Lovelace: Upcoming Media Card
Are you using storage or yaml mode?
yaml mode!
Think I see the issue. You have entity: sensor.plex_upcoming_media in your card config, but the sensor is actually called sensor.plex_recently_added
Wow, you have a sharp eye, it works!!
Thanks for your help,
Greetings,
Harry
Great module! :slight_smile:
Hi, tried setup Plex and Trakt but get errors on both :frowning:
Tried going trough all previous posts, but couldn’t find a solution.
Plex:
I don’t get any sensor but get downloaded posters in www/custom-lovelace/upcoming-media-card/images/plex.
My log shows this error:
Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 365, in _async_add_entity
await entity.async_update_ha_state()
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 225, in async_update_ha_state
self._async_write_ha_state()
File “/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 256, in _async_write_ha_state
device_attr = self.device_state_attributes
File “/config/custom_components/plex_recently_added/sensor.py”, line 139, in device_state_attributes
media.get(‘parentIndex’, ‘’), media.get(‘index’, ‘’))
ValueError: Unknown format code ‘d’ for object of type ‘str’
Trakt
I get my sensor but it’s quite empty - only the number of shows (state) is correct.
data: [{“title_default”: “$title”, “line1_default”: “$episode”, “line2_default”: “$release”, “line3_default”: “$rating - $runtime”, “line4_default”: “$number - $studio”, “icon”: “mdi:arrow-down-bold”}]
unit_of_measurement: shows
friendly_name: Trakt Upcoming Calendar
icon: mdi:calendar
Hope anybody can help.
For Plex could you follow the troubleshooting guide to get the raw api response and PM it to me. It looks like you have a show that’s reporting something strange for it’s season or episode number.
Unsure about trakt, any idea @iantrich?
@onkelfarmor what version of HA are you on?
@iantrich Hass.io 91.4 - also didn’t work on 91.3.
Can you log your issue on the trakt plugin github repo so I can better track this and provide as much detail as possible? Thanks.
@iantrich done
Updated my components for Radarr, Sonarr, and Plex with a __init___.py file for changes in 0.92.0. Also a small fix for Plex to fix image downloading in some cases.
Just updated to 0.92
Even after updating your components I still get these errors:
Integration radarr_upcoming_media not found when trying to verify its sensor platform.
Integration sonarr_upcoming_media not found when trying to verify its sensor platform.
Integration plex_recently_added not found when trying to verify its sensor platform.
I ran into the same issue myself and a system reboot cleared it up.
Even after a reboot… same issue. Any troubleshooting tips?
Couple of things to try.
Make sure there is a file called __init__.py in the same folder as sensor.py for each component. If not either grab the one off github or create your own blank file called __init__.py in those folders.
Delete the __pycache__ folder in each of the components folders.
Reboot
I did exactly that! Created ‘init.py’ in all 3 folders and rebooted. I don’t see any ‘pycache’ files using configurator.
After 3 reboots it now works again! Thanks for replying anyway!
I upgraded to 0.92 and it broke this card. I sse this in the logs
Unable to set up dependencies of kodi_recently_added. Setup failed for dependencies: kodi
Unable to prepare setup for platform kodi_recently_added: Could not set up all dependencies.
I tried adding the kodi component but it didn’t help…
I see this in states as well…
title: Invalid config
message: The following components and platforms could not be set up:
  • kodi
  • kodi_recently_added.sensor
Please check your config.
I released a new version that may fix the issue. I haven’t yet upgraded to 0.92 so I’m unable to test if the fix worked in v0.2.4. Give that a try. If it does not could you open up an issue on github with all pertinent information? https://github.com/custom-components/sensor.kodi_recently_added/issues
