Sorry I literally just found it hiding underneath that little dropdown.
Im stil getting the error.
Just to confirm, it goes in
button_card_templates >> card_room.yaml
My usage.
type: custom:button-card
template:
- card_room
- red_no_state
entity: light.bathroom
icon: mdi:shower-head
tap_action:
action: navigate
navigation_path: /ui-lovelace-minimalist/bathroom
variables:
label_use_temperature: false
label_use_brightness: true
entity_1:
entity_id: light.bathroom
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
entity_id: binary_sensor.badkamer_motion_sensor
templates:
- blue_on
tap_action:
action: none
entity_3:
entity_id: input_boolean.badkamer_motionsensor_enabled
templates:
- green_on
- red_off
tap_action:
action: toggle
entity_4:
entity_id: input_boolean.bath_mode
templates:
- pink_on
tap_action:
action: toggle
This is stupid. I get frustraded when simple things dont work. Got to be honest been going at this now for 4 days.
I used to see that opccassionally. It clearly says the file is missing. I just went into that HACS card and re-download it, then all is well
done that 3 times
Maybe compoletely uninstall, reboot, then reinstall it from hacs?
Can you share the full dashboard yaml. That would give us some more insight in why the template is not found.
aparently this was the issue, as i’m still getting the errors, anyone have any ideas ?
I have a problem with some custom cards (nas summary, apex-charts and bar cards). When I add them to my dashboard they don’t appear when I’m in the browser and in the mobile app it’s like the dashboard crashes (blank screen then HA logo then blank screen again). No error in console.
Does anyone have the same problem?
finally found the issue with my dashboard, it was a bug in button-card
, it has been fixed in latest dev version here fix(templates): `variables` was `undefined` if none where provided. · custom-cards/button-card@fad332b · GitHub
Sure, here you go.
- title: Home
cards:
- type: button
entity: switch.a8_light1
icon: mdi:sofa-outline
hold_action:
action: toggle
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
browser_id: THIS
dismissable: true
content:
type: vertical-stack
cards:
- type: custom:mushroom-title-card
title: Lighting & Security
subtitle: ''
alignment: center
- type: horizontal-stack
cards:
- type: custom:mushroom-light-card
entity: light.topwalllights
name: Top Wall Lights
layout: vertical
tap_action:
action: more-info
hold_action:
action: toggle
layout: vertical
entity: light.topstairlights
name: Top Stair Lights
tap_action:
action: more-info
hold_action:
action: toggle
entity: light.top_deck_pir_1_top_deck_lights
show_brightness_control: true
tap_action:
action: more-info
hold_action:
action: toggle
- type: picture-entity
entity: camera.cam_test_my_camera
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.cam_test_light
icon: mdi:lightbulb
- type: shopping-list
title: To Do
- type: custom:tabbed-card
options: {}
tabs:
- card:
type: button
entity: light.bed_light
tap_action:
action: toggle
show_name: true
show_icon: true
show_state: true
attributes:
label: Button
icon: mdi:pause
- card:
type: entities
title: Air Quality
entities:
- air_quality.demo_air_quality_home
- air_quality.demo_air_quality_office
attributes:
label: Air Quality
icon: mdi:pause
- card:
type: entities
title: Binary sensor
entities:
- binary_sensor.basement_floor_wet
- binary_sensor.movement_backyard
attributes:
label: Binary Sensor
icon: mdi:pause
- type: custom:todoist-card
entity: sensor.to_do_list
show_header: true
show_completed: 5
show_item_add: true
use_quick_add: false
show_item_close: true
show_item_delete: true
only_today_overdue: false
- type: vertical-stack
cards:
cards:
- type: picture
image: /local/images/channels/1.png
- type: picture
image: /local/images/channels/1+1.png
- type: picture
image: /local/images/channels/2.png
- type: picture
image: /local/images/channels/2+1.png
cards:
- type: picture
image: /local/images/channels/3.png
- type: picture
image: /local/images/channels/3+1.png
- type: picture
image: /local/images/channels/maoritv.png
cards:
- type: picture
image: /local/images/channels/numbers/number-one-square.png
- type: picture
image: /local/images/channels/numbers/number-two-square.png
- type: picture
image: /local/images/channels/numbers/number-three-square.png
- type: picture
image: /local/images/channels/numbers/number-four-square.png
- type: picture
image: /local/images/channels/numbers/number-five-square.png
cards:
cards:
- type: picture
image: /local/images/channels/numbers/number-six-square.png
- type: picture
image: /local/images/channels/numbers/number-seven-square.png
- type: picture
image: /local/images/channels/numbers/number-eight-square.png
- type: picture
image: /local/images/channels/numbers/number-nine-square.png
- type: picture
image: /local/images/channels/numbers/number-zero-square.png
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: light.camper_outputs_camperlights
icon: mdi:lightbulb-group
content_info: name
cards:
cards:
layout: vertical
name: Top Deck Lights
layout: vertical
layout: vertical
cards:
layout: vertical
layout: vertical
layout: vertical
- type: custom:button-card
template:
- card_room
- red_no_state
tap_action:
action: navigate
variables:
entity_1:
entity_id: light.topstairlights
templates:
- yellow_on
tap_action:
action: toggle
entity_2:
entity_id: light.camper_outputs_bottomstairlights
templates:
- blue_on
tap_action:
action: none
entity_3:
entity_id: light.camper_outputs_camperdecklights
templates:
- green_on
- red_off
tap_action:
action: toggle
entity_4:
entity_id: light.topwalllights
templates:
- pink_on
tap_action:
action: toggle
Do you care to show your code for it. It looks great.
Hi @tben, sorry for tagging you.
Thanks for all the great work and using custom button-card
I’m about to release v4.0.0 of button-card by the end of this week with some new shiny stuff aligned with the latest release of HA (and maybe breaking changes). Would you mind having a quick look if it doesn’t break too much for your templates with the latest dev16 version?
Getting your feedback (or anyone else here who is courageous enough to test the latest button-card beta) would be very helpful
You can open issues directly on GH.
Still the same problem: I can’t fill the entire space of the tablet display 1920px:
Any hint on where to touch…?
@stefano-ita Can you share your yaml, I’m trying to remember how to get temperature on room cards but drawing a blank
@stefano-ita what is that graph on the bottom? I would very much like to have time intervals shown if not always at least to see the temp and time at a point on the graphs where I am touching, for example I have these which look nice but are not entirely useful -
For example when I hold my finger on the graph in the second screen shot, all that happens is the lines show as bolder (rather than the details for that one point in time being touched)?
I guess it’s not a dashboard build by the minimalist integration. You are missing the lines to include the button card templates. Note that can only work when you build your dashboard in YAML mode.
Minimalist cards work best when you you the full integration installed due to the nesting of templates between cards.
I think UI Minimalist is too hard to setup. I certainly is not working out of the box…
Has anyone confirmed that the latest version of Minimalist works with v4.0.0 of button-card?
