I can confirm that
Thank you for confirming
@bjorn.sivertsen Iām trying your configuration and Iām having troubles figuring out what is the number.bedroomair_purifier_fan_level
entity so I can replace it with mine. I have the mi air 3H, so I should have that entity.
Thanks for making this available to the community. Iāve created my own version, mostly based on the version by @bjorn.sivertsen, with a few modifications and additions.
My āFavorite modeā (alternative auto mode) looks like this:
Some of the modifications I made:
- Added the default Auto mode
- Added a selector to adjust the Favorite fan level
- Added color indication on the Favorite symbol according to PM 2.5 level (green, yellow, orange, red)
- Added adjustment for LED brightness (off, dim, bright)
- Added lock/unlock for the display button (Child-lock)
- Added control for buzzer (on, off)
- Included some more automations
If anyone is interested my version is in my Github repository here
I tried to include a detailed instruction that can be followed even by someone completely new to Home Assistant, so pardon me for the spoon-feeding!
Hi Christer, Iāve since moved to a less polluted area of the city, and have actually stopped using my purifier.
But a bit kudos to taking it further (and the fantastic instructions!), your additions make a lot of sense!
Have you found a solution to this, I have the same question?
hi,
how can i get the token for configuration.yaml, id for automation.yaml?
i am new in home assistant things.
thank you!
If you install the addon, it should sort the token for you through the process.
Id for automation doesnāt matter and you can give it any you like. If you create an automation through the UI, it is automatically generated.
