could you provide a language file?
Sure, sorry about that.
EN.yaml:
custom_card_heat_pump_language_variables:
variables:
custom_card_heat_pump_off: "Off"
custom_card_heat_pump_dry: "Dry"
custom_card_heat_pump_heat: "Heat"
custom_card_heat_pump_heat_cool: "Auto"
custom_card_heat_pump_cool: "Cool"
custom_card_heat_pump_fan_only: "Fan Only"
0.0.1
Hello dear Minimalist fans!
It took a long time, but we were not idle! This is a huge release!
The changes are massive, especially in the folder structure. Breaking changes to previous versions and configurations are therefore very likely.
Breaking Changes ahead!
This is the first version that supports installation and updating via HACS. Because of this we also had to change our folder structure.
The internal templates for cards, chips and popups are now delivered and updated directly via the integration of HACS. These have therefore migrated from the top folder of our repo to a subfolder of the custom_integration. For a better clarity, these were also further divided thematically. This template code for internal cards, chips and popups can now be found on our repo here: UI/custom_components/ui_lovelace_minimalist/lovelace/ulm_templates at main Ā· UI-Lovelace-Minimalist/UI Ā· GitHub
You can still download and copy the code there manually, but you donāt have to do that, because the custom_integration will do the updating for you from now on.
For the custom_cards we have decided that they can still be downloaded and used by you as needed. They are still on the top level of our repo and can be downloaded from there: UI/custom_cards at main Ā· UI-Lovelace-Minimalist/UI Ā· GitHub
Instructions on how to use them in conjunction with the new custom_integration can be found in our new wiki under Configuration - UI Lovelace Minimalist.
If you had previous Minimalist installations, delete them and use the installation via HACS or manually via the ui_lovelace_minalist.zip file of the latest release. You can back up your own custom cards and then put them back under the ui_lovelace_minimalist\custom_cards folder generated by the integration so that they are still available. Please have a look here: Configuration - UI Lovelace Minimalist
A detailed installation and configuration guide can be found in our brand new wiki:
https://ui-lovelace-minimalist.github.io/UI/setup/download/
Please read everything and follow the instructions step by step.
With the new wiki we finally have the possibility to keep up with the development with the documentation. Please keep in mind that this is still a kind of alpha release and things can change.
We are looking forward to your feedback and suggestions. Please open an issue/discussion on our repoitory (Issues Ā· UI-Lovelace-Minimalist/UI Ā· GitHub) or visit us on our Discord server (UI Minimalist).
Unfortunately, we canāt guarantee that posts here in the forum thread will be addressed.
All changes of this release can be found here: Release 0.0.1 Ā· UI-Lovelace-Minimalist/UI (github.com)
Thank you so much for helping out to keep this UI awesome
AndyVRD, CM000n, Damix48, TJohnson93, actions-user, basbruss, bavo, desty2k, eliseo-juan, httpedo13, jp2creation, juvenalandres, mp-se, pierrecle, revin34, rphlwnk, schumijo, sildehoop, stokkie90, telashton, tkwy-rick, vncnt-dev
@tben , can you please edit the starting post and link to our new wiki at Welcome to the UI-Lovelace-Minimalist wiki! - UI Lovelace Minimalist?
Could be related in how you reach your ha instance. There might be a related when using https or http.
Not sure where I read it. Bit had the same issue on my main instance.
After HACS Installation the Welcome card is no longer working
Hey guys,
Getting this issue when trying to upgrade from the wiki link.
Also, could I get a list of what I need to delete for the upgrade? is it just the minimalist-templates folder?
EDIT
Install though HACS then add the integration
I have just installed the theme via HACS. All seemed to work well, except, I would have expected to be able to select the Minimalist theme in my profile, but it doesnāt appear (no theme appear, as it s a new install of HA)
So mine works on mobile but not desktop, Iāll poke around
I assume that you have enabled themes in your Lovelace config as well? Unfortunately a custom_component canāt do that for you. Maybe we should include this in our documentation.
You need an entry in your configuration.yaml
like this:
# https://www.home-assistant.io/integrations/frontend/
frontend:
themes: !include_dir_merge_named themes
Hello! Thanks for creating such a beautiful card!
Been trying to use it for a few weeks but havenāt been able
button_card_templates.yaml
list_items_climate:
styles:
card:
- background-color: transparent
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"item1 item2 item3"'
- grid-template-columns: 1fr 3fr 1fr
- grid-template-rows: min-content
- column-gap: 7px
widget_icon_signal:
tap_action:
action: toggle
color: var(--google-grey-500)
show_icon: true
show_name: false
icon: >
if (entity.attributes.fan_mode == 'LOW')
return 'mdi:network-strength-outline';
else if (entity.attributes.fan_mode == 'LOW_MID')
return 'mdi:network-strength-1';
else if (entity.attributes.fan_mode == 'MID')
return 'mdi:network-strength-2';
else if (entity.attributes.fan_mode == 'MID_HIGH')
return 'mdi:network-strength-3';
else if (entity.attributes.fan_mode == 'HIGH')
return 'mdi:network-strength-4';
else if (entity.attributes.fan_mode == 'NATURE')
return 'mdi:leaf';
else
styles:
card:
- box-shadow: none
- padding: 0px
#- background-color: 'rgba(var(--color-theme),0.05)'
- border-radius: 100%
- place-self: center
- height: 42px
- width: 42px
grid:
- grid-template-areas: '"i"'
icon:
- color: "rgba(var(--color-theme),0.9)"
state:
- styles:
icon:
- color: "#ffffff"
value: heat
- styles:
icon:
- color: "#ffffff"
value: dry
- styles:
icon:
- color: "#ffffff"
value: cool
- styles:
icon:
- color: "#ffffff"
value: fan_only
- styles:
icon:
- color: "#ffffff"
value: heat_cool
- styles:
icon:
- color: "#ffffff"
- display: none
card:
- display: none
value: "off"
climate_temperature_text:
#tap_action:
#action: toggle
show_icon: false
show_name: true
show_label: true
if (entity.state == 'off')
return entity.attributes.current_temperature;
else
return entity.attributes.temperature;
label: "Ā°C"
styles:
card:
- box-shadow: none
- padding: 0px
- height: 42px
- font-size: 20px
- font-weight: bold
grid:
- grid-template-areas: '"n" "l"'
name:
- font-size: 25px
- align-self: center
label:
- font-size: 15px
state:
- styles:
name:
- color: "#ffffff"
label:
- color: rgba(255,255,255,0.3)
value: heat
- styles:
name:
- color: "#ffffff"
label:
value: dry
- styles:
name:
- color: "#ffffff"
label:
value: cool
- styles:
name:
- color: "#ffffff"
label:
value: fan_only
- styles:
name:
- color: "#ffffff"
label:
value: heat_cool
widget_icon_circle_climate:
tap_action:
action: toggle
show_icon: true
show_name: false
styles:
card:
- box-shadow: none
- padding: 0px
- background-color: "rgba(var(--color-theme),0.05)"
- border-radius: 50%
- height: 42px
- width: 42px
grid:
icon:
state:
- value: "heat"
styles:
card:
- background-color: "#ffffff"
icon:
- color: rgba(var(--color-yellow),1)
- value: "dry"
styles:
card:
icon:
- color: rgba(var(--color-light-yellow),1)
- value: "cool"
styles:
card:
icon:
- color: rgba(var(--color-blue),1)
- value: "fan_only"
styles:
card:
icon:
- color: rgba(var(--color-grey),1)
- value: "heat_cool"
styles:
card:
icon:
- color: rgba(var(--color-green),1)
climate_text_only:
tap_action:
action: more-info
show_icon: false
label: >-
var climate_mode = entity.state;
styles:
card:
- border-radius: 8px
- padding: 5px 0
state:
- styles:
card:
- background-color: rgba(var(--color-yellow),1)
img_cell:
#- background-color: rgba(var(--color-yellow), 0.2)
- background-color: rgba(255,255,255,0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: heat
- styles:
card:
- background-color: rgba(var(--color-light-yellow),1)
img_cell:
#- background-color: rgba(var(--color-light-yellow), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: dry
- styles:
card:
- background-color: rgba(var(--color-blue),1)
img_cell:
#- background-color: rgba(var(--color-blue), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: cool
- styles:
card:
- background-color: rgba(var(--color-grey),1)
img_cell:
#- background-color: rgba(var(--color-grey), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: fan_only
- styles:
card:
- background-color: rgba(var(--color-green),1)
img_cell:
#- background-color: rgba(var(--color-green), 0.2)
label:
- color: "#ffffff"
name:
- color: "#ffffff"
value: heat_cool
climate_icon_only:
#tap_action:
# action: toggle
# action: call-service
# service: script.step_hvac_mode
# service_data:
# climate_id: "[[[ return variables.entity ]]]"
show_name: false
icon: |
var icon = 'mdi:snowflake';
if (climate_mode == 'heat'){
var icon = 'mdi:fire';
} else if(climate_mode == 'dry'){
var icon = 'mdi:water-percent';
} else if(climate_mode == 'cool'){
} else if(climate_mode == 'fan_only'){
var icon = 'mdi:fan';
} else if(climate_mode == 'heat_cool'){
var icon = 'mdi:autorenew';
} else {
var icon = 'mdi:power';
return icon ;
styles:
card:
state:
- styles:
card:
icon:
#- color: rgba(var(--color-yellow),1)
- color: "#ffffff"
img_cell:
value: heat
- styles:
card:
icon:
#- color: rgba(var(--color-light-yellow),1)
- color: "#ffffff"
img_cell:
value: dry
- styles:
card:
icon:
#- color: rgba(var(--color-blue),1)
- color: "#ffffff"
img_cell:
value: cool
- styles:
card:
icon:
#- color: rgba(var(--color-grey),1)
- color: "#ffffff"
img_cell:
value: fan_only
- styles:
card:
icon:
#- color: rgba(var(--color-green),1)
- color: "#ffffff"
img_cell:
value: heat_cool
- styles:
card:
- background-color: rgba(var(--color-theme),0.05)
icon:
- color: rgba(var(--color-theme),0.9)
img_cell:
value: "off"
list_items_climate_three:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- column-gap: 7px
climate_buttons_with_favorite:
variables:
entity: climate.default
show_name: false
show_icon: false
styles:
card:
- border-radius: 20px
- box-shadow: var(--box-shadow)
- padding: 12px
# - background-color: |
# [[[variables.entity
# if (states[variables.entity].state == "heat"){
# return 'rgba(var(--color-yellow),1)';
# } else if (states[variables.entity].state == "dry"){
# return 'rgba(var(--color-light-yellow),1)';
# } else if (states[variables.entity].state == "cool"){
# return 'rgba(var(--color-blue),1)';
# } else if (states[variables.entity].state == "fan_only"){
# return 'rgba(var(--color-grey),1)';
# } else if (states[variables.entity].state == "heat_cool"){
# return 'rgba(var(--color-green),1)';
# } else {
# return 'white';
grid:
- grid-template-areas: '"item1" "item2"'
- grid-template-rows: min-content min-content
- row-gap: 12px
state:
- value: "heat"
styles:
card:
- value: "dry"
styles:
card:
- value: "cool"
styles:
card:
- value: "fan_only"
styles:
card:
styles:
card:
custom_fields:
item1:
card:
template: list_items_climate_three
type: custom:button-card
custom_fields:
item1:
card:
entity: "[[[ return variables.entity ]]]"
tap_action:
service_data:
template:
- icon_info
- climate_icon_only
item2:
card:
name: "[[[ return variables.name ]]]"
template:
- icon_info
- climate_text_only
item3:
card:
tap_action:
service: script.step_fan_mode
service_data:
template: widget_icon_signal
item2:
card:
custom_fields:
item1:
card:
icon: mdi:minus
tap_action:
action: >
if (entity.attributes.temperature == '16')
return 'none';
else
return 'call-service';
service: script.temperature_down
service_data:
value: 1
template: widget_icon_circle_climate
item2:
card:
tap_action:
action: more-info
template: climate_temperature_text
item3:
card:
icon: mdi:plus
tap_action:
action: >
if (entity.attributes.temperature == '30')
return 'none';
else
service: script.temperature_up
service_data:
value: 1
ui_lovelace.yaml
- title: Office
resources:
- url: /local/button-card.js
type: module
cards:
- type: vertical-stack
cards:
- type: markdown
content: >
## Victor's Office
card_mod:
style: |
ha-card {
font-family: Roboto;
height:50px !important;
box-shadow: none;
background: none;
text-align: center;
justify-content: center;
margin: 0 auto;
padding: 1em;
- type: 'custom:button-card'
template: climate_icon_only
variables:
entity: climate.office_ac
Any ideas on how to fix it?
Finally , i get this media card working using the code of the custom_card_sonos.
Downloaded the new update through HACS and went through everything to understand the new directory structure. Can anyone get the new card_light
template to work? From the documentation they merged a bunch of light templates (i.e. card_light_slider
), but for me changing the template to card_light
and adding the ulm_card_light_enable_slider
attribute in the yaml doesnāt do anything. Same with the other variables from the documentation.
Hi, this looks very nice!
I have installed for the first time via HACS, everything seemed to go ok but when I navigate to the dashboard in the sidebar, all I see is a card for the Sun. Should I see any other default cards?
Do I need to edit the YAML for every card I should add?
Hi i have installed the new version on HACS, but i cant select the Minimalist theme on settings ?
Nothing about this on Installation - UI Lovelace Minimalist
Edit : Ok fix with
frontend:
Maybe add these on setup/github wiki ?
And on ui_lovelave_minimalist->custom_cards i have nothing, i need to download all custom cards i want, manually ?
Can you share here or in a PM your ui-lovelace.yaml
or the file which contains your lovelace dashboard with card_light
so I can get a better understanding of what is going wrong
Yes, your auto-generated dashboard only consists for now of a card with the Sun. You can remove that card in the config/ui-lovelace-minimalist/dashboard/ui-lovelace.yaml
file and add your own cards with all the templates provided by the integration
Can you share with a code
Hey, thanks!
One the Wiki it says about the prerequisites and mentioned the HACS install method should install them. I did tick the box which said it can install them, however I am unsure it has done anything? Should I just go through and install them in HACS?
" PrerequisitesĀ¶
In order to function correctly, the UI Lovelace Mininmalist āThemeā requires some additional integrations and lovelace resources. While we can install most of these for you during the installation via HACS, you will also have to install and configuring them manually in advance for a manual installation."
