Hey guys,
I created an update-chip that shows you if a new update is available. It also supports the language - templates.
Usage
- type: custom:button-card
template: chip_update
entity: group.updates
variables:
ulm_chip_update_path: '/ui-lovelace-minimalist/system'
Template code
### Chip Update ###
chip_update:
template:
- "ulm_language_variables"
- "chips"
tap_action:
action: navigate
navigation_path: "[[[ return variables.ulm_chip_update_path; ]]]"
haptic: light
show_icon: true
state:
- operator: default
color: red
icon: mdi:shield-alert
label: "[[[ return variables.ulm_updates_available ]]]"
- value: 'off'
color: green
icon: mdi:shield-check
label: "[[[ return variables.ulm_no_updates_available ]]]"
styles:
grid:
- grid-template-areas: "'i l'"
Still no go. I have created another instance of home assistant as a dev environment in a different virtual machine Copy everything like you have posted and still not working for me. Will keep looking to see where Iām wrong. Maybe Iām missing and custom card or a lovelace element that Iām over seeing. Thank you for all of your time and help.
benm7
(Ben M)
June 2, 2022, 11:04pm
2256
Are pop ups working ok for everyone? Just canāt get them to work and have checked code and integrations many times!!
Neekster
(Nathan K)
June 3, 2022, 1:08am
2257
Make sure youāve added
browser_mod:
to your configuration.yaml file. More info can be found here.
benm7
(Ben M)
June 3, 2022, 2:26am
2258
I do have browser_mod configured but I also have ādisable: allā in the config to stop all those entities being created. Perhaps that could be my issue!?!?
Neekster
(Nathan K)
June 3, 2022, 3:34am
2259
I canāt be sure that that is your issue, but it would make sense that it could be. Try removing it from your config, restarting HA, and checking to see if the problem is fixed.
benm7
(Ben M)
June 3, 2022, 3:49am
2260
Nope, that wasnāt it will keep trying, thanks anyway!
benm7
(Ben M)
June 3, 2022, 5:45am
2261
Resolved! Had ticked the āinclude custom cardsā option which was trying to load resources twice and causing the issue. All sorted, thanks again!
Hi, hope anybody can help me out, feeling stupid. I tried in different ways to change the icons (the 4 at right side) of the card-room, but no change is working. Where and how i need to change the config to adjust the entity_1 to a different icon, i donĀ“t want the default from the template. The icon value for the big icon is working, but for entity_1 or any sub (here āicon: mdi:ceiling-lightā) itĀ“s not changing anything:
- type: horizontal-stack
cards:
- type: "custom:button-card"
template:
- card_room
- blue_no_state
label: '[[[ return["š”ļø"] + states["sensor.sensor_wohnzimmer_temperature"].state +"°C š§"+states["sensor.sensor_wohnzimmer_humidity"].state + "%"]]]'
styles:
label:
- font-size: 14px
name:
- font-size: 14px
entity: light.yeelight_ceiling3_0x0000000005ec8cd8
icon: mdi:home
tap_action:
action: navigate
navigation_path: "wohnzimmer"
variables:
label_use_temperature: false
label_use_brightness: true
entity_1:
entity_id: light.yeelight_ceiling3_0x0000000005ec8cd8
templates:
- yellow_on
tap_action:
action: toggle
Gilganik
(Nik)
June 3, 2022, 6:44am
2263
Send me the whole code thatās not working
You can set the entity icon in the customize.yaml file for room cards.
Thank you for this great config.
I am using HA mainly on desktop and noticed something odd with the font alignment.
Can you think of a solution?
benm7
(Ben M)
June 3, 2022, 8:04am
2266
It would have to do with the padding on the top and bottom of the name and label fields. Play around with those numbers and you should get it to align to your liking I think!
Hi Gilganik, here is the full yaml, i stripped it of further rooms, cause in no card it“s working for me now. In this sample just entity_1 shouldn“t use the default mdi bulb icon, instead i want use the icon: mdi:ceiling-light
title: "Home"
path: "home"
cards:
template: "card_esh_welcome"
triggers_update: "input_boolean.minimalist_dropdown"
variables:
ulm_card_esh_welcome_collapse: input_boolean.minimalist_dropdown
ulm_weather: "weather.home"
entity_1:
nav: "wohnzimmer"
icon: "mdi:home"
color: "blue"
entity_2:
nav: "schlafzimmer"
icon: "mdi:bed"
color: "yellow"
entity_3:
nav: "kueche"
icon: "mdi:fridge"
color: "green"
entity_4:
nav: "arbeitszimmer"
icon: "mdi:laptop"
color: "purple"
entity_5:
nav: "bad"
icon: "mdi:shower-head"
color: "red"
cards:
template: card_person
styles:
icon:
- color: "rgba(var(--color-theme),0.9)"
- width: 42px
- place-self: center
entity_picture: /local/img/YXZ.png
variables:
ulm_card_person_entity: person. YXZ
ulm_card_person_use_entity_picture: false
variables:
ulm_card_person_entity: person.YXZ2
ulm_card_person_use_entity_picture: true
template: card_title
cards:
template:
- card_room
- blue_no_state
styles:
label:
- font-size: 14px
name:
- font-size: 14px
icon: mdi:home
tap_action:
action: navigate
variables:
entity_1:
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
icon: mdi:bed
entity_id: binary_sensor.motion_sensor_01_occupancy
templates:
- blue_on
tap_action:
action: none
entity_3:
entity_id: input_boolean.manuell_wohnzimmer_boolean_var
templates:
- green_off
- red_on
tap_action:
action: toggle
entity_4:
entity_id: climate.heizungen_wohnzimmer
templates:
- green_off
tap_action:
action: toggle
template:
- card_room
- red_no_state
label: '[[[ return["š”ļø"] + states["sensor.bad_thermostat_temperatur"].state ]]]'
styles:
label:
- font-size: 14px
name:
- font-size: 14px
entity: light.badlicht
icon: mdi:shower-head
tap_action:
action: navigate
navigation_path: "bad"
variables:
entity_1:
entity_id: light.badlicht
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
entity_id: binary_sensor.motion_sensor_03_occupancy
templates:
- blue_on
tap_action:
action: none
entity_3:
entity_id: input_boolean.manuell_bad_boolean_var
templates:
- green_off
- red_on
tap_action:
action: toggle
entity_4:
entity_id: climate.bad_thermostat
templates:
- green_off
tap_action:
action: toggle
Neekster
(Nathan K)
June 3, 2022, 1:22pm
2268
Glad you figured it out! That was actually the culprit of some of my issues with the mini graph card a few months back. Seems to be a common issue.
Gilganik
(Nik)
June 4, 2022, 9:26am
2270
from what I can see the code is correct. try to check into this page: Installation - UI Lovelace Minimalist (Included lovelace resources)
what you have all the custom cards installed
Started today exploring the possibilities of Minimalist UI: This is awesome! I made a (wall mounted) tablet UI
he nice dashboard & how did you make that popup card from buiradar?
Iāve an issue where none of the colors within the cards are displaying. Any ideas?
Neekster
(Nathan K)
June 5, 2022, 2:19am
2274
Make sure you have selected the correct theme. Also, give HA a restart and try pressing Ctrl + F5 to completely refresh the page and clear cache.
