bbwebb
(Bbwebb)
October 6, 2023, 2:02am
3500
Working on my first dashboard, and still pretty new to Home Assistant. Making good progress on my dashboard, but having a problem trying to change an icon in the Room Card. Specifically Iām trying to change one of the entities to have an icon that is different from what is assigned to the entity. Here is my yaml:
entity_2:
entity_id: cover.master_bedroom_slider
icon: mdi:arrow-up-bold
templates:
- green_on
tap_action:
action: call-service
service: cover.open_cover
service_data:
Iām trying to change the ācoverā icon to be an up arrow (mdi:arrow-up-bold)
Any help is appreciated!
Bill
andyblac
(Andy Blackburn)
October 6, 2023, 9:51am
3501
that is not supported in the default room card, but take a look at my custom room card, it has loads of additional features.
https://community.home-assistant.io/t/my-custom-cards-for-minimalist-ui
I be happen to help in that thread i you need help settingup, or have any questions
bbwebb
(Bbwebb)
October 6, 2023, 11:06am
3502
Thanks! Checking it out now.
nukleuz80
(nukleuz)
October 6, 2023, 2:45pm
3503
Hi there,
iām working on my first simple custom card.
This is what i have, but i need the state under the friendly name:
Here is the template:
custom_card_test:
template:
- "icon_info_bg"
show_name: true
show_state: true
show_label: false
show_icon: true
show_last_changed: false
variables:
ulm_custom_card_jb_test_icon_on: ""
ulm_custom_card_jb_test_icon_off: ""
ulm_custom_card_jb_test_icon_tilt: ""
ulm_custom_card_jb_test_color_background: ""
icon: >
if (entity.state == "Offen")
return variables.ulm_custom_card_jb_test_icon_on;
if (entity.state == "Gekippt")
return variables.ulm_custom_card_jb_test_icon_tilt;
else return variables.ulm_custom_card_jb_test_icon_off;
Here is the card:
- type: custom:button-card
entity: sensor.wohnzimmer_tur_advanced
template: custom_card_test
variables:
ulm_custom_card_jb_test_icon_on: "mdi:door-open"
ulm_custom_card_jb_test_icon_off: "mdi:door-closed"
ulm_custom_card_jb_test_icon_tilt: "mdi:door-sliding"
I donāt get itā¦ Thanks
andyblac
(Andy Blackburn)
October 6, 2023, 5:12pm
3504
you do this using styles
ie
styles:
state:
- justify-self: "start"
- font-size: "15px"
- margin-left: "33%"
- margin-top: "0%"
- max-width: "65%"
- text-overflow: "ellipsis"
- overflow: "hidden"
nukleuz80
(nukleuz)
October 6, 2023, 7:24pm
3505
Thanks for the hintā¦
I had to change the grid from label to state:
styles:
grid:
- grid-template-areas: '"i n" "i s"'
Zixten
October 7, 2023, 3:26pm
3506
Hi Iām running Home Assistant 2023.9.3 with the latest version of Minimalist.
Itās been a while since i started my custom dashboard and now I have some time to work some more on it.
Then i Noticed that I have these ugly borders now.
I found that there is a fix and I see that is has been implemented
# fix added border-lines in 2022.11
ha-card-border-width: "0px"
Yet it does not work Have been googling and trying all sorts of fixes I found but no luck.
Any one been having tha same problem?
drashish87
(Drashish87)
October 8, 2023, 9:06am
3507
You can do this for any entity by following the below!
Developer tool > states > search your entity in your case cover.master_bedroom_slider > click on " i " icon below it > click on the gear icon > you will get icon option to change it!
andyblac
(Andy Blackburn)
October 8, 2023, 9:28am
3508
you can. but doing so, will stop the state icon changing, it will become a static icon.
drashish87
(Drashish87)
October 8, 2023, 9:33am
3509
Mine are working fine,I am using the default room cards.
max5962
(Max5962)
October 10, 2023, 2:45pm
3510
Awesome, can you share the code when you finished it ? please
Great Dashboard!
How did you put the swipe card with the camera entities into minimalist and how is the schedule card working?
thanks for any help
clemalex:
button_card_templates
Excuse me, one Q, where I have to locate/put the template section?
nikno
(Niklas)
October 16, 2023, 8:22am
3513
My first trials to get tabs to workā¦
Not sure what I am doing wrong hereā¦all I get is an empty dashboard!?
I have follow the description for adding tabs as it it described here:
https://ui-lovelace-minimalist.github.io/UI/setup/customizing/#how-to-customize-the-dashboard
Currently the yaml file looks something like this (where I expect 2 tabs to show up one āMainā and one āVitoā:
button_card_templates: !include_dir_merge_named "../../custom_components/ui_lovelace_minimalist/__ui_minimalist__/ulm_templates/"
title: "Home trials"
theme: "minimalist-desktop"
background: "var(--background-image)"
- title: "Main"
path: 0
icon: "mdi:home"
cards:
- type: vertical-stack
cards:
########## TOP CHIPS/PILLS
- type: horizontal-stack
cards:
################### REMOVED STUFF
- title: "Vito"
path: vito
icon: "mdi:car"
cards:
cards:
Iām working at an adaptive dashboard version for my tablet and I donāt know why, my dashboard is loading very slow. I double checked the code and it seems fine. Does anyone have an ideea why it is working slow and also, after a few minutes it crashes, especially when Iām in Home page? HASS is running on a virtual machine on Synology. I tried on MS Edge, Google Chrome. On FullyKioskBrowser it is even worse. Also I tried on a iPad with HA Companion app, and again it is worse. It could be because I used horizontal-stack in a vertical-stack, some kind of stack-in-stack on a single grid-area? I didnāt used this on all views, but all views are loading very slowly.
IssaSFX
(Issa SFX)
October 17, 2023, 12:12pm
3515
how do you center the entities like adblue inspektion licht usw
It seems that this is because of the popup.yaml file. I cannot understand why, or how this popup works (when accessing the dashboard, the entire popup cards are loaded?). I reinstalled UI Minimalist, recreated all views without popup. Everything is working fine. When I recreate the popup, all is working slowly. Bellow is my popup.yaml file. Is there something I do wrong?
type: custom:state-switch
view_layout:
grid-area: popup
show:
mediaquery: "(min-width: 1100px)"
entity: input_select.input_select_minimalist_ui
default: "default"
transition: "slide-down"
transition_time: 500
states:
bec_buc:
type: "custom:button-card"
template: "popup_light_brightness"
entity: light.kitchen
mediaplayer 1:
template: "popup_media_player_infos"
entity: media_player.chromecastcosmin
spotify:
entity: media_player.spotify_cosmin
boxa_living:
entity: media_player.living_room
mibox_living:
entity: media_player.mibox_living_room
boxa_baie:
entity: media_player.bathroom_speaker
boxa_fete:
entity: media_player.kids_room_speaker
temp_buc:
type: custom:plotly-graph
entities:
- entity: sensor.temperatura_bucatarie_adjusted
hours_to_show: 24
refresh_interval: 10
title: Temperatura Bucatarie
vreme:
template: "popup_weather_forecast"
entity: weather.home_2
popup_variables:
ulm_weather_popup_surpress_first_forecast: false
umid_buc:
entities:
- entity: sensor.umiditate_bucatarie_adjusted
hours_to_show: 24
title: Umiditate Bucatarie
temp_baie:
entities:
- entity: sensor.temperatura_baie_adjusted
hours_to_show: 24
title: Temperatura Baie
birou_fete:
entity: light.sonoff_100123e37b
veioza:
entity: light.tapo_light
lidl1:
entity: light.lidl_light_1
lidl2:
entity: light.lidl_light_2
umid_baie:
entities:
- entity: sensor.umiditate_baie_adjusted
hours_to_show: 24
title: Umiditate Baie
temp_fete:
entities:
- entity: sensor.temperatura_fete_adjusted
hours_to_show: 24
title: Temperatura Fete
umid_fete:
entities:
- entity: sensor.umiditate_fete_adjusted
hours_to_show: 24
title: Umiditate Fete
temp_living:
entities:
- entity: sensor.salus_current_temp
hours_to_show: 24
title: Temperatura Camera Mare
umid_living:
entities:
- entity: sensor.umiditate_camera_mare_adjusted
hours_to_show: 24
title: Umiditate Camera Mare
gaz:
type: entity
entity: binary_sensor.ch4_alarm
metan:
cards:
- type: entity
entity: sensor.ch4_alarm_methane
- type: custom:plotly-graph
entities:
- entity: sensor.ch4_alarm_methane
hours_to_show: 24
title: Nivel Metan
consum_apart:
cards:
cards:
- type: energy-date-selection
- type: energy-usage-graph
title: Grafic Consum Energie
- type: energy-sources-table
title: Cost Energie
cards:
- type: entities
entities:
- entity: switch.shellyem_a4e57cba9f4d
- entity: sensor.consum_total_apartament_energy
name: Consum Total Apartament
- entity: sensor.consum_total_apartament_energy_returned
name: Consum Total Returnat
- entity: sensor.consum_total_apartament_power
name: Putere Actuala Apartament
- type: entities
entities:
- entity: sensor.consum_total_apartament_power_factor
name: Factor Putere Apartament
- entity: sensor.consum_total_apartament_voltage
name: Voltaj Apartament
- entity: binary_sensor.shellyem_a4e57cba9f4d_cloud
- entity: sensor.shellyem_a4e57cba9f4d_uptime
consum_masina:
cards:
- type: history-graph
entities:
- entity: sensor.consum_masina_spalat_energy_total
hours_to_show: 24
refresh_interval: 0
title: Consum Masina Spalat si Uscator
cards:
- type: entities
entities:
- entity: sensor.consum_masina_spalat_energy_voltage
- entity: sensor.consum_masina_spalat_energy_power
- entity: sensor.consum_masina_spalat_energy_current
- entity: sensor.consum_masina_spalat_energy_frequency
- entity: sensor.consum_masina_spalat_energy_apparentpower
- entity: sensor.consum_masina_spalat_energy_factor
- type: entities
entities:
- entity: sensor.consum_masina_spalat_energy_reactivepower
- entity: sensor.consum_masina_spalat_energy_today
- entity: sensor.consum_masina_spalat_energy_yesterday
- entity: sensor.consum_masina_spalat_ssid
- entity: sensor.consum_masina_spalat_firmware_version
termostat_living:
template: "popup_thermostat_temperature"
entity: climate.salus_thermostat
termostat_fete:
entity: climate.termostat_calorifer
priza_troti:
template: "popup_power_outlet_stats"
entity: switch.priza_trotineta_trotineta
variables:
ulm_popup_power_outlet_sensor1: sensor.priza_trotineta_trotineta_power
ulm_popup_power_outlet_sensor2: sensor.priza_trotineta_trotineta_energy
ulm_popup_power_outlet_graph_sensor: sensor.priza_trotineta_trotineta_power
priza_aspi:
entity: switch.priza_trotineta_aspirator
variables:
ulm_popup_power_outlet_sensor1: sensor.priza_trotineta_aspirator_power
ulm_popup_power_outlet_sensor2: sensor.priza_trotineta_aspirator_energy
ulm_popup_power_outlet_graph_sensor: sensor.priza_trotineta_aspirator_power
alarma:
type: alarm-panel
states:
- arm_away
- arm_vacation
entity: alarm_control_panel.ha_alarm
priza_nas:
entity: switch.plug_status
variables:
ulm_popup_power_outlet_sensor1: sensor.current_consumption
ulm_popup_power_outlet_sensor2: sensor.current
ulm_popup_power_outlet_graph_sensor: sensor.current_consumption
priza_esxi:
entity: switch.plug_status_esxi
variables:
ulm_popup_power_outlet_sensor1: sensor.current_consumption_esxi
ulm_popup_power_outlet_sensor2: sensor.current_esxi
ulm_popup_power_outlet_graph_sensor: sensor.current_consumption_esxi
nas:
title: Synology-NAS
cards:
cards:
- type: "custom:button-card"
template: custom_card_bar_card
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_nas_cpu_utilization_total
ulm_custom_card_bar_card_name: Incarcare CPU
ulm_custom_card_bar_card_value: true
ulm_custom_card_bar_card_indicator: true
ulm_custom_card_bar_card_color: "var(--google-green)"
ulm_custom_card_bar_card_min: 0
ulm_custom_card_bar_card_max: 100
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_nas_memory_usage_real
ulm_custom_card_bar_card_name: Utilizare Memorie
cards:
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_nas_volume_1_volume_used
ulm_custom_card_bar_card_name: Procentaj Utilizare Volume 1
cards:
- type: 'custom:button-card'
template: card_generic_swap
entity: sensor.cosmin_nas_volume_1_total_size
variables:
ulm_card_generic_swap_color: green
ulm_card_generic_swap_name: Dimensiune totala Volume 1
ulm_card_generic_swap_force_background_color: true
entity: sensor.cosmin_nas_volume_1_used_space
variables:
ulm_card_generic_swap_name: Dimensiune utilizata Volume 1
template: custom_card_speedtest_shogun160
variables:
ulm_custom_card_speedtest_download_speed_entity: sensor.cosmin_nas_download_throughput
ulm_custom_card_speedtest_upload_speed_entity: sensor.cosmin_nas_upload_throughput
ulm_custom_card_speedtest_ping_entity: sensor.speedtest_ping
ulm_custom_card_speedtest_round: false
router:
title: Xiaomi Router
cards:
cards:
entity: sensor.miwifi_router_b_received
variables:
ulm_card_generic_swap_name: Data received
entity: sensor.miwifi_router_b_sent
variables:
ulm_card_generic_swap_name: Data sent
cards:
entity: sensor.miwifi_router_kib_s_received
variables:
ulm_card_generic_swap_name: Download speed
entity: sensor.miwifi_router_kib_s_sent
variables:
ulm_card_generic_swap_name: Upload speed
cards:
entity: sensor.miwifi_router_packets_received
variables:
ulm_card_generic_swap_name: Packets received
entity: sensor.miwifi_router_packets_s_received
variables:
ulm_card_generic_swap_name: Packet download speed
cards:
entity: sensor.miwifi_router_packets_s_sent
variables:
ulm_card_generic_swap_name: Packet upload speed
entity: sensor.miwifi_router_packets_sent
variables:
ulm_card_generic_swap_name: Packets sent
camera_buc:
entity: camera.camera2
template: "custom_card_camera"
show_icon: true #True if you set ulm_custom_card_camera_title: true
variables:
ulm_custom_card_camera_name: "Bucatarie"
ulm_custom_card_camera_aspect_ratio: '16:9'
printer:
template: "custom_card_sisimomo_printer"
entity: sensor.epson_l7160_series
variables:
printer_name: EPSON L7160 Series
cartridges:
- label: "BK"
entity_id: sensor.epson_l7160_series_black_ink
type: unicolor
color: "black"
- label: "PB"
entity_id: sensor.epson_l7160_series_photo_black_ink
type: unicolor
color: "black"
- label: "Y"
entity_id: sensor.epson_l7160_series_yellow_ink
type: unicolor
color: "rgba(var(--color-yellow), 1)"
- label: "M"
entity_id: sensor.epson_l7160_series_magenta_ink
type: unicolor
color: "#F84B7A"
- label: "C"
entity_id: sensor.epson_l7160_series_cyan_ink
type: unicolor
color: "#427EDE"
laptop:
title: Cosmin-Laptop
cards:
cards:
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_laptop_cpuload
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_laptop_memoryusage
cards:
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_laptop_storage_c_usage
ulm_custom_card_bar_card_name: Utilizare Drive C
variables:
ulm_custom_card_bar_card_entity: sensor.cosmin_laptop_storage_d_usage
ulm_custom_card_bar_card_name: Utilizare Drive D
cards:
entity: sensor.cosmin_laptop_storage_c_file_system
variables:
ulm_card_generic_swap_name: File System C
entity: sensor.cosmin_laptop_storage_d_file_system
variables:
entity: sensor.cosmin_laptop_network_wi_fi
variables:
ulm_card_generic_name: WIFI Status
ulm_card_generic_force_background_color: true
ulm_card_generic_color: green
variables:
ulm_custom_card_speedtest_download_speed_entity: sensor.speedtest_download
ulm_custom_card_speedtest_upload_speed_entity: sensor.speedtest_upload
## Rooms
baie: !include "../views/baie.yaml"
balcon: !include "../views/balcon.yaml"
bucatarie: !include "../views/bucatarie.yaml"
camera_fete: !include "../views/camera_fete.yaml"
camera_mare: !include "../views/camera_mare.yaml"
casa: !include "../views/casa.yaml"
coridor_intrare: !include "../views/coridor_intrare.yaml"
coridor_mic: !include "../views/coridor_mic.yaml"
lab: !include "../views/lab.yaml"
lumini: !include "../views/lumini.yaml"
main: !include "../views/main.yaml"
summary: !include "../views/summary.yaml"
prize: !include "../views/prize.yaml"
secure: !include "../views/secure.yaml"
nikno
(Niklas)
October 18, 2023, 2:30pm
3517
@daxm Looks like I have the same issue, did you find the solution?
nikno
(Niklas)
October 19, 2023, 9:41am
3518
I figured out that I need to empty the browser cache, after that things started to show up.
But still having issues with the apexcharts, some of the info shows up in a card but then an error in what appear/might to be the line chart area. I tried different chart types but no difference.
EDIT: Solved. Below is how it looks when you havenāt installed the HACS apex-charts addon, didnāt read the requirements very wellā¦
This is the code:
cards:
template: "custom_card_apexcharts"
variables:
chart_type: "line"
graph_span: "1h"
entity_1:
entity_id: sensor.fridge_temperature
icon: mdi:fridge
color: "blue"
entity_2:
entity_id: sensor.living_room_temperature
icon: mdi:sofa
color: "red"
entity_3:
entity_id: sensor.bedroom_temperature
icon: mdi:bed-king
color: "green"
I have been using this card for almost 6 months and a set of these room cards is front and center of my dashboard. I have one āfeature requestā as I havenāt figured out a way to implement it myself. Can you direct me in the right direction?
For room cards, where I have a light entity, tapping toggles the lights, double tapping opens up the popup where I can adjust the brightness and colors of those lights. This is great, but I was thinking if the visual element on the card for the lights can become a brightness slider if the lights are ON. I think with the 3 column grid you have shown above, it may be a little bit crowded, but with a 2 column grid, that may actually be a great addition which allows for an easier brightness adjustment.
Any thoughts?
