🌻 Lovelace UI • Minimalist
@LRvdLinden exactly like this
and peace of your yaml file?
Easier with a gif :slight_smile:
And here’s the file
you can fix it with this code above your chips
        - type: custom:button-card
          template: spacer
          variables:
            height: 50px
play a little with the 50px
I saw this also in my own install.
The thing is, it its very hard to fix.
Also in the other themes it doesn’t do this.
Seems my implementation of the tabbar breaks a few things.
Its not an spacing issue, there is some whit the sizing of the tabbar that’s interfering whit an stock Home-assistant gui.
Weird, I tried dmatik’s version and that does not jump like yours but I do see now that dmatisk’s version does have a pretty big gap at the top.
Even with @LRvdLinden fix the bar moves a couple of pixels as you can see in my gif above
Hey guys,
Great work one more time :slight_smile: i just made the integration by hacs but i do not understand with this happens ?
Do any of you have the same problem ?
That true but his theme does not have an rounded shape behind an active tab and that’s one of the things that breaks the theme.
The goal was to get this design to work : https://github.com/UI-Lovelace-Minimalist/UI/issues/346
It’s a issue with Chrome browser, in all other browsers and companion apps it shows just fine.
Thanks for that fast reply but Here i am on Android Ha app. Cache is still empty but seems still Not working.
OK i think you have another problem, i don’t have Android here so i can’t check for it. Can you check if it works in Firefox?
It looks damn beautiful it’s a shame it bugs. Read the issue and they might be right that it could be an iOS or iOS HA app issue.
no problem on iOS with this theme. I modified it a little
minimalist-mobile-tapbar:
  # Journal
  state-icon-color: "rgb(var(--color-theme))"
  border-radius: "20px"
  error-color: "var(--google-red)"
  warning-color: "var(--google-yellow)"
  success-color: "var(--google-green)"
  info-color: "var(--google-blue)"
  divider-color: "rgba(var(--color-theme),.12)"
  accent-color: "var(--google-yellow)"
  card-mod-theme: "minimalist-mobile-tapbar"
  header-height: "56px"
  card-mod-view-yaml: |
    "*:first-child$": |
      #columns .column > * {
        padding-left: 5px;
        padding-right: 5px;
        padding-bottom: 5px;
  # Move navbar
  card-mod-root-yaml: |
    ha-tabs$: |
      #tabsContent {
            width: 97%;
      @media (orientation: portrait) {
        a.menu-link[target="_blank"], ha-button-menu, ha-menu-button, [main-title] {
          display: none !important;
        app-toolbar {
          padding-right: 0px;
          padding-left: 0px;
      ha-app-layout{
        transform: initial;
        padding: 0 !important;
        margin: 0 !important;
        width: 100%;
      app-header {
        top: auto;
        bottom: 0;
        box-shadow: var(--footer-shadow);
        position: fixed;
      app-toolbar {
        transform: none;
        padding-top:10px !important;
        padding-bottom: calc(env(safe-area-inset-bottom) + 2px);
        height: 100px !important;
      #view {
        margin-top: calc(-71px + env(safe-area-inset-top)) !important;
        width: 100%;
        min-height: 100%;
        height: auto;
        padding-bottom: calc(env(safe-area-inset-bottom) + 50px);
      ha-tabs {
        --paper-tabs-selection-bar-color: var(--header-tab-indicator-color);
        --mdc-icon-size: 26px;
        display: flex;
        justify-content: space-between;
        padding: 0 10px;
      paper-tab[aria-selected=true] {
        color: var(--header-active-tab-color);
        background-color: var(--header-active-tab-bg-color)
      paper-tab {
        color: var(--header-all-tabs-color);
        border-radius: 35px;
        height:50px;
        /*width: calc(100% / 4);*/
        padding-left: 20px;
        padding-right: 20px;
  # Color themes
  modes:
    light:
      # Header / Footer
      header-active-tab-color: "rgba(61, 90, 254, 1)"
      header-active-tab-bg-color: "rgba(61, 90, 254, .3)"
      header-all-tabs-color: "var(--paper-item-icon-color)"
      header-tab-indicator-color: "rgba(0, 0, 0, 0)"
      app-header-text-color: "var(--primary-text-color)"
      app-header-background-color: "var( --ha-card-background, var(--card-background-color, white) )"
      paper-tabs-selection-bar-color: "var(--primary-text-color)"
      footer-shadow: "0px -1px 3px 0px rgba(0,0,0,0.12)"
      # background and sidebar
      card-background-color: "#FAFAFA"
      primary-background-color: "#EFEFEF"
      secondary-background-color: "#EFEFEF"
      # text
      primary-text-color: "#212121"
      # main interface colors
      primary-color: "#434343"
      google-red: "#F54436"
      google-green: "#01C852"
      google-yellow: "#FF9101"
      google-blue: "#3D5AFE"
      google-violet: "#661FFF"
      google-grey: "#BBBBBB"
      color-red: "245, 68, 54"
      color-green: "1, 200, 82"
      color-yellow: "255, 145, 1"
      color-blue: "61, 90, 254"
      color-purple: "102, 31, 255"
      color-grey: "187, 187, 187"
      color-pink: "233, 30, 99"
      color-theme: "51,51,51"
      color-background-yellow: "250, 250, 250"
      color-background-blue: "250, 250, 250"
      color-background-green: "250, 250, 250"
      color-background-red: "250, 250, 250"
      color-background-pink: "250, 250, 250"
      color-background-purple: "250, 250, 250"
      color-yellow-text: "var(--primary-text-color)"
      color-blue-text: "var(--primary-text-color)"
      color-green-text: "var(--primary-text-color)"
      color-red-text: "var(--primary-text-color)"
      color-pink-text: "var(--primary-text-color)"
      color-purple-text: "var(--primary-text-color)"
      opacity-bg: "1"
      # slider
      slider-color: "rgb(var(--color-blue))"
      slider-bar-color: "rgba(var(--color-blue),0.38)"
      # cards
      box-shadow: "0px 2px 4px 0px rgba(0,0,0,0.16)"
      ha-card-box-shadow: "var(--box-shadow)"
      # sidebar
      sidebar-selected-text-color: "var(--google-red)"
      sidebar-selected-icon-color: "var(--google-red)"
      sidebar-text-color: "#80868b"
      # switch
      switch-checked-color: "var(--google-blue)"
      # media player
      mini-media-player-accent-color: "var(--google-red)"
    dark:
      # Header / Footer
      header-active-tab-color: "rgba(255, 145, 1, 1)"
      header-active-tab-bg-color: "rgba(255, 145, 1, .3)"
      app-header-background-color: "var( --ha-card-background, var(--card-background-color, rgb(29, 29, 29)) )"
      card-background-color: "#1D1D1D"
      primary-background-color: "#121212"
      secondary-background-color: "#121212"
      # text
      primary-text-color: "#DDDDDD"
      primary-color: "#89B3F8"
      google-red: "#F18B82"
      google-green: "#80C994"
      google-yellow: "#FCD663"
      google-blue: "#89B3F8"
      google-violet: "#BB86FC"
      color-red: "241, 139, 130"
      color-green: "128, 201, 148"
      color-yellow: "252, 214, 99"
      color-blue: "137, 179, 248"
      color-theme: "221,221,221"
      color-background-yellow: "var(--color-yellow)"
      color-background-blue: "var(--color-blue)"
      color-background-green: "var(--color-green)"
      color-background-red: "var(--color-red)"
      color-background-pink: "var(--color-pink)"
      color-background-purple: "var(--color-purple)"
      color-yellow-text: "var(--color-yellow)"
      color-blue-text: "var(--color-blue)"
      color-green-text: "var(--color-green)"
      color-red-text: "var(--color-red)"
      color-pink-text: "var(--color-pink)"
      color-purple-text: "var(--color-purple)"
      opacity-bg: "0.1"
      # floating button text color
      mdc-theme-on-secondary: "var(--card-background-color)"
      # Sidebar
      sidebar-selected-text-color: "rgb(var(--color-blue))"
      sidebar-selected-icon-color: "rgb(var(--color-blue))"
      # Slider
      # card
      box-shadow: "none"
      # media player
      mini-media-player-accent-color: "var(--google-blue)"
      # Journal
Do you use that spacer at the top then or do it just work out of the box like that?
Did somebody already create an input_select card for UI? Keen to set-up a couple of actions with selection helpers as inputs (e.g. where do I play a certain TTS, where do I flash certain lights). Open to suggestions!
@mn_box I can give you the code, is still much saved statically
It works in Firefox :wink:
I’m a newby here and feel a little bit stupid. Can somebody please tell me which template to use for a simple on/off button with state (switch)?
you can use this one:
https://ui-lovelace-minimalist.github.io/UI/usage/cards/card_input_boolean/
