I have started but not finished yet
I dont understand how to use popup cards in UI-mode. Сan anyone help me?
Is possible to combine custom State within Welcome Car?
my code:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:layout-card
layout_type: grid
layout_options:
grid-template-columns: 1fr 1fr
grid-template-rows: auto
grid-gap: 0px 4px
mediaquery:
"(max-width: 450px)":
cards:
##-- Welcome Card --##
- type: 'custom:button-card'
template: custom_card_paddy_welcome
variables:
ulm_custom_card_paddy_welcome_time: sensor.time
cards:
layout_type: grid
layout_options:
grid-gap: 0px 4px
mediaquery:
grid-template-columns: 1fr 1fr 1fr 1fr
cards:
template: vertical_buttons_custom_state
variables:
state: home
color: green
entity: input_select.status_person
label: home
icon: 'mdi:home'
variables:
state: Work
color: purple
label: Work
icon: 'mdi:factory'
variables:
state: snooker
color: pink
label: Play
icon: "mdi:billiards-rack"
variables:
state: not_home
color: yellow
label: Away
icon: "mdi:run"
Hi, can you share this template: template: vertical_buttons_custom_state?
Is part of the UI minimalist, under the file button_card_templates.yaml
If you do not find, I will share
The buttons wont show in the dashboard. This is my code.
cards:
layout_type: grid
layout_options:
grid-gap: 0px 4px
mediaquery:
cards:
variables:
state: on
color: green
entity: scene.avond1
label: Avond1
icon: 'mdi:home'
variables:
state: on
color: green
label: Avond
icon: 'mdi:home'
I use that template. but some how it wont show up in the ui…
I implemented that card yesterday, but had also some challenges. The color were not shown and I were also not able to to switch the scene off… Here my code - as next enhancement the color could be used as variable
vertical_buttons_custom_state:
template: "vertical_buttons"
variables:
state: "on"
# blue, red, green, yellow, purple, pink
color: "green"
show_last_changed: false
name: "[[[ return variables.state ]]]"
styles:
name:
- text-transform: "capitalize"
state:
- operator: "template"
value: "[[[ return entity.state == variables.state ]]]"
styles:
icon:
- color: "[[[ return `rgba(var(--color-${variables.color}), 1)`; ]]]"
label:
- color: "[[[ return `rgba(var(--color-${variables.color}-text), 1)`; ]]]"
name:
img_cell:
- background-color: "[[[ return `rgba(var(--color-${variables.color}), 0.2)`; ]]]"
card:
- background-color: "[[[ return `rgba(var(--color-background-${variables.color}), var(--opacity-bg))`; ]]]"
tap_action:
action: "call-service"
service: "input_select.select_option"
service_data:
entity_id: "[[[ return entity.entity_id ]]]"
option: >
if (entity.state == 'on') {
return 'off';
} else if (entity.state == 'off') {
return 'on';
Can you please open a bug report on GitHub with some Screenshots and code examples.
Ist’s hard to track such issues inside a forum thread.
In your template you work with the entity itself not with a variable. So try:
- type: custom:button-card
template: vacuum
entity: vacuum.vacuum
variables:
Don’t know if name is the name property of the custom:button-card or a custom variable. When you wish to pass the entity as a variable you have to get the state like this: states[variables.entity].state
How do you changed the card th show the temperature? Can you share your code pls?
Looks really nice, but is it possible to get more then 1 next event from a calendar entity?
I looked into this once, but could not figure it out
Looks like GitHub - totaldebug/atomic-calendar-revive: Custom calendar card for Home Assistant with Lovelace does. But might be better to just adjust to this card?
Okey, I looked into this quickly and the card does a call to the backend:
this.hass.callApi('GET', `calendars/${entity.entity}?start=${start}Z&end=${end}Z`)
And then processes the result.
So the more easy option would indeed be to adjust the card
that wil be nice! maybe in combination with the welcome card
do you have the yaml code and template?
No, Its a card I miss and it needs to be developed.
how do you create this card?
