I was simply focus on the card code and didn’t look at the bigger picture. Something like this?
type: picture-elements
elements:
- type: state-label
entity: 'light.pc_lights'
style:
top: 32%
left: 40%
card_mod:
style: |
:host {
color: {{ 'red' if is_state(config.entity, 'on') else 'green' }}
image: /local/your_pic.png
What you are doing is:
- do not define a color by a native “style” option
- define a color by card-mod.
Alternative way - what I am using and which I recommend:
- define a color = variable in the native “style”
- define a variable by card-mod.
Gotcha, I’ll try that method.
Is this the method you suggested?
card_mod:
style: |
ha-card {
{{ '--var:red' if is_state('light.pc_lights', 'on') else '--var:blue' }}
elements:
- type: state-label
entity: sensor.basement_sensor
style:
top: 32%
left: 40%
font-size: 40px
color: var(--var)
@kosakenzipfel, the same code still works in my setup.
First, please make sure config-template-card is used and indentations are correct.
As suggested, using config-template-card may not be the best way.
If this still does not work for you, please consider trying suggestions in other helpful posts here.
Thank you all. It works now
