Not at the moment… You might be able to set it in the fontface setting, but I’m not sure. If you can’t then I’ll have a look at adding a setting
So if I use gmap location sharing there is no way to have it show “travelling”?
Is there a way to add a background image?
Just installed this, and generally loving it. It’s a shame it seems to have gone dark a couple years ago. To echo a couple others, my wishlist would include:
- Background image
- Fullscreen version
- Entity pictures
- HACS integration
Wish I had the programming skills to modify it myself.
Yes, me too! JavaScript is horrible and it took me a lot of effort to get this working, the code is not exactly elegant
I might have another look at it at some point as most of those things are on my wish list too (I’m still using it), but if anyone with superior JavaScript skills wants to improve it feel free!
I’m probably just a thick n00b, but….
It seems custom-updater is deprecated.
I just can’t figure out where to put the weasley card now and how to add it to a dashboard.
I found some reference to ui-lovelace-card.yaml and ui-lovelace.yaml but those do not exist on my HA yellow
Can anyone point me in the right direction?
I have weasley-card.js and weaslyconfig.txt under /config/www/custom-lovelace.
I created the “custom-lovelace” folder myself under www and put the font and js file in there. I needed to ensure I set it to truetype rather than opentype because that was the only downloadable Blackadder font I could find. The way to add the resources has changed in HA, which means instead of performing step 2 in the installation you need to go to Settings->Dashboards and then click the vertical ellipsis in the top right corner where you’ll find “resources” an option - go in there and add the URL from step 2 as a Javascript module.
Thought I would add my solution to this as I never got this version to work.
Mine is a bit hacky but it works. NB If the “hand” is outside the clock face then they are in a place i have not set up a condition for.
Using a little MS paint and PowerPoint I made three pictures. The clock face (Weasley clock.png), and 2 Clock hands with Cartonified faces as png files (E%20clock%20hand3.png and A%20clock%20hand3.png) and uploaded them to the “/local/images/” folder.
Then using a combination of:
- Picture Element card
- card_mod from hacs (🔹 Card-mod - Super-charge your themes!)
- Template sensor - helper
- Lots of Zones
I made my version which, while a work in progress, does work.
It rotates the “hands” of the “clock” to pont at a location name based off the zones i have set up in home assistant.
- Picture Element Card (with CardMods applied)
The code below contains 2 sensors which modify the location of the hands. How this done is shown in the next section of code.
type: picture-elements
card_mod:
style: |
ha-card {
--my-transform-style: {{states('sensor.locationclocka')}};
--my-transform-style2: {{states('sensor.locationclocke')}};
elements:
- type: image
image: /local/images/A%20clock%20hand3.png
style:
top: 100%
left: 85%
transform: var(--my-transform-style)
- type: image
image: /local/images/E%20clock%20hand3.png
style:
top: 100%
left: 85%
transform: var(--my-transform-style2)
image: /local/images/Weasley clock.png
Is a sensor which output contains text detailing how i want the position of the “clock hand” to be changed in the picture element card.
Each Person has their own “hand”, and because i don’t want them to overlap when people are in the same position each.
These Translations and rotations are specific to the pictures I used so will have to be tweaked, at laborious extent, for ech individual and picture.
(i have edited the below slightly to anonymize this as much as possible)
Person 1 ‘sensor.locationclocka’
translate(-280%,-105%) rotate(-0.03turn)
{% elif states('person.person1') == 'Town centre' %}
translate(-280%,-105%) rotate(0.14turn)
{% elif states('person.person1') == 'Work' %}
translate(-280%,-105%) rotate(0.3turn)
{% elif states('person.person1') == 'not_home' %}
{% if states('sensor.home_aperson1_direction_of_travel') == 'stationary' %}
translate(100%,-120%) rotate(-0.1turn)
{% else %}
translate(-280%,-105%) rotate(0.47turn)
{% endif %}
{% elif states('person.person1') == 'Sister in laws house' %}
translate(-280%,-105%) rotate(0.64turn)
{% elif states('person.person1') == 'Mother in laws house' %}
translate(-280%,-105%) rotate(0.80turn)
{% endif %}
person 2 ‘sensor.locationclocke’
{% if states('person.Person2') == 'home' %}
translate(-278%,-110%)rotate(0.03turn)
{% elif states('person.Person2') == 'Town centre' %}
translate(-278%,-110%) rotate(0.20turn)
{% elif states('person.Person2') == 'word' %}
translate(-278%,-110%) rotate(0.36turn)
{% elif states('person.Person2') == 'not_home' %}
{% if states('sensor.home_Person2_direction_of_travel') == 'stationary' %}
translate(-650%,-130%) rotate(0.1turn)
{% else %}
translate(-278%,-110%) rotate(0.53turn)
{% endif %}
{% elif states('person.Person2') == 'Sisters House' %}
translate(-278%,-110%) rotate(0.70turn)
{% elif states('person.Person2') == 'Mothers house' %}
translate(-278%,-110%) rotate(0.86turn)
{% endif %}
Hope this helps/inspires someone.
I didn’t understand what’s the Travelling state. For me, when I’m not in any Zone, I’m always at Lost.
How can I make the Travelling to work?
Hi, the “travelling” status is broken at the moment - it was written specifically for the location tracker that I was using at the time, and doesn’t really work with anything else.
I’m planning on rewriting it to work with the “Person” entities instead, which should work whatever location tracker you use, but I haven’t started that yet.
Can you explain the logic for traveling? I don’t think the Person have a travelling attribute…
I’ve not looked that closely at it yet.
However someone else posted a possible solution:
Maybe this is for another thread, but can someone walk me through how to change the color of the clock face and/or the other colors that aren’t changed in the card editor?
If anybody would like to test it, I’ve released a beta version with two major changes:
- Entity pictures! This is disabled by default, but there’s now a config flag to enable it - if you have pictures set for your “People” in HA then it should pick them up and render them on the end of the clock hands. I had to move the zone text out towards the edge of the clock to make a bit of room, and I’m still working on layout so let me know what you think.
- Reworking of the “travelling” code to pick up e.g. the speed attribute from e.g. phone devices. This uses the location tracker that’s set as the “source” attribute for each person. Still very much a work in progress this, there seems to be an issue if you don’t have the “travelling” zone always visible on your clock at the moment. Have a play and let me know how you get on though.
You can install the beta version from HACS (you need to have added the repository as a custom repository first), then “re-download” the component and it’ll let you select which version you want.
Amazing! So excited for entity pictures! Is the flag in the documentation somewhere?
Edit: found it: show_images
Welcome back! I kept this project bookmarked hoping for your return from your coding sabbatical ![]()
Wife and daughter are both HP lovers, and are very much enjoying this. Thank you for making a fun thing for HA.
I can confirm that the beta8 is working with person entities and their associated pictures. Have not tested the “traveling” yet, as my setup isn’t 1-1 for person to phones, will look into passing those attributes through from their respective sources.
All,
I am probably late to the game, but absolutely love this clock and are now displaying this on a seeed studio ink screen. Has somebody every consider adding the hands for minutes and hours? So besides the location it also serves as an actual clock? Not a coder myself but happy to contribute if that helps.
@malcolmrigg Is it possible to alias locations? Such that multiple locations show as one on the clock?
Example: Each person has a zone for their work, each with a unique name. I want them all to just show “Work” when at that zone rather than having a separate clock segment for each place.
