It’s Simple weather card
Okay, thank you! I found a style configuration, that I was looking for, a few posts ago
Nice job @N-l1
I’m testing this card configuration, but I’m having some problems when I edit the cards. It seems that the browser is constantly reloading and I have this error in the log:
Client exceeded max pending messages [2]: 512
Does anyone have this kind of problems?
Thanks @Joca,
I’m not getting any error in my log. Do you have any other custom cards? Found something similar on GitHub…
Thanks.
I installed hacs and custom cards for the first time.
I have these cards installed:
There must be some problem with installing the cards. I tried to add just one card and I couldn’t.
Yes I do.
Please add your experience to the GitHub referenced above. It is getting some attention but the more reports the more likely there will be a fix.
Ok.
I found another similar report on GitHub:
Hello !
I also have the problem with the websockets and will also add my report on Github as well.
However I have another problem with this theme: when the HA theme is switching from light to dark, the templates that compute the shadows does not trigger instantly and for some minutes (like half an hour sometimes), I have this kind of things…
Do somebody have the same problems and/or know how to solve it ?
Thank you !
I have the same problem as well, the shadows don’t switch instantly. I was wondering if the styling template only updates at a certain interval But Wow, 30 minutes is a long time. Mine goes for only 2/3 minutes which doesn’t bother me so much. Would love to hear other’s thoughts as well…
I noticed the same. I also noticed the shadows are flickering.
If you’re using button card for this setup, I advise you to check the documents. There has been some major changes as to how the card is being updated.
Changed with release 3.3.1 > https://github.com/custom-cards/button-card/releases
Not sure if this is the case (I don’t use your stying myself) but might be worth to check it
No it’s not only on the custom button card, it’s on every card where we are using card-mod to put some styling. The template to change the shadows is a Jinja template from HA.
I’ll try a workaround today to see if it’s working : creating a template sensor with the shadow template and in the entity field used for the update “sun.sun”. Then in Lovelace using the state of this new sensor in every card. I think it could do the job !
I don’t use your theme but my setup is based on similar neomorphism styling on buttons and other elements, I change the shadow colours by adding them as custom lines to the theme then reference in the card-mod styles, colours change instantly with the theme, hope this helps.
style: |
ha-card {
border-radius: 20px;
box-shadow: -8px -8px 8px 0 var(--box-shadow-top),8px 8px 8px 0 var(--box-shadow-bottom);
Hi @N-l1
Thanks for this card.
So I followed your readme for the remote pop-up card and copied your code and altered it to mine. However when I long press my switch.tv entity which I have set it to pop up the remove pop up card, I dont see the pop.
Can you help please?
@Frixx, @BradAU Those are all great ideas! Can’t wait to try them
Hi @bachoo786,
Just tested it and mine still works. Make sure you have browser-mod installed, and also make sure you have setup the button card to more-info when hold:
hold_action:
action: more-info
where do I add this? this was a little confusing
Just add it inside the button card of your TV entity
For example:
- entity: light.family_room_lamp
icon: 'mdi:lamp'
show_icon: true
show_name: false
state:
- styles:
icon:
- color: 'var(--paper-item-icon-active-color) '
value: 'on'
style: |
ha-card {
box-shadow:
{% if is_state('sun.sun', 'above_horizon') and is_state('light.family_room_lamp', 'on') %}
inset -4px -4px 8px 0 rgba(255,255,255,.5), inset 4px 4px 8px 0 rgba(0,0,0,.03);
{% elif is_state('sun.sun', 'above_horizon') and is_state('light.family_room_lamp', 'off') %}
-8px -8px 8px 0 rgba(255,255,255,.5),8px 8px 8px 0 rgba(0,0,0,.03);
{% elif is_state('sun.sun', 'below_horizon') and is_state('light.family_room_lamp', 'on') %}
inset -4px -4px 10px 0 rgba(50, 50, 50,.5), inset 4px 4px 12px 0 rgba(0,0,0,.3);
{% elif is_state('sun.sun', 'below_horizon') and is_state('light.family_room_lamp', 'off') %}
-5px -5px 8px 0 rgba(50, 50, 50,.5),5px 5px 8px 0 rgba(0,0,0,.15);
{% endif %}
styles:
card:
- width: 60px
- height: 60px
- border-radius: 15px
- background-color: var(--primary-background-color)
icon:
- color: var(--primary-text-color)
tap_action:
action: toggle
haptic: light
##### You should add it here ####
hold_action:
action: more-info
type: 'custom:button-card'
I created a button card for my TV. And have put the hold action there but it doesn’t work for me. Here is me trying to access the remote card.
I see. Please make sure you have browser-mod installed, and the popup code is inside the raw configuration.
I have installed browser-mod and the popup code in my raw configuration.
Are you saying to add
hold_action:
action: more-info
in my raw configuration in the code you provided i.e. where my switch.tv entity is?
