Lovelace UI not loading but the rest of Home Assistant seems to be working
Hi, it appears that my problem is different and it got resolved after I restarted the OS. Restarting the core alone doesn’t solve the problem.
Going through the log files in detailed again and I noticed there was instance my camera lost connection and I suspect there either my router got restarted itself or my internet connection has restarted and causing the HA socket connection screw up.
Anyway, my HA is now back online. Thanks for the comment and reply.
I found a solution to my problem. Not sure if this will help others but in my case it was related to the Modern Forms Smart Fan Integration. I added the automation shared here to auto reset the fan controller and my lockups went away. Over 2 weeks now with not 1 single issue.
