  --paper-card-background-color: none !important;
                  box-shadow: none !important;
              ha-markdown:
                  h1 {
                    font-size: 24px;
                    font-weight: normal;
                    font-family: Helvetica;
                    letter-spacing: '-0.01em';
                    text-align: center;
            type: markdown
          - type: horizontal-stack
            cards:
              - entity: switch.switch_portao
                template:
                  - main_style
                  - button
                type: 'custom:button-card'
                variables:
                  icon_on: 'mdi:garage-open'
                  icon_off: 'mdi:garage-variant'
                  message_on: Open
                  message_off: Close
                  color: var(--yellow)
              - entity: switch.switch_luz_quintal
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:lighthouse-on'
                  icon_off: 'mdi:lighthouse'
                  message_on: 'On'
                  message_off: 'Off'
            cards:
              - entity: switch.switch_luz_loja
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:lightbulb-on-outline'
                  icon_off: 'mdi:lightbulb-off'
                  message_on: 'On'
                  message_off: 'Off'
              - entity: sensor.temperatura_soutelo
                template:
                  - main_style
                  - temperature
                show_state: true
                show_label: true
                label: Temperature
                variables:
                  sensor_name: |
                    [[[  return states['sensor.humidade_soutelo'].state; ]]]
            cards:
              - entity: binary_sensor.movimento_garagem
                template:
                  - main_style
                  - sensor
                variables:
                  icon_on: 'mdi:motion-sensor'
                  icon_off: 'mdi:motion-sensor-off'
                  message_on: Detected!
                  message_off: 'Undetected '
                  color: var(--blue)
              - entity: binary_sensor.fogo
                template:
                  - main_style
                  - sensor
                variables:
                  icon_on: 'mdi:fire-alert'
                  icon_off: 'mdi:cloud-off-outline'
                  message_on: Fire !!!
                  message_off: Smoke Free
                  color: var(--red)
        cards:
          - content: |
              # Covers
            style:
                ha-card {
              ha-markdown:
                  h1 {
                    font-size: 24px;
                    text-align: center;
            type: markdown
            cards:
              - entity: cover.estore1
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
            cards:
              - entity: cover.estore2
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
              - entity: cover.estore3
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
            cards:
              - entity: cover.estore4
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
              - entity: cover.estore5
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
            cards:
              - entity: cover.estore6
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
              - entity: cover.estore7
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
            cards:
              - entity: cover.estore8
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
              - entity: cover.estore9
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
            cards:
              - entity: cover.estore10
                icon: 'mdi:blinds'
                template:
                  - main_style
                  - cover
        cards:
          - content: |
              # Water Controlls
            style:
                ha-card {
              ha-markdown:
                  h1 {
                    font-size: 24px;
                    text-align: center;
            type: markdown
            cards:
              - entity: input_boolean.input_b_agua_alterar
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:arrow-decision-auto-outline'
                  icon_off: 'mdi:arrow-decision-auto-outline'
                  message_on: 'Yes'
                  message_off: 'No'
              - entity: switch.switch_eletrov
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:fountain'
                  icon_off: 'mdi:home-circle-outline'
                  message_on: Borehole
                  message_off: Main grid
                  color: var(--blue)
            cards:
              - variables:
                  sensor_name: input_number.input_n_agua_dia_de_alterar
                  depends: input_boolean.input_b_agua_alterar
                icon: 'mdi:calendar'
                entity: input_number.input_n_agua_dia_de_alterar
                template:
                  - main_style
                  - number
        cards:
          - content: |
              # Corredor
            style:
                ha-card {
              ha-markdown:
                  h1 {
                    font-size: 24px;
                    text-align: center;
            type: markdown
            cards:
              - entity: switch.corredor_presenca
                template:
                  - main_style
                  - button
                variables:
                  message_on: Ghosts away
                  message_off: 'Off'
              - entity: sensor.temperatura_casa
                template:
                  - main_style
                  - temperature
                show_state: true
                show_label: true
                label: Termómetro
                variables:
                  sensor_name: |
                    [[[  return states['sensor.humidade_casa'].state; ]]]
      - cards:
          - content: |
              # Covers Automations
            style:
                ha-card {
              ha-markdown:
                  h1 {
                    font-size: 24px;
                    text-align: center;
            type: markdown
          - cards:
              - entity: input_boolean.input_b_estores_abrir
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:weather-sunset-up'
                  icon_off: 'mdi:weather-sunset-up'
                  message_on: Open at sunrise
                  message_off: Do not open
              - entity: input_boolean.input_b_estores_fechar
                template:
                  - main_style
                  - button
                variables:
                  icon_on: 'mdi:weather-sunset-down'
                  icon_off: 'mdi:weather-sunset-down'
                  message_on: Close at Sunset
                  message_off: Do not Close
                  color: var(--blue)
            cards:
              - variables:
                  sensor_name: input_datetime.input_dt_estores_abertura
                  depends: input_boolean.input_b_estores_abrir
                icon: 'mdi:clock'
                entity: input_datetime.input_dt_estores_abertura
                name: Time to<br/>Open Covers
                template:
                  - main_style
                  - time
              - variables:
                  sensor_name: input_number.input_n_estores_offset_fecho
                  depends: input_boolean.input_b_estores_fechar
                icon: 'mdi:ruler-square-compass'
                entity: input_number.input_n_estores_offset_fecho
                name: Sun height<br/>to close
                template:
                  - main_style
                  - number
Not a problem at all @claudiovillani58
There is your problem, you are missing some configurations.
If you go to my github, you will see a file called button_card_templates.yaml. That’s the file which contains all the css and script configurations.
You need to copy all content of that file to the file that you share with me,
At the end, this yaml lovelace file It should be something like this
button_card_templates:
  main_style:
    styles:
title: ....
My version in dark theme :slight_smile:
here is the file you are talking about that I have successfully uploaded to my home assistant and got it from your repository and it was updated for you about 8 days ago. In order not to make mistakes, I copied the RAW
  main_style:
    styles:
      img_cell:
        - padding-left: 25px
        - padding-bottom: 15px
        - justify-content: start
      card:
        - width: 'min(37vw, 170px)'
        - height: 'min(35vw, 150px)'
        - border-radius: 15px
        - border-style: solid
        - border-color: var(--primary-background-color)
        - background-color: var(--primary-background-color)
        - border-width: 2px
        - margin: 3px 20px 3px 3px
        - box-shadow: >
            [[[ return '-4px -4px 8px rgba(255, 255, 255, .5), 5px 5px 8px
            rgba(0, 0, 0, .09)' ]]]
        - font-family: 'Google Sans, Roboto'
        - font-weight: 500
      name:
        - justify-self: start
        - font-size: 18px
        - font-weight: 400
        - align-self: center
        - text-align: left
        - padding-left: 15px
        - opacity: 0.5
        - color: var(--primary-text-color)
      icon:
        - color: var(--primary-icon-color)
        - align-self: start
        - opacity: 0.5
      state:
        - font-weight: normal
        - font-size: 14px
        - opacity: 0.6
        - padding: 0 15px 5px
        - opacity: 0.5
      label:
        - font-size: 14px
        - opacity: 0.6
        - opacity: 0.5
  cover:
    show_label: true;
    show_state: false
    variables:
      sensor_name: ' '
    label: |
      [[[ return (states[entity.entity_id].attributes.current_position)+'%' ]]]
    hold_action:
      action: more-info
    tap_action:
      action: none
    styles:
      grid:
        - grid-template-areas: '"i top" "i center" "n bottom" "l l"'
        - grid-template-rows: 1fr 1fr 1fr min-content
        - grid-template-columns: 2fr 1fr
    custom_fields:
      top:
        card:
          entity: null
          icon: 'mdi:arrow-up-circle-outline'
          template: botao2
          tap_action:
            action: call-service
            service: cover.open_cover
            service_data:
              entity_id: '[[[ return entity.entity_id ]]]'
      bottom:
        card:
          entity: null
          icon: 'mdi:arrow-down-circle-outline'
          template: botao2
          tap_action:
            service: cover.close_cover
            service_data:
      center:
        card:
          entity: null
          icon: 'mdi:stop-circle-outline'
          template: botao2
          tap_action:
            service: cover.stop_cover
            service_data:
  time:
    variables:
      sensor_name: ' '
      depends: ' '
    show_label: true;
    show_state: false
    state:
      - styles:
          card:
            - border-width: 2px
            - box-shadow: >
                [[[ return 'inset -3px -3px 5px rgba(255, 255, 255), inset 3px
                3px 5px rgba(0, 0, 0, .08)'  ]]]
            - border-color: '#f7bf42'
          icon:
            - color: '#f7bf42'
            - opacity: 1
          name:
            - color: '#e2ad37'
              opacity: 1
          label:
            - color: '#e2ad37'
              opacity: 1
        value: |
            if( variables.depends !== ' '){
              if( states[variables.depends].state == 'on' )
                  return entity.state;
                else
                  return "Fechado";
            else
             return "fechado";
    label: |
      [[[ return states[variables.sensor_name].state ]]]
    hold_action:
      action: none
    tap_action:
      action: more-info
    styles:
      grid:
  number:
    variables:
      sensor_name: ' '
      depends: ' '
    show_label: true;
    show_state: false
    state:
      - styles:
          card:
            - border-width: 2px
            - box-shadow: >
          icon:
            - color: '#f7bf42'
            - opacity: 1
          name:
            - color: '#e2ad37'
              opacity: 1
          label:
            - color: '#e2ad37'
              opacity: 1
        value: |
                else
                  return "Fechado";
            else
             return "fechado";
    label: |
      [[[ return Math.trunc(states[variables.sensor_name].state) ]]]
    hold_action:
      action: more-info
    tap_action:
      action: none
    styles:
      grid:
    custom_fields:
      top:
        card:
          entity: null
          template: botao2
          tap_action:
            service: input_number.increment
            service_data:
              entity_id: '[[[ return variables.sensor_name ]]]'
      bottom:
        card:
          entity: null
          template: botao2
          tap_action:
            service: input_number.decrement
            service_data:
  botao_extendido:
    state:
      - value: 'on'
        operator: ==
        styles:
          card:
            - box-shadow: |
                [[[ return states['sun.sun'].state == 'below_horizon'
                  ? 'inset -4px -4px 5px rgba(60, 60, 60, .6), inset 4px 4px 5px rgba(0, 0, 0, .5)'
                  : 'inset -3px -3px 5px rgba(255, 255, 255), inset 3px 3px 5px rgba(0, 0, 0, .08)';
          icon:
            - color: var(--paper-item-icon-active-color)
    styles:
      card:
        - width: 80px
        - height: 80px
        - margin: 10px
        - box-shadow: |
              ? '-5px -5px 10px rgba(50, 50, 50, .2), 6px 6px 10px rgba(0, 0, 0, .08)'
              : '-5px -5px 8px rgba(255, 255, 255, .5), 5px 5px 8px rgba(0, 0, 0, .03)';
      tap_action:
        action: toggle
        haptic: light
      hold_action:
        action: more-info
        haptic: medium
  botao2:
    show_icon: true
    show_name: false
    styles:
      card:
        - width: 30px
        - height: 30px
        - margin: 5px
        - border-radius: 20px
        - box-shadow: >
            rgba(0, 0, 0, .03)'; ]]]
      icon:
        - color: '#b473f5'
          opacity: 1
    variables:
      icon_on: ' '
      icon_off: ' '
      message_on: ' '
      message_off: ' '
      color: ' '
    hold_action:
      action: more-info
    show_label: true
    show_state: false
    state:
      - value: 'on'
        label: '[[[ return variables.message_on ]]]'
        icon: '[[[ return variables.icon_on ]]]'
        styles:
          card:
            - border-width: 2px
            - box-shadow: >
            - border-color: '[[[ return variables.color ]]]'
          icon:
            - color: '[[[ return variables.color ]]]'
            - opacity: 1
          name:
              opacity: 1
          label:
              opacity: 1
      - value: 'off'
        label: '[[[ return variables.message_off ]]]'
        icon: '[[[ return variables.icon_off ]]]'
    styles:
      card:
        - height: 'min(30vw, 90px)'
      grid:
        - grid-template-areas: '"n i" "n i" "l i" '
  temperature:
    variables:
      sensor_name: ' '
    state:
      - value: 18
        icon: 'mdi:thermometer-low'
        operator: <
        styles:
          card:
            - border-color: '#59bde2'
            - color: '#59bde2'
            - opacity: 1
          icon:
            - color: '#59bde2'
          state:
            - color: '#59bde2'
      - value: 27
        icon: 'mdi:thermometer'
        operator: <
        styles:
          card:
            - border-color: '#f79a0e'
            - color: '#f79a0e'
            - opacity: 1
          icon:
            - color: '#f79a0e'
          state:
            - color: '#f79a0e'
      - value: 70
        icon: 'mdi:thermometer-high'
        operator: <
        styles:
          card:
            - border-color: '#ec3967'
            - color: '#ec3967'
            - opacity: 1
          icon:
            - color: '#ec3967'
          state:
            - color: '#ec3967'
    custom_fields:
      teste: |
          return `<ha-icon
            icon="mdi:water-percent"
            style="width: 17px; height: 17px;">
            </ha-icon>${variables.sensor_name}%`
    styles:
      custom_fields:
        teste:
          - justify-self: right
          - font-size: 16px
          - opacity: 0.6
          - padding-right: 5px
          - padding-bottom: 20px
      card:
        - box-shadow: >
            [[[ return 'inset -3px -3px 5px rgba(255, 255, 255, .65), inset 3px
            3px 5px rgba(0, 0, 0, .2)' ]]]
      icon:
        - opacity: 1
      grid:
        - grid-template-areas: '"i s" "i teste" "n n" "l l"'
        - grid-template-columns: 1fr 1fr
        - grid-template-rows: 1fr 1fr min-content min-content
      state:
        - font-size: 18px
        - font-weight: 400
        - opacity: 1
        - align-self: flex-end
      label:
        - font-size: 14px
        - opacity: 0.6
  button:
    tap_action:
      action: toggle
    hold_action:
      action: more-info
    styles:
      grid:
        - grid-template-areas: '"i" "n" "s" "l"'
        - grid-template-rows: 1fr min-content min-content min-content
    variables:
      icon_on: ' '
      icon_off: ' '
      message_on: ' '
      message_off: ' '
      color: ' '
    show_label: true
    show_state: false
    state:
      - value: 'on'
        styles:
          card:
            - border-width: 2px
            - box-shadow: >
          icon:
            - opacity: 1
          name:
              opacity: 1
          label:
              opacity: 1
      - value: 'off'
OK… and is not working yet?
It should…
unfortunately no I have also restarted home assistant. the image I have is always this.
Where did you place the file?
What is the raw config of your HA dashboard?
Hello
Thank you for this awesome theme, but i have a question. I only want to use the dark theme, but when i do, eveytime the sun is above the horizon i get a white shadow behind the buttons, i guess its for the light theme. Do anyone know what im suppose to change to get it to work with only dark mode, and remove the sun.sun theming.
Great and clean! Good work!
But, I seem to have missed something…
The spacing between all is huge… Looking at others UI there are different
Much more narrowed than mine…
Any ideas how to fix the spacing?
It’s the theme. You could just remove the block of code with “card-mod” in it. It’s not meant to be designed for horizontal stacks.
Would you like to beta test a simpler version of Dark Soft UI? By default it’s purple, but I can change it. The reason behind this is even I don’t understand all of the card-mod CSS in my themes, and also now it’s possible to globally apply the simplest styles:
# Example entry
style: |
  ha-card {
      background-color: var(--primary-background-color);
      border-radius: 15px;
      margin: 10px;
      box-shadow:
        {% if is_state('sun.sun', 'above_horizon') %}
          -4px -4px 8px rgba(255, 255, 255, .5), 5px 5px 8px rgba(0, 0, 0, .03);
        {% elif is_state('sun.sun', 'below_horizon') %}
          -5px -5px 8px rgba(50, 50, 50, .2), 5px 5px 8px rgba(0, 0, 0, .08);
        {% endif %}
without using card-mod at all.
Here it is:
Dark:
  # Backgrounds
  primary-background-color: "#313238"
  card-background-color: var(--primary-background-color)
  paper-card-background-color: var(--primary-background-color)
  secondary-background-color: var(--primary-background-color)
  divider-color: var(--primary-background-color)
  # Colors
  primary-text-color: "#FFFFFF"
  primary-color: "#6960EB"
  # Cards
  ha-card-border-radius: 15px
  ha-card-box-shadow: -5px -5px 8px rgba(50, 50, 50, .2), 5px 5px 8px rgba(0, 0, 0, .08)
  ha-card-inset-box-shadow: inset -5px -5px 8px rgba(50, 50, 50, .2), inset 5px 5px 8px rgba(0, 0, 0, .08)
  masonry-view-card-margin: 20px
  # Header
  app-header-background-color: var(--primary-background-color)
  app-header-text-color: var(--primary-text-color)
  paper-tabs-selection-bar-color: var(--primary-text-color)
  # Sidebar
  sidebar-icon-color: var(--primary-text-color)
  sidebar-text-color: var(--primary-text-color)
  sidebar-selected-icon-color: var(--primary-color)
  sidebar-selected-text-color: var(--primary-color)
  sidebar-background-color: var(--primary-background-color)
  sidebar-selected-background-color: var(--primary-background-color)
  # More colors
  success-color: "#60eb80"
  accent-color: "#eb9560"
  #paper-item-icon-active-color: "#ebe660"
  #paper-item-icon-color: "#607eeb"
  #state-color: var(--paper-item-icon-color)
  label-badge-red: "#eb7360"
  label-badge-blue: var(--success-color)
Thanks for your reply, ive tried to remove the card code but the the “button” dosnt inset when i click it. Its just a static button style.
That was for @Minglarn. Please post an example of your code.
