Just login on your PC into your Tesla Account. There you will see your cars linked to that account. And you can just right click on it and download it
do you know if its possible to pop up a card after a tap not related to Minimalist UI? My goal is to open LG WebOS Remote Control after tapping on card_media_player on Name action.
Thank you
I donât manage to get the * Waste Collection Custom-card working correctly: the dot with the exclamation mark is behind the icon instead of in front of it.
Iâve read the styling guide documentation of the custom button card but must admit that it is way above my (very limited!) yaml code skills.
The custom_card_paddy_waste_collection.yaml looks like this:
custom_card_paddy_waste_collection:
template:
- "card_generic_swap"
state:
- operator: "template"
value: "[[[ return states[entity.entity_id].attributes.daysTo == 0; ]]]"
styles:
custom_fields:
notification:
- border-radius: "50%"
- position: "absolute"
- left: "38px"
- top: "8px"
- height: "16px"
- width: "16px"
- border: "2px solid var(--card-background-color)"
- font-size: "12px"
- line-height: "14px"
- background-color: >
return "rgba(var(--color-red),1)";
value: "[[[ return states[entity.entity_id].attributes.daysTo == 1; ]]]"
styles:
custom_fields:
notification:
- left: "38px"
- top: "8px"
- height: "16px"
- width: "16px"
- font-size: "12px"
- value: "unavailable"
styles:
custom_fields:
notification:
- left: "38px"
- top: "8px"
- height: "16px"
- width: "16px"
- font-size: "12px"
custom_fields:
item1:
card:
type: "custom:button-card"
template:
- "icon_more_info"
custom_fields:
item1:
card:
entity: "[[[ return entity.entity_id ]]]"
state:
styles:
img_cell:
- background-color: "rgba(var(--color-red),0.5)"
icon:
- color: "rgba(var(--color-red),1)"
styles:
img_cell:
- background-color: "rgba(var(--color-red),0.05)"
icon:
item2:
card:
notification: >
if (entity.state == 'unavailable' || states[entity.entity_id].attributes.daysTo == 0 || states[entity.entity_id].attributes.daysTo == 1){
return '<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: var(--primary-background-color);"></ha-icon>'
My home.yaml looks like this:
title: "Home"
path: "home"
cards:
- type: custom:button-card
template:
- custom_card_paddy_waste_collection
entity: sensor.next_residual_waste_collection
variables:
ulm_icon_tap_action: "more-info"
template:
entity: sensor.next_paper_carton_collection
variables:
template:
entity: sensor.next_glass_collection
variables:
template:
entity: sensor.next_valorlux_collection
variables:
and my configuration.yaml looks like this:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include_dir_merge_list sensors
waste_collection_schedule:
sources:
- name: ics
args:
url: https://www.vdl.lu/fr/vivre/domicile-au-quotidien/collecter-et-trier-ses-dechets/calendrier-des-collectes-new/1/all/ical.ics # this is just an example url
#file: FILE
#offset: OFFSET
#method: METHOD
#params: PARAMS
#year_field: YEAR_FIELD
#regex: REGEX
#split_at: SPLIT_AT
#version: 2
#verify_ssl: VERIFY_SSL
#headers: HEADERS
customize:
- type: Déchets résiduels
alias: Residual waste
icon: mdi:delete-empty
- type: Emballages Valorlux
alias: Valorlux
icon: mdi:sack
- type: Papier/Carton
alias: Paper & Carton
icon: mdi:package-variant-remove
- type: Verre
alias: Glass
icon: mdi:liquor
- type: Déchets alimentaires
show: false
hi, this is very beautiful! But, how you can send the commands to tesla model y? With teslamate?
Iâm using the custom Tesla integration inside HACS GitHub - alandtse/tesla: Tesla custom integration for Home Assistant. This requires a refresh token be generated by third-party apps to login.
i have some issues:
Logger: custom_components.ui_lovelace_minimalist.base
Source: custom_components/ui_lovelace_minimalist/base.py:333
Integration: UI Lovelace Minimalist (documentation, issues)
First occurred: 9:45:11 AM (11 occurrences)
Last logged: 9:45:11 AM
- HACS Frontend repo âmy-cardsâ is already installed, Remove it or disable include custom cards
- HACS Frontend repo âsimple-weather-cardâ is already installed, Remove it or disable include custom cards
- HACS Frontend repo âlovelace-layout-cardâ is already installed, Remove it or disable include custom cards
- HACS Frontend repo âlovelace-state-switchâ is already installed, Remove it or disable include custom cards
- HACS Frontend repo âweather-radar-cardâ is already installed, Remove it or disable include custom cards
if i take them out from ressources:
- url: /hacsfiles/my-cards/my-cards.js
type: module
it dont work.
Is this project still being maintained? It has been a while since any pull requested has been approved.
Sorry for the beginner question, Iâm just starting.
What card did you use to manage this?
this is my own card, if i am ready. i share the code
Nobody knows how to incorporate this in Minimalist UI ?
It looks amazing!
You have manually installed all HACS frontend repos and let Minimalist also install them. So it warns you of duplicate files in different locations.
Either deselect the option to let Minimalist install all needed repos or deinstall all manually installed items from HACS, not by just deleting the resource link.
Note: This is exactly what the error in the log describes ![]()
perfect, it works
Itâs pretty straight forward. Just add the card template (that he provided) to your dashboard. Just make sure you format it correctly for your dashboard. For the Days to Reminder to work, you will also need to add script to reset the reminder by adding the code he provided to your scripts.yaml. Then you need to create a helper (input_datetime.reminder_date) so you set a date for the reminder. Once you have all that you should be good to go.
where is the code? can you make a pull request?
I installed all the cards that were listed as dependencies and then installed the integration (after adding it by HACS)
Two dashboards were added to my sidebar both with same name of âUI Lovelace Minimalistâ. The dashboards donât look at all correct with misrendered cards. I swear Iâve looked at the setup instructions and followed all the steps.
Any ideas?
You must select a minimalist-* theme in user settings
