šŸŒ» Lovelace UI ā€¢ Minimalist
Hey! Awesome! Would you mind sharing your current config? Link is brokenā€¦
UI-MInimalist - with YoLink Alarm KeyFob
I have the YoLInk Alarm KeyFob and the button presses can be sent to HA, which I would like to use to have small bulbs or indicators on the top of my ui-minimalist display which would be green/red/yellow etc depending upon the status of the alarm that is set by the keyfob. Is there such an item or card for UI-Minimalist?
here you go
Hey andyblac, thank-you for sharing.
Does anyone know why I would get the below error? This is when i set:
            variables:
              ulm_card_room_label_use_temperature: true
Fine when set to false. I have refresh UI in dev tools and via service, etc. I seem to have some issues with variables when using custom cards from time to time. user error I am sure, must be missing something! Tried to search through and couldnā€™t find a solution.
Thanks all!
have you also set either the entity or temperature_entity to the sensor, please post the full yaml section for that card, and iā€™ll have a look.
hereā€™s the latest version download
hereā€™s an example of one of mine.
          - type: custom:button-card
            template:
              - custom_card_andyblac_room
              - green_no_state
            icon: mdi:flower
            tap_action:
              action: navigate
              navigation_path: front-garden
            variables:
              ulm_card_room_label_use_humidity: true
              ulm_card_room_label_use_illuminance: true
              temperature_entity: sensor.front_garden_motion_sensor_temperature
              humidity_entity: sensor.front_garden_soil_sensor_humidity
              illuminance_entity: sensor.back_garden_motion_sensor_illuminance_lux
              sensor_1:
                entity_id: binary_sensor.front_door
                ulm_card_room_sensor_color: green
              sensor_2:
                entity_id: binary_sensor.front_garden_motion_sensor_occupancy
              sensor_3:
                entity_id: switch.front_garden_water_control
              entity_3:
                entity_id: light.front_garden_light
                templates:
                  - yellow_on
                tap_action:
                  action: toggle
if only using 1 room sensor (temp / humidity / lux) then you can just use something like this:
            template:
              - green_no_state
            icon: mdi:flower
            tap_action:
              action: navigate
            variables:
Hi, could you please share your config again? Link is broken.
sure, sorry, here
I might as well post my other cards, download
Hey thanks for the reply Andy! Apologies for taking a bit to respond.
I had a look through my yaml and I canā€™t see anything different (likely me missing something obvious), tried the updated custom_card you linked too.
Below is my config for this card:
      - type: "custom:button-card"
        template:
          - yellow_no_state
        icon: mdi:sofa
        tap_action:
          action: navigate
          navigation_path: "living"
        variables:
          ulm_card_room_label_use_temperature: false
          ulm_card_room_label_use_humidity: false
          temperature_entity: sensor.thermostat_group
          humidity_entity: sensor.lounge_humidity
          sensor_1:
            entity_id: media_player.lounge_tv
            ulm_card_room_sensor_color: yellow
          sensor_2:
            entity_id: binary_sensor.motion2_motion
          sensor_3:
            entity_id: cover.garage_door
          sensor_4:
            entity_id: light.hall
          entity_1:
            entity_id: light.living_light_group
            templates:
              - yellow_on
            tap_action:
              action: toggle
          entity_2:
            entity_id: light.living_room
            templates:
              - yellow_on
            tap_action:
              action: toggle
          entity_3:
            entity_id: light.dining_light
            templates:
              - yellow_on
            tap_action:
            action: toggle
          entity_4:
            entity_id: light.kitchen_light
            templates:
              - yellow_on
            tap_action:
            action: toggle
          entity_5:
            templates:
              - yellow_on
            tap_action:
            action: toggle
When I set either the ulm_card_room_label_use_temperature or humidity to true, I get the error. Tried all the usual clearing cache, reloading theme, etc. Works great without the label, really happy with it thank-you!
Sorry for late reply, dint get a notification of your reply.
You will need to edit the
custom_card_esh_welcome.yaml
towards the end of the code replace the items with 3 instead of original two you can obviously choose what entities you want as per your preference.
  custom_fields:
    item1:
      card:
        template: chip_temperature_ash
        variables:
          ulm_chip_temperature_weather: weather.openweathermap
        tap_action:
          action: "more-info"
          entity: "[[[ return variables.ulm_weather]]]"
        styles:
          card:
            - width: "100px"
            - box-shadow: >
                  if (hass.themes.darkMode){
                    return "0px 2px 4px 0px rgba(0,0,0,0.80)";
                  } else {
                    return "var(--box-shadow)";
            - "--mdc-ripple-press-opacity": 0.12    # allow click animation
    item2:
      card:
        template: chip_alarm_ash
        entity: alarm_control_panel.homebase_2
        tap_action:
          action: "navigate"
          navigation_path: "/ui-lovelace-minimalist/secure"
        styles:
          card:
            - width: "100px"
            - box-shadow: >
                  } else {
    item3:
      card:
        template: "custom_chip_group_counter"
        entity: "light.all"
        variables:
          ulm_custom_chip_group_counter_entities_active: "sensor.lights_on"
        tap_action:
          action: "navigate"
          navigation_path: "/ui-lovelace-minimalist/lights"
        styles:
          card:
            - width: "100px"
            - box-shadow: >
                  } else {
Once you have edited the yaml. developer tools> click all the way down UI minimalist UI to refresh these changes > refresh your minimalist ui to see the changes!
Iā€™m just wondering, is there some other Lovelace theme which could be fully applied to Minimalist UI?
I mean, I know that Minimalist UI is already a ā€œthemeā€ (but not ordinary one). I like whole concept of creating beautiful dashboards in YAML, and this is the power of Minimalist UI. But if you go to Profile > Select Theme, there are 4 themes which comes with Minimalist UI - minimalist-desktop, minimalist-ios-tapbar, minimalist-mobile and minimalist-mobile-tapbar. These 4 themes were made for Minimalist UI and these 4 perfectly fit. If I try to apply some other theme, e.g. Graphite (I much like Graphite theme), it doesnā€™t fit in full to Minimalist UI dashboards, and there are always some parts missing (sliders, colors, etc.). Example, Graphite left aka first, minimalist-desktop right aka second:
image image
This is the case with all other themes I tried before. Not that I donā€™t like minimalist-desktop theme, but from time to time I would like to change it little bit, so Iā€™m just wondering are there some Lovelace themes which would fully fit to Minimalist UI?
Hi every one,
I just found this thread and Iā€™m trying to make some views. I have a question, I would like to put my lights under the title this way:
But my lights are placed this way:
Can you tell me what I need to change in my code (below):
#                                 Page Salon                                     #
#                               Navigation                                       #
  - title: "Equipements Salon"
    path: 0
    icon: "mdi:sofa"
    cards:
      - type: "horizontal-stack"
        cards:
             template: chip_back
             color_type: blank-card
#                               Titre                                            #
      - type: "vertical-stack"
        cards:
          - type: 'custom:button-card'
            template: card_title
            label: 'Subtitle'
        cards:
            template: card_light
            entity: light.ikea_of_sweden_tradfri_bulb_e27_ww_806lm_light_2
            variables:
                ulm_card_light_enable_slider : true
                ulm_card_light_enable_color: true
                ulm_card_light_force_background_color: true
            variables:
Thanks, sorry for the stupid question
Try :wink:
It works thks
I am trying to configure the adaptive dashboard and I am having a problem with the popup not showing.
The default in popup.yaml doesnā€™t display anything in the popup area with Button Card v4.1.1 installed via HACS:
states:
  light 1:
    template: "popup_light_brightness"
    entity: "light.master_bedroom_bedside_lights"
On the other hand, this does work:
states:
  light 1:
    type: "custom:light-entity-card"
Any thoughts on why the default button-card type doesnā€™t show?
Hi Andy,
I like your card. I have an issue where the card doesnā€™t size on my browser. On my iPhone it is the same size as the ā€œstandardā€ room card.
Any change you know why?
  - view_layout:
    grid-area: "card5"
    template:
      - yellow_no_state
    icon: mdi:sofa
    tap_action:
      action: navigate
      navigation_path: "Livingroom"
    variables:
      temperature_entity: "sensor.woonkamer_temperature"
      humidity_entity: "sensor.woonkamer_humidity"
      sensor_1:
        entity_id: binary_sensor.achterdeur_contact
      sensor_2:
        entity_id: binary_sensor.woonkamer_motion_sensor_occupancy
hmm, thats strange, I donā€™t know how to use grid-area so I have not tested it using that, If you could provide a example how to use it, iā€™ll see if I can debug the card, but it should have worked.
Thanks for helping.
On my mobile the card is the right size but the icon is small.
I shared my main.yaml config below. It starts with the grid layout
type: "custom:layout-card"
layout_type: "custom:grid-layout"
layout:
  # Tablet portrait
  grid-template-columns: "1fr 1fr 1fr 1fr 1fr 1fr"
  grid-template-rows: auto
  grid-template-areas: |
    "swipe swipe swipe swipe swipe swipe"
    "title1 title1 title1 title1 title1 title1"
    "welcome welcome welcome welcome welcome welcome"
    "person1 person1 person2 person2 person3 person3"
    "rooms rooms rooms rooms rooms rooms"
    "keuken keuken card5 card5 card6 card6"
  mediaquery:
    # Mobile
    "(max-width: 800px)":
      grid-template-columns: "1fr 1fr"
        "swipe swipe"
        "title1 title1"
        "welcome welcome"
        "person1 person2"
        "person3 person3"
        "rooms rooms"
        "keuken card5"
        "card6 ."
view_layout:
  grid-area: "main"
cards:
  # - view_layout:
  #     grid-area: "text"
  #   type: "custom:button-card"
  #   template: "card_title"
  #   name: "This is the adaptive <br>dashboard provided by <br> UI Minimalist"
  #   label: "Find instructions to add <br> cards on the wiki"
  - view_layout:
      grid-area: "swipe"
    type: "custom:swipe-card"
#    card_width: '185px'
#    start_card: 6
    parameters:
      simulateTouch: true
      spaceBetween: 8
      preventInteractionOnTransition: true
#      preventClicks: true
#      effect: coverflow
      freeMode: true
    cards:
      # - type: 'custom:button-card'
      #   template: chip_temperature
      #   variables:
      #     ulm_chip_temperature_inside: sensor.average_house_temperature
      #     ulm_chip_temperature_outside: sensor.amersfoort_temperature
      #     ulm_chip_temperature_weather: weather.amersfoort
      - !include "../chips/include_chip_temperature.yaml"
      # - !include "chips/include_chip_presence.yaml"
      # - !include "chips/include_chip_energy.yaml"
      # - !include "chips/include_chip_alarm_clock.yaml"
  - view_layout:
      grid-area: "welcome"
    template: "card_esh_welcome"
    triggers_update: input_boolean.ulm_card_welcome_scenes_collapse_state
    #entity: input_boolean.<Your_boolean>
    variables:
      ulm_card_esh_welcome_collapse: input_boolean.ulm_card_welcome_scenes_collapse_state #OPTIONAl --> uncomment also entity or triggers_update
      ulm_weather: "weather.amersfoort"
      entity_1:
        nav: "house"
        icon: "mdi:home"
        color: "blue"
      entity_2:
        nav: "Lampen"
        icon: "mdi:lightbulb"
        color: "yellow"
      entity_3:
        nav: "security"
        icon: "mdi:shield"
        color: "green"
      entity_4:
        nav: "network"
        icon: "mdi:nas"
        color: "purple"
      entity_5:
        nav: "Weather"
        icon: "mdi:weather-partly-cloudy"
        # name: Weather
        color: "blue"
  - view_layout:
      grid-area: "person1"
    template: card_person
    entity: person.remco
    variables:
      ulm_card_person_entity: person.remco
      ulm_card_person_use_entity_picture: true
      # ulm_card_person_icon: mdi:face-woman
      ulm_card_person_battery: sensor.phone_merlin_battery_level
      ulm_card_person_eta: sensor.reistijd_remco_work_duration
      # ulm_address: sensor.s10_mike_gegeocodeerde_locatie
  - view_layout:
      grid-area: "person2"
    entity: person.iris
    variables:
      ulm_card_person_entity: person.iris
      ulm_card_person_battery: sensor.iphone_iris_battery_level_iosapp
  - view_layout:
      grid-area: "person3"
    entity: person.iris
    variables:
      ulm_card_person_entity: person.noah
      ulm_card_person_battery: sensor.iphonen_battery_level_iosapp
      ulm_card_person_eta: sensor.reistijd_noah_work
  - view_layout:
      grid-area: "title1"
    # label: 'Subtitle'
  - view_layout:
      grid-area: "rooms"
  - view_layout:
      grid-area: "keuken"
    template:
      - card_room
      - red_no_state
    entity: sensor.keuken_sensors_temperature
    icon: mdi:stove
    tap_action:
      action: navigate
      navigation_path: "Keuken"
    variables:
      label_use_brightness: true
      entity_1:
        entity_id: binary_sensor.keukendeur_contact
        templates:
          - blue_on
        tap_action:
          action: more-info
      entity_2:
        entity_id: light.aanrechtlampen
        templates:
          - blue_on
        tap_action:
          action: toggle
      entity_3:
        entity_id: light.keukenspots_dimmer
        templates:
          - blue_on
        tap_action:
          action: toggle
      entity_4:
        entity_id: switch.laders_stekker
        templates:
          - blue_on
        tap_action:
          action: toggle
  - view_layout:
      grid-area: "card6"
    template:
      - card_room
      - red_no_state
    entity: sensor.woonkamer_average_temp
    icon: mdi:sofa
    tap_action:
      action: navigate
      navigation_path: 'Livingroom'
    variables:
      entity_1:
        templates:
          - blue_on
        tap_action:
          action: more-info
      entity_2:
        entity_id: light.woonkamer_lampen
        templates:
          - blue_on
        tap_action:
          action: toggle
      entity_3:
        entity_id: light.woonkamerspots_dimmer
        templates:
          - blue_on
        tap_action:
          action: toggle
      entity_4:
        entity_id: switch.tv_kijken
        templates:
          - blue_on
        tap_action:
          action: toggle  # - view_layout:
  - view_layout:
    grid-area: "card5"
    template:
      - yellow_no_state
    icon: mdi:sofa
    tap_action:
      action: navigate
    variables:
      sensor_1:
      sensor_2:
      entity_1:
        entity_id: group.woonkamer_lampen
        templates:
          - yellow_on
        tap_action:
          action: toggle
Here is another data point. The Popup Power Outlet cards donā€™t show up either, but they do become visible for a second during the transitions, after you double click on something else. The Light popup does not show up during the transitions though.
power 3:
    template: "popup_power_outlet_stats"
    entity: sensor.guest_air_conditioner_utility_meter
    variables:
      ulm_popup_power_outlet_sensor1: sensor.guest_air_conditioner_utility_meter
      ulm_popup_power_outlet_sensor2: sensor.guest_air_conditioner_utility_meter
      ulm_popup_power_outlet_graph_sensor: sensor.guest_air_conditioner_utility_meter
I tried installing the beta version and the previous stable version of button-card with no change in the behavior. Currently Iā€™m back on v4.1.1. I saw the same behavior in Edge and Chrome(including incognito mode).
Any help appreciated.
Check the version of state-switch you have installed. This should be 1.9.3. The problems you describe are correlated wit the latest version 1.9.5
Thank you very much!!
That was it. I had attempted to downgrade to state-switch 1.9.3 when I saw the warning on the wiki but I didnā€™t verify :roll_eyes: and I was still on 1.9.5. I had to remove and re-install state-switch to get 1.9.3 and now everything is working as expected.
