That didnt help:-(
- title: Sonarr
cards:- type: custom:upcoming-media-card
entity: sensor.sonarr_upcoming_media
That didnt help:-(
There was a problem in the max items config. Thanks to @thomasloven for finding it and providing the fix. Just updated the card.
Worked fine! Thanks a lot:-)
/Ola
Thanks - working a treat now
what does this mean? i’ve updated my cards and restarted
Sun Oct 28 2018 15:25:44 GMT-0700 (Pacific Daylight Time)
http://192.168.1.214:8123/local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.2:19:45 Uncaught TypeError: Cannot read property ‘icon’ of undefined
title: Home
resources:
- url: /local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.2
type: js
- url: /local/custom_ui/ecobee-card.js
type: js
# This file was automatically generated by lovelace_migrate.py
# https://github.com/dale3h/python-lovelace
- title: Home
cards:
- type: entities
title: Livingroom Receiver
show_header_toggle: false
entities:
- switch.music
- type: entities
title: Downstairs Receiver
entities:
- switch.music2
- type: media-control
entity: media_player.plex_plex_f4m1rdkw68cylmtyyie82qqg
entity: media_player.plex_plex_234cff3fecab88e9_com_plexapp_android
- type: custom:ecobee-card
entity: climate.thermostat
Is the sonarr sensor working, if so what data does it show?
Make sure you’re using the latest version of the card and components.
the latest version of the card is 0.2.7, but your lovelace code shows v=0.2.2
sensor.sonarr_upcoming_media 0 data: [] friendly_name: Sonarr_Upcoming media
No… nothings changed as farf as api, ip address or ports, and my config.yaml is correct as far as settings to connect to sonarr
- platform: yr
- platform: sonarr_upcoming_media
api_key: e69debdbf70d4be2b229aeda8201a975
host: 192.168.1.189
port: 8989
days: 2
ssl: false
Do you have any tv shows scheduled to air in the next 2 days?
Not until Tuesday, i changed days to 7, will reboot…
Think I still need to change how the components handle no upcoming, but let me know if that does it for you.
I agree. It works, but if there’s no upcoming media in the future, itll show the redbox, looks like there needs to be a catch all exception
Already fixed it. Will be an update for components and cards uploaded in a few minutes.
Just updated. Refresh and then I noticed first upcoming show (episode) disappeared. Something is not right.
Did you restart? The components updated too.
Just restarted, all seems fine now. As I should have understood. Thanks!
Hi - had Radarr working this weekend, the sensor component suddenly stopped working (is not being loaded) - am running .81.1. Just tried updating to the latest release from 10/28 , i’m seeing the following error in the logs:
2018-10-29 19:25:58 ERROR (MainThread) [homeassistant.components.sensor] radarr_upcoming_media: Error on device update!
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 251, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/app/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/sensor/radarr_upcoming_media.py", line 202, in update
for x in tmdbjson['genres']:
KeyError: 'genres'
Odd. Hopefully this is just a hiccup with that movie in themoviedb.org and it’s just missing genres.
Updated both cards to account for it if that is the case. Let me know if it helps.
Wow - you are ninja fast, that worked! Thank you! I saw in an earlier post you had a similar fix for a different missing attribute, looks like the component doesn’t like missing attributes. Thanks again for the quick fix!
edit: it’s odd I checked back in the sensor status and all of the retrieved movies have genres… Not sure why that made it hiccup, but your fix worked.
Dear all…I try getting this running bit my sensor always shows 0 … What do I have to to on the side of radar to push upcoming media ? Sorry for dumb question
Edit: I had to add a list …but it would be good having a shirt introduction how to setup radarr to get those information
Is it somehow possible to also get a trailer link ?
