fnxpt
(Marlon Tojal)
January 5, 2022, 8:52am
970
Added the following lines to the card
z-index: 9
margin-top: -56px;
card_graph:
variables:
ulm_card_graph_color: var(--info-color)
ulm_card_graph_name: n/a
triggers_update:
- '[[[ variables.ulm_card_graph_entity ]]]'
styles:
grid:
- grid-template-areas: '"item1" "item2"'
- grid-template-columns: 1fr
- grid-template-rows: min-content min-content
card:
- border-radius: var(--border-radius)
- box-shadow: var(--box-shadow)
- padding: 0px
custom_fields:
item1:
card:
type: custom:button-card
template:
- icon_info
- card_generic
styles:
card:
- box-shadow: none
- border-radius: var(--border-radius) var(--border-radius) 0px 0px
- padding: 12px
- background: none
- z-index: 9
entity: '[[[ return variables.ulm_card_graph_entity ]]]'
item2:
card:
type: custom:mini-graph-card
entities:
- entity: '[[[ return variables.ulm_card_graph_entity ]]]'
line_color: '[[[ return variables.ulm_card_graph_color ]]]'
show:
icon: false
legend: false
state: false
style: |
ha-card {
box-shadow: none;
border-radius: var(--border-radius);
margin-top: -56px;
bms
(Bavo)
January 5, 2022, 9:03am
971
I don’t know how to fix this. But what could help you debug this is to log the variables to somewhere you can easily see whats going on:
sequence:
- service: persistent_notification.create
message: "Light entity: {{ light_entity }}"
title: "DEBUG"
message: "Snapshot entities: {{ expand(state_attr('{{ light_entity }}', 'entity_id'))
|map(attribute='entity_id')|list }}"
title: "DEBUG"
But know that i look at it, it seems your using {{ inside of other {{. I dont know if this works.
Can you try you template {{ expand(state_attr('{{ light_entity }}', 'entity_id') |map(attribute='entity_id')|list }}
inside de Developer Tools > Templates, but with the light_entity filled in as a real entity instead of the variable. There you can try and get it to work.
mn_box
(Martijn)
January 5, 2022, 10:01am
972
Thanks good suggestion to debug. {{ light entity }} gives the right entity but the state_attr doesn’t (i.e empty list). The command without the variable works fine:
{{ expand(state_attr('light.dimmer....', 'entity_id'))
So question is how to get this variable to be executed within the state_attr command.
bms
(Bavo)
January 5, 2022, 10:07am
973
I’m not sure but can you try this:
{{ expand(state_attr(light_entity, 'entity_id')) | map(attribute='entity_id')|list }}
Instead of
{{ expand(state_attr('{{ light_entity }}', 'entity_id')) | map(attribute='entity_id')|list }}
mn_box
(Martijn)
January 5, 2022, 10:15am
974
That’s it! Indeed, big thanks!!
Abeksis
January 5, 2022, 1:18pm
975
Is it possible to combine scenes together with welcome?
Abeksis
January 5, 2022, 5:05pm
976
- type: custom:layout-card
layout_type: grid
cards:
- type: 'custom:button-card'
template: custom_card_paddy_welcome
variables:
ulm_custom_card_paddy_welcome_time: sensor.time
- type: "custom:button-card"
template:
- card_scenes
variables:
entity_1: "scene.bad_time"
entity_2: "scene.lights_off"
entity_3: "scene.builaer"
entity_4: "scene.YOUR_SCENE"
entity_5: "scene.YOUR_SCENE"
name_1: "Sleep"
name_2: "Off"
name_3: "Builaer"
name_4: "YOUR_NAME"
name_5: "YOUR_NAME"
icon_1: "mdi:weather-night"
icon_2: "mdi:lightbulb-group-off"
icon_3: "mdi:water-boiler"
icon_4: "mdi:YOUR_ICON"
icon_5: "mdi:YOUR_ICON"
color_icon_1: "yellow"
color_icon_2: "blue"
color_icon_3: "purple"
color_icon_4: "green"
color_icon_5: "red"
color_bg_1: "yellow"
color_bg_2: "blue"
color_bg_3: "purple"
color_bg_4: "green"
color_bg_5: "red"
depasseg
(Greg DePasse)
January 5, 2022, 6:08pm
977
I seem to recall something about not using “bold” because of a conflict with Chrome. But maybe not.
mn_box
(Martijn)
January 5, 2022, 7:58pm
978
Don’t know why but for various cards (e.g. graph, vacuum) I am getting this
- type: custom:button-card
template: card_graph
entity: sensor.switch_bg_woon_loox_temperature
variables:
ulm_card_graph_entity: sensor.switch_bg_woon_loox_temperature
ulm_card_graph_name: Woonkamer
ulm_card_graph_color: "var(--google-blue)"
What am I missing? Doing wrong?
micdejo
(Michiel)
January 5, 2022, 8:36pm
979
I have had this happen to me before. The problem is most likely that the entity has been defined twice. In this case you will only have to put your entity in the variables.
This is an example of my card:
variables:
ulm_card_graph_name: Temperatuur Garage
ulm_card_graph_entity: sensor.garage_temperatuur
hope this helps!
mn_box
(Martijn)
January 5, 2022, 9:02pm
980
Jep, that did the trick. Thanks!
And sorry one more. My desktop version is in colors (and looks great), see below
But when using my phone (also on Chrome) I am getting grey only, see below
Seems to be an issue with the style sheet. Any suggestions how to resolve? Profile is one minimist_desktop as I want to see the top sidebar.
CM000n
(Simon)
January 6, 2022, 1:42am
981
It just looks like you didn’t choose the right theme on mobile.
Currently there is no top nav bar display for mobile devices. But you can change it manually if needed by deleting these code lines from the mobile theme: Introduce padding with card-mod-view-yaml by CM000n · Pull Request #92 · UI-Lovelace-Minimalist/UI · GitHub
mn_box
(Martijn)
January 6, 2022, 9:41am
983
My profile is on mobile; on the laptop it works perfectly (also the mobile version) but on my iphone I am missing CSS…
sergio_pt
(Sergio_PT)
January 6, 2022, 9:52am
984
Check the same configuration directly on the phone.
It is possible to have a theme in the PC, and another in the mobile app.
Hello. Can you tell me what the problem might be? Everything works fine, but the drawing of the brightness control does not change (while pressing the action is performed, but the color of the control does not change).
bms
(Bavo)
January 6, 2022, 11:13am
986
andrewkurenkov:
The slider uses the following properties:
mainSliderColor: "rgba(var(--color-theme),0.1)"
mainSliderColorOff: "rgba(var(--color-theme),0.1)"
secondarySliderColor: "var(--color-theme)"
secondarySliderColorOff: "var(--color-theme)"
There could be something wrong with your --color-theme variable.
How do you define your theme?
Many thanks. When I edited the styles, I really touched on the color-theme and indicated the color in the HEX format. It was at the very beginning and I had already gone over everything and completely forgot about it. Thanks again for the tip.
bms
(Bavo)
January 6, 2022, 12:02pm
988
No problem. Were you able to fix it?
mn_box
(Martijn)
January 6, 2022, 12:22pm
989
Got it, style on my phone now works as well! I removed the lines (in the mobile theme) as Simon suggested but I still don’t have the navigation panel. Other solutions?
