That all looks good, what does your lovelace code look like?
Also, try a hard browser refresh. Usually, Ctrl + Shift + R.
didn,t work…
my cards:
- type: vertical-stack cards: - type: entities title: Sonarr show_header_toggle: true entities: - sensor.sonarr_queue - sensor.sonarr_series - sensor.sonarr_wanted - sensor.sonarr_upcoming - type: custom:upcoming-media-card title: Sonarr Upcoming service: sonarr image_style: fanart clock: 12 max: 10 # show_color: '#ffffff' # episode_color: '#000000' # time_color: '#f41103' # downloaded_color: '#000000' # ribbon_color: '#03a9f4' # border_color: 'grey' - type: vertical-stack cards: - type: entities title: Radarr show_header_toggle: true entities: - sensor.radarr_status - sensor.radarr_movies - sensor.radarr_commands - sensor.radarr_upcoming - type: custom:upcoming-media-card title: Radarr Upcoming service: radarr image_style: fanart title_color: '#fff' extra_color: '#fff' clock: 12 max: 10 # show_color: '#ffffff' # episode_color: '#000000' # time_color: '#f41103' # downloaded_color: '#000000' # ribbon_color: '#03a9f4' # border_color: 'grey'
Looking further into your error.
http://192.168.1.9:8123/local/custom-lovelace/upcoming-media-card/upcoming-media-card.js:192:31 Uncaught TypeError: Cannot read property 'match' of undefined
Just noticed its complaining about an error with “match” on line 192 of the code. There have been 4 updates to the card since the last time that line contained “match”.
I believe you need to update your card to the latest.
Or you need to make sure you’re adding a new version number to the resources portion of your lovelace. Might also need to delete your browser cache. Your card is definitely using a version from October 3rd or earlier.
upcoming-media-card is not listed under Custom Cards so it is not being updated. Your components look fine though.
oh… I thought it was also part of the custom updater…
It is.
Do these lines exist in your configuration.yaml?
custom_updater:
track:
- components
- cards
It should…
custom_updater:
card_urls:
- https://raw.githubusercontent.com/bramkragten/custom-ui/master/updater.json
- https://raw.githubusercontent.com/kalkih/mini-media-player/master/tracker.json
track:
- components
- cards
Yeah, not sure why your custom updater isn’t picking it up. I would just manually update the card and add the current version number in your lovelace yaml resources.
- url: /local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.2
type: js
How is that option configured? It seems to default to hidden.
NVM I found it’s added to config yaml. When I changed it to true I got extra cards so it seems to default to false despite the config instructions saying it defaults to true. I also checked the sensor and it was only showing 1 release before I edited config yaml and added theatres: true and I now see 4 in upcoming media radarr.
You’re right, I meant to have it set to true by default, but it was indeed false. I’ve made that quick fix.
Love your work and responsiveness!!!
Just updated everything to the latest version and I get :-
http://192.168.11.84:8123/local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.6:247:40 Uncaught TypeError: Cannot read property 'airdate' of undefined
10:01 PM components/system_log/__init__.py (ERROR)
http://192.168.11.84:8123/local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.6:16:49 Uncaught TypeError: Cannot read property 'attributes' of undefined
9:58 PM components/system_log/__init__.py (ERROR)
What am I missing ? - I checked both sensors and it looks like all the data is there…
Yep restarted and tried manually upping the version on the resources entry.
Data for radar :
data: [{“title_default”: “$title”, “line1_default”: “$release”, “line2_default”: “$genres”, “line3_default”: “$rating - $runtime”, “line4_default”: “$studio”, “icon”: “mdi:arrow-down-bold”, “airdate”: “2018-10-30T00:00:00Z”, “release”: “Available $day”, “title”: “Some Movie”, “flag”: true, “runtime”: 94, “genres”: “Action”, “studio”: “STX Entertainment”, “rating”: “\u2605 5.7”, “poster”: “https://image.tmdb.org/t/p/w500/ptSrT1JwZFWGhjidnIUGrh.jpg”, “fanart”: “https://image.tmdb.org/t/p/w780/eTwftrInxzZTSLUkXJUVud.jpg”}]
friendly_name: Radarr Upcoming media
I’ve commented out radar/sonarr alternately to see which is causing the issue, but both have the error.
Whats your lovelace yaml for the cards look like?
resources:
- url: /local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.6
type: js
entity: sensor.radarr_upcoming_media
text_shadows: false
I had “service: radarr” instead of entity previously, but when it stopped working after the update, i checked the docs and noticed it now seems to be entity - changing it didn’t help though.
