šŸŒ» Lovelace UI ā€¢ Minimalist
Depending on what you have, you can use templates for that as well. Templates from button-card (thatā€™s what this is basically about) can be inherited from other templates. So what you need in the end, is a template like my_chips that inherit from the default chips.
Like this:
first_page_chips ā†’ inherits from my_chips ā†’ inherits from chips. :slight_smile:
hello @clemalex
i have trouble to get the same cool alarm panel like your picture. Check mine below.
Did copy your code and changed some few lines, can you see what i have missed?
  - title: Alarm
    icon: 'mdi:security'
    path: alarm
    cards:
      - cards:
          - cards:
              - template: edge
                type: 'custom:button-card'
              - template: chips_return
              - template: chips_power_consumption_price
              - template: edge
            type: horizontal-stack
          - type: vertical-stack
            cards:
              - card:
                  entity: alarm_control_panel.alarm
                  states:
                    - arm_home
                  style:
                      ha-card > ha-label-badge{
                        --alarm-state-color: var(--google-green-500) !important;
                      ha-card{
                        padding-top: 16px;
                        padding-bottom: 12px !important;
                        border-radius: 21px;
                      ha-card > h1{
                        padding-top: 0;
                        color: transparent;
                      ha-card > h1::before{
                        content: "Larma av";
                        color: var(--google-green-500);
                        position: absolute;
                        font-variant: small-caps;
                      #alarmCode{
                        display: none;
                      #keypad{
                        display: none !important;
                    '#armActions':
                      mwc-button:
                          #button > span.slot-container{
                            color: transparent;
                            position: absolute;
                          #button{
                            width: 150px;
                          #button > span.slot-container::before{
                            color: var(--mdc-theme-primary, #6200ee);
                            content: "Aktivera";
                            margin: 0 0 0 50%;
                  title: Alarme
                  type: alarm-panel
                conditions:
                  - entity: alarm_control_panel.alarm
                    state: disarmed
                type: conditional
              - card:
                  states:
                    - armed_home
                  title: Alarm
                  type: alarm-panel
                  style:
                        --alarm-state-color: var(--google-red-500) !important;
                      ha-card{
                        padding-top: 16px;
                      ha-card > h1{
                        padding-top: 0;
                        color: transparent;
                        content: "ActivƩe";
                        color: var(--google-red-500);
                        position: absolute;
                    '#armActions':
                      mwc-button:
                            color: transparent;
                            position: absolute;
                          #button{
                            width: 150px;
                            margin: 0 0 0 50%;
                    '#keypad':
                      mwc-button:
                          #button{
                            border-radius: 12px
                conditions:
                    state_not: disarmed
                type: conditional
Found out the error but not sure how i could fix it no other way than remove -500 from color part.
Oh! :roll_eyes:
ofcourse, add it to theme template
Can someone explain how-to setup Scene part. Not sure how-to create this sensors
sensor.presence
sensor.absent
sensor.travail
The colors have changed. Yes it is necessary to correct then
I cannot find the rest of the code for the media-player button. Can you share?
Found all now but how to setup card correct, mine does not look like your picture
                    - entity: media_player.kok
                      template:
                        - icon_info_bg
                        - media_buttons
Why would you say that? That template seems fine?
Iā€™m interested in that, too. I always use the option without curly brackets and it works as desired. What is the advantage of Paddyā€™s solutions?
Itā€™s not because of the brackets, itā€™s the logic behind. :slight_smile:
With this version, there are three if-statements, and the last one overwrites the previous two.
if (entity.state == 'hjemme') return 'šŸ ';
This one checks, if the state is ā€œhjemmeā€. If it is, the icon will be set.
The next line does the same, but independent from the first.
The third line is another if-statement, that answers the question, is the state ā€œferieā€, if not, show the burnng icon. It is run totally indepent of the statements before. So every state, that is not ā€œferieā€ shows the burning icon, no matter the two statements before.
To sum it up, the first two if-statements are totally ignored, the only one that is shown in the end is the third one, and that checks only, if the state is ā€œferieā€. Nothing else. :slight_smile:
I hope this is understandably explained, if not, please ask again. :slight_smile:
EDIT: This is exactly, why I use the curly brackets. Short hand code writing is easy, but it hides the logic a little bit. With the brackets it is easy to see, that the three statements donā€™t belong together and therefor donā€™t work together.
Maybe Iā€™m blind, but isnā€™t this the same logic? (from my covers template)
      label: |
          if (entity.attributes.current_position == 100) return 'vollstƤndig geƶffnet';
          if (entity.attributes.current_position == 0) return 'vollstƤndig geschlossen';
          if (entity.attributes.current_position <= 20) return 'geschlossen';
          else return entity.attributes.current_position + '% geƶffnet';
It always works as defined.
Youā€™re totally right, my bad, Iā€™m sorry! :flushed:
The ā€œreturnā€ leaves the actual function and therefor the next statements arenā€™t run. insert-the-head-banging-smilie-here Sorry for the confusion, seems Iā€™m not awake enoughā€¦ Iā€™ll go and repair my car now, before I post other nonsenseā€¦ Sorry, really! :slight_smile:
Iā€™ll make a note at the code above. :slight_smile:
Not referring to the brackets.
Not sure why you think it does what you state here, but itā€™s not the fact.
Upon each state change the template
is evaluated.
The template will be fine as is. For reference you can see the many templates I show in my examples for custom-ui
Btw: the ā€˜elseā€™ is not even required :wink: a simple ā€˜returnā€™ suffices in the last line
Everythingā€™s fine! I just wondered if there was a better way :slightly_smiling_face: :heart:
Totally right. I use it only for clarity purposes and so that my dumb head still knows later what I wanted to express with it. :crazy_face:
As I said in the post above, my bad, Iā€™m sorry for the confusion! :slight_smile:
- type: 'custom:button-card'
  variables:
    entity: media_player.living_room
    template: media_buttons
This actually works here :slight_smile:
Need some help to making the header generic.
I have made a my_chips template and added this to my frontpage yaml:
      - cards:
          - template: my_chips
Then I have made this and added it to the button_card_template.yaml:
  my_chips:
    - template: edge
    - template: chips_temperature
    - template: chips
      tap_action:
        action: navigate
        navigation_path: '/lovelace-yaml2/lys/'
      label: |
            var antall = states['sensor.lights_on_counter'].state;
            return 'šŸ’”' + antall ;
    - template: chips
      label: "šŸ›’"
      tap_action:
        action: navigate
        navigation_path: '/lovelace-yaml2/handleliste/'
    - template: chips
      label: "šŸ§¹"
      tap_action:
        action: navigate
        navigation_path: '/lovelace-yaml2/vaskeoversikt/'
    - template: edge
the result:
just a white line. What im a missing?:slight_smile:
      - cards:
You are defining a button card and passing a list of cards to it.
So I think this wont work no matter what ā€¦
Thatā€™s also why youā€™re seeing one big white card
But I dont actually know how to fix it :confused:
Try and follow the configuration options from button-card: here
Ps: Nice background :smiley:
@paddy0174
Can you post the configuration of your inheritance, if possible? :slight_smile:
yeah was afraid of that, maybe I can use the !include function.
Thanks, I have stole it from someone else in this topic:)
What do you mean whit inheritance? :slight_smile:
