I don’t think this are affecting the functionality. Most are related to no info from the purifier. For example speed is having predefined values and cannot be None and also Fan level cannot be 0. Try adding in the configuration Initial values for this input_numbers like: initial: Auto and initial: 1. Also I have nothing to do if value for pm2.5 is not reported by purifier. I noticed this after restarting the HA but it OK once first measurement is received.
Hey shilea,
thanks for your great work.
Regarding the warnings and error messages. I get the same and using initial values somehow doesn’t work.
But is it maybe possible to intercept these “wrong” value like “none” or “0.0” in the sensor configuration? e.g. if the value is 0.0 set it to 1.0 or if value is none set it to 0.
Due to the huge amount of automations I have I often loose overview in HA Webui. Therefore I removed all coverage parts from this configuration, since I don’t use it and therefore I can remove the related automations entirely.
For purifier on and off automation I created an replacement using the recently introduced choose function. This way I get rid of at least one additional automation.
Here’s the code if someone’s interested:
- id: 'xxxxxxxxxxxxxx'
alias: Air Purifier turn toogle
description: ''
- above: '15'
entity_id: sensor.mi_air_purifier_air_quality_pm25
for: 00:00:10
platform: numeric_state
- below: '5'
for: 00:05:00
condition: []
- choose:
- conditions:
- condition: and
conditions:
- above: '15'
condition: numeric_state
- condition: state
entity_id: fan.mi_air_purifier_3h
state: 'off'
sequence:
- data: {}
service: fan.turn_on
- data_template:
speed: Fan
service: fan.set_speed
- conditions:
- condition: and
conditions:
- below: '5'
- condition: state
state: 'on'
sequence:
- data: {}
service: fan.turn_off
default: []
mode: single
Unfortunately for fan or mode change the chooser doesn’t work since there is no state which can use use a condition of choosing the right option - as far as I know
EDIT:
In order to get rid of the sensor.mi_air_purifier_air_quality_pm25 one can add “if else” into the value template
mi_air_purifier_air_quality_pm25:
friendly_name: "Air quality (AQI) PM2.5"
value_template: >
{% set value = state_attr('fan.mi_air_purifier_3h', 'aqi') %}
{% if state_attr('fan.mi_air_purifier_3h', 'aqi') == None %}
{{ 0 }}
{%- else -%}
{{ value }}
{% endif %}
unit_of_measurement: "μg/m³"
icon_template: "mdi:weather-fog"
Thanks Peter for your valuable comments and updates.
I used your settings and it is working great. Thanks for this automation and Lovelace plugin.
One question. I would add an automation to this for myself and mayby you can guide me in the right direction.
I have a window sensor in my room where the air purifier is located. Now i want to turn off your automation when the window sensor is open and start it again when closed. How can this be done?
Hi @sn33ky, I am having such kind of automation for my boiler, it shuts it down if a window/door is open foe 30s and starts it if all windows/doors are closed for 1 min. Try this one to turn off the purifier but before replace the sensor name with yours.
- id: b73aca069a3dcb533e9c32fac7006bdd
alias: Turn off the purifier if a window/door is open for 30 seconds
- entity_id: binary_sensor.window_door
for: 0:00:30
platform: state
to: 'on'
condition:
- condition: state
state: 'on'
- data: {}
- service: notify.notify
message: Mi Air Purifier 3H turn off! window/door is open for 30 seconds at {{
states('sensor.date_time') }}
Thanks for your information. This helped me. I also added a automation when i’m not home to turn off the air purifier.
So I did it a little different, and edited the existing automations:
In the “Air Purifier turn off” automation i added following triggers:
- When windows sensor x is open for 30 seconds
- When person x is leaving home area.
And in the “Air Purifier turn on” automation i added following condition:
- Only when window sensor x is closed.
- Only when person x is in home area.
Due to issues with Mi Air Purifier 2S and 3H sending “None” status when turned off, I’ve modified the automations to ignore it when off, along with several conditions to detect if changes were made on the device itself. All these are meant to minimize unnecessary bloating of the HA logs.
I’m using HA 0.117.6
These are fully working lovelace cards and automations for models 2S and 3H.
configuration.yaml
fan:
# Mi Air Purifier 2S
- platform: xiaomi_miio
name: "Mi Air Purifier 2S"
host: 0.0.0.0
token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# Mi Air Purifier 3H
name: "Mi Air Purifier 3H"
host: 0.0.0.0
switch:
switches:
mi_air_purifier_2s_led:
friendly_name: "Display"
value_template: "{{ is_state_attr('fan.mi_air_purifier_2s', 'led', true) }}"
turn_on:
service: xiaomi_miio.fan_set_led_on
entity_id: fan.mi_air_purifier_2s
turn_off:
service: xiaomi_miio.fan_set_led_off
icon_template: mdi:lightbulb-outline
mi_air_purifier_2s_child_lock:
friendly_name: "Child lock"
value_template: "{{ is_state_attr('fan.mi_air_purifier_2s', 'child_lock', true) }}"
turn_on:
service: xiaomi_miio.fan_set_child_lock_on
turn_off:
service: xiaomi_miio.fan_set_child_lock_off
icon_template: "mdi:lock-outline"
mi_air_purifier_2s_buzzer:
friendly_name: "Buzzer"
value_template: "{{ is_state_attr('fan.mi_air_purifier_2s', 'buzzer', true) }}"
turn_on:
service: xiaomi_miio.fan_set_buzzer_on
turn_off:
service: xiaomi_miio.fan_set_buzzer_off
icon_template: "mdi:volume-high"
switches:
mi_air_purifier_3h_led:
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'led', true) }}"
turn_on:
turn_off:
mi_air_purifier_3h_child_lock:
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'child_lock', true) }}"
turn_on:
turn_off:
mi_air_purifier_3h_buzzer:
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'buzzer', true) }}"
turn_on:
turn_off:
input_number:
mi_air_purifier_2s_favorite_level:
initial: 5
min: 0
max: 14
step: 1
icon: mdi:weather-windy
mi_air_purifier_3h_favorite_level:
initial: 5
min: 0
max: 14
step: 1
mi_air_purifier_3h_fan_level:
initial: 1
min: 0
max: 3
step: 1
icon: mdi:jquery
input_boolean:
mi_air_purifier_2s_attributes:
icon: mdi:pencil
mi_air_purifier_3h_attributes:
icon: mdi:pencil
input_select:
mi_air_purifier_2s_mode:
options:
- Auto
- Silent
- Favorite
initial: Auto
icon: mdi:animation-outline
mi_air_purifier_3h_mode:
options:
- Auto
- Silent
- Favorite
- Fan
initial: Auto
sensors:
mi_air_purifier_2s_temperature:
friendly_name: "Temperature"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'temperature') }}"
unit_of_measurement: "°C"
device_class: "temperature"
mi_air_purifier_2s_humidity:
friendly_name: "Humidity"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'humidity') }}"
unit_of_measurement: "%"
device_class: "humidity"
mi_air_purifier_2s_air_quality_pm25:
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'aqi') }}"
mi_air_purifier_2s_avg_air_quality_pm25:
friendly_name: "Average air quality (AvgAQI) PM2.5"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'average_aqi') }}"
icon_template: "mdi:weather-hazy"
mi_air_purifier_2s_use_time:
friendly_name: "Time used"
value_template: >
{% macro phrase(value, name) %}
{%- set value = value | int %}
{%- set end = 's' if value > 1 else '' %}
{{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
{%- endmacro %}
{% set weeks = (state_attr('fan.mi_air_purifier_2s', 'use_time') | int / 604800) | int %}
{% set days = ((state_attr('fan.mi_air_purifier_2s', 'use_time') | int - (weeks * 604800)) / 86400) | int %}
{% set hours = ((state_attr('fan.mi_air_purifier_2s', 'use_time') | int - (weeks * 604800) - (days * 86400)) / 3600) | int %}
{% set minutes = ((state_attr('fan.mi_air_purifier_2s', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600)) / 60) | int %}
{% set seconds = (state_attr('fan.mi_air_purifier_2s', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600) - (minutes*60)) | int %}
{{ [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min'), phrase(seconds, 'sec') ] | select('!=','') | list | join(', ') }}
icon_template: "mdi:heart-pulse"
mi_air_purifier_2s_filter_used:
friendly_name: "Filter used"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'filter_hours_used') }}"
unit_of_measurement: "hrs"
icon_template: "mdi:heart-off"
mi_air_purifier_2s_filter_remaining:
friendly_name: "Filter remaining"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'filter_life_remaining') }}"
icon_template: "mdi:heart-outline"
mi_air_purifier_2s_purify_volume:
friendly_name: "Purified volume"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'purify_volume') }}"
unit_of_measurement: "m³"
icon_template: "mdi:warehouse"
mi_air_purifier_2s_speed:
friendly_name: "Fan speed"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'motor_speed') }}"
unit_of_measurement: "rpm"
icon_template: "mdi:speedometer"
mi_air_purifier_2s_filter_type:
friendly_name: "Filter type"
value_template: "{{ state_attr('fan.mi_air_purifier_2s', 'filter_type') }}"
icon_template: "mdi:air-filter"
sensors:
mi_air_purifier_3h_temperature:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'temperature') }}"
mi_air_purifier_3h_humidity:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'humidity') }}"
mi_air_purifier_3h_air_quality_pm25:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'aqi') }}"
mi_air_purifier_3h_avg_air_quality_pm25:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'average_aqi') }}"
mi_air_purifier_3h_use_time:
value_template: >
{%- endmacro %}
{% set weeks = (state_attr('fan.mi_air_purifier_3h', 'use_time') | int / 604800) | int %}
{% set days = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800)) / 86400) | int %}
{% set hours = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400)) / 3600) | int %}
{% set minutes = ((state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600)) / 60) | int %}
{% set seconds = (state_attr('fan.mi_air_purifier_3h', 'use_time') | int - (weeks * 604800) - (days * 86400) - (hours * 3600) - (minutes*60)) | int %}
mi_air_purifier_3h_filter_used:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'filter_hours_used') }}"
mi_air_purifier_3h_filter_remaining:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'filter_life_remaining') }}"
mi_air_purifier_3h_purify_volume:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'purify_volume') }}"
mi_air_purifier_3h_speed:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'motor_speed') }}"
mi_air_purifier_3h_filter_type:
value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'filter_type') }}"
lovelace cards
cards:
- cards:
- entity: sensor.mi_air_purifier_2s_air_quality_pm25
max: 30
min: 0
severity:
green: 0
red: 21
yellow: 11
type: gauge
type: horizontal-stack
- entities:
- entity: fan.mi_air_purifier_2s
- entity: switch.mi_air_purifier_2s_led
- entity: input_select.mi_air_purifier_2s_mode
show_header_toggle: false
type: entities
- card:
entities:
- entity: input_number.mi_air_purifier_2s_favorite_level
type: entities
conditions:
state: Favorite
type: conditional
- entities:
- entity: sensor.mi_air_purifier_2s_temperature
- entity: sensor.mi_air_purifier_2s_humidity
- entity: sensor.mi_air_purifier_2s_avg_air_quality_pm25
- type: divider
- entity: sensor.mi_air_purifier_2s_filter_type
- entity: sensor.mi_air_purifier_2s_filter_used
- entity: sensor.mi_air_purifier_2s_filter_remaining
- entity: sensor.mi_air_purifier_2s_use_time
- entity: sensor.mi_air_purifier_2s_purify_volume
- type: divider
- entity: sensor.mi_air_purifier_2s_speed
- type: divider
- entity: switch.mi_air_purifier_2s_child_lock
- entity: switch.mi_air_purifier_2s_buzzer
type: entities
type: vertical-stack
cards:
- cards:
- entity: sensor.mi_air_purifier_3h_air_quality_pm25
max: 30
min: 0
severity:
green: 0
red: 21
yellow: 11
type: gauge
- entities:
- entity: fan.mi_air_purifier_3h
- entity: switch.mi_air_purifier_3h_led
- entity: input_select.mi_air_purifier_3h_mode
type: entities
- card:
entities:
- entity: input_number.mi_air_purifier_3h_favorite_level
type: entities
conditions:
state: Favorite
type: conditional
- card:
entities:
- entity: input_number.mi_air_purifier_3h_fan_level
type: entities
conditions:
state: Fan
type: conditional
- entities:
- entity: sensor.mi_air_purifier_3h_temperature
- entity: sensor.mi_air_purifier_3h_humidity
- entity: sensor.mi_air_purifier_3h_avg_air_quality_pm25
- type: divider
- entity: sensor.mi_air_purifier_3h_filter_type
- entity: sensor.mi_air_purifier_3h_filter_used
- entity: sensor.mi_air_purifier_3h_filter_remaining
- entity: sensor.mi_air_purifier_3h_use_time
- entity: sensor.mi_air_purifier_3h_purify_volume
- type: divider
- entity: sensor.mi_air_purifier_3h_speed
- type: divider
- entity: switch.mi_air_purifier_3h_child_lock
- entity: switch.mi_air_purifier_3h_buzzer
type: entities
automations.yaml
- id: '10000000001'
alias: Mi Air Purifier 2S mode change init
platform: state
entity_id: input_select.mi_air_purifier_2s_mode
# Send browser notification
- service: persistent_notification.create
title: 'Mi Air Purifier 2S'
message: 'Mode change: {{ states(''input_select.mi_air_purifier_2s_mode'') }}'
- service: fan.set_speed
data_template:
speed: '{{ states(''input_select.mi_air_purifier_2s_mode'') | capitalize }}'
- id: '10000000002'
alias: Mi Air Purifier 2S mode change update
platform: state
condition:
condition: and
conditions:
# Check if turned on
- '{{ (state_attr(''fan.mi_air_purifier_2s'', ''speed'') | capitalize) != ''None'' }}'
# Proceed if purifier mode is set different than HA dropdown
- '{{ (state_attr(''fan.mi_air_purifier_2s'', ''speed'') | capitalize) != (states(''input_select.mi_air_purifier_2s_mode'') | capitalize) }}'
message: 'Mode change update: {{ states(''input_select.mi_air_purifier_2s_mode'') }} > {{ state_attr(''fan.mi_air_purifier_2s'', ''speed'') }}'
- service: input_select.select_option
data_template:
option: '{{ state_attr(''fan.mi_air_purifier_2s'', ''speed'') | capitalize }}'
- id: '10000000003'
alias: Mi Air Purifier 2S favorite level change init
platform: state
entity_id: input_number.mi_air_purifier_2s_favorite_level
message: 'Favorite level change: {{ states(''input_number.mi_air_purifier_2s_favorite_level'') }}'
- service: xiaomi_miio.fan_set_favorite_level
data_template:
level: '{{ states(''input_number.mi_air_purifier_2s_favorite_level'') | int }}'
- id: '10000000004'
alias: Mi Air Purifier 2S favorite level change update
platform: state
condition:
condition: and
conditions:
- '{{ (state_attr(''fan.mi_air_purifier_2s'', ''favorite_level'') | int) != 0 }}'
# Proceed only if purifier favorite level different than on HA card
- '{{ (state_attr(''fan.mi_air_purifier_2s'', ''favorite_level'') | int) != (states(''input_number.mi_air_purifier_2s_favorite_level'') | int) }}'
message: 'Favorite level change update: {{ states(''input_number.mi_air_purifier_2s_favorite_level'') }} > {{ state_attr(''fan.mi_air_purifier_2s'', ''favorite_level'') }}'
- service: input_number.set_value
data_template:
value: '{{ state_attr(''fan.mi_air_purifier_2s'', ''favorite_level'') | int }}'
- id: '20000000001'
alias: Mi Air Purifier 3H mode change init
platform: state
entity_id: input_select.mi_air_purifier_3h_mode
title: 'Mi Air Purifier 3H'
message: 'Mode change: {{ states(''input_select.mi_air_purifier_3h_mode'') }}'
data_template:
speed: '{{ states(''input_select.mi_air_purifier_3h_mode'') | capitalize }}'
- id: '20000000002'
alias: Mi Air Purifier 3H mode change update
platform: state
condition:
condition: and
conditions:
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''speed'') | capitalize) != ''None'' }}'
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''speed'') | capitalize) != (states(''input_select.mi_air_purifier_3h_mode'') | capitalize) }}'
message: 'Mode change update: {{ states(''input_select.mi_air_purifier_3h_mode'') }} > {{ state_attr(''fan.mi_air_purifier_3h'', ''speed'') }}'
data_template:
option: '{{ state_attr(''fan.mi_air_purifier_3h'', ''speed'') | capitalize }}'
- id: '20000000003'
alias: Mi Air Purifier 3H favorite level change init
platform: state
entity_id: input_number.mi_air_purifier_3h_favorite_level
message: 'Favorite level change: {{ states(''input_number.mi_air_purifier_3h_favorite_level'') }}'
data_template:
level: '{{ states(''input_number.mi_air_purifier_3h_favorite_level'') | int }}'
- id: '20000000004'
alias: Mi Air Purifier 3H favorite level change update
platform: state
condition:
condition: and
conditions:
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''favorite_level'') | int) != 0 }}'
# Proceed only if purifier favorite level is set different than on HA card
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''favorite_level'') | int) != (states(''input_number.mi_air_purifier_3h_favorite_level'') | int) }}'
message: 'Favorite level change update: {{ states(''input_number.mi_air_purifier_3h_favorite_level'') }} > {{ state_attr(''fan.mi_air_purifier_3h'', ''favorite_level'') }}'
data_template:
value: '{{ state_attr(''fan.mi_air_purifier_3h'', ''favorite_level'') | int }}'
- id: '20000000005'
alias: Mi Air Purifier 3H fan level change init
platform: state
entity_id: input_number.mi_air_purifier_3h_fan_level
message: 'Fan level change: {{ states(''input_number.mi_air_purifier_3h_fan_level'') }}'
- service: xiaomi_miio.fan_set_fan_level
data_template:
level: '{{ states(''input_number.mi_air_purifier_3h_fan_level'') | int }}'
- id: '20000000006'
alias: Mi Air Purifier 3H fan level change update
platform: state
condition:
condition: and
conditions:
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''fan_level'') | int) != 0 }}'
# Proceed only if purifier fan level different than on HA card
- '{{ (state_attr(''fan.mi_air_purifier_3h'', ''fan_level'') | int) != (states(''input_number.mi_air_purifier_3h_fan_level'') | int) }}'
message: 'Fan level change update: {{ states(''input_number.mi_air_purifier_3h_fan_level'') }} > {{ state_attr(''fan.mi_air_purifier_3h'', ''fan_level'') }}'
data_template:
value: '{{ state_attr(''fan.mi_air_purifier_3h'', ''fan_level'') | int }}'
Note: automations are set to notify browser on any purifier change; simply disable it by commenting out (with #) the lines - service: persistent_notification.create, data, title and message
Something is wrong with automations (Purifier 3H). When I change mode from eg. Auto to favourite it changes for a second and then changes to fan. This is what I see in log:
Mi Air Purifier 3H mode change init has been triggered by state of input_select.mi_air_purifier_3h_mode
10:32:19 - 3 minuty temu
Mi Air Purifier 3H mode change update has been triggered by state of fan.mi_air_purifier_3h
Mi Air Purifier 3H fan level change init has been triggered by state of input_number.mi_air_purifier_3h_fan_level
10:32:18 - 3 minuty temu
Mi Air Purifier 3H fan level change update has been triggered by state of fan.mi_air_purifier_3h
Look like both automations fire one by one…
Changing mode is changing fan level and we have chain reaction…
Work like a charm but really difficult for my first integration … But i’m happy now. Thanks a lot !
@check I can see the only difference are the conditions, like the one bellow, you added on 3 automations. I will give them a try and let you know my thoughts.
@majkers I think this is how Purifier implements changes in Favorite level. When going through different favorite levels it changes also the fan level. The lowest ones are with FAN level 1 and the highest ones with FAN level 3. So the automations see also a FAN changes and reacts accordingly. I have also to think about on how not to run automation when Favorite level changed.
I just updated my initial post where I added checks for 2S in automations. It works flawlessly without bloating the log when device sends status update.
I’ve had lot’s of issues with purifiers this year and finally I can say it’s working right.
Thanks all for sharing your job. Was very helpful to me.
I have been reworking this system until I got something more compact. It also solves all problems with state ping-pong I had due to 3H connectivity issues.
Added automation:
- Recognizes open door and window and pauses/resumes purifier (wont turn on purifier while they are open)
- Recognizes presence, stops purifier after leaving and wont start until returning home
- Clean before returning home, based on time of a day and presence
- Follows day and night hours
- Faster reaction to PM changes, and even faster with external PM sensor
You may remove all time_pattern triggers if your purifier wifi is reliable.
/config/integrations/airpurifier.yaml
# Mi Air Purifier 3H #
fan:
host: !secret mi_air_host
token: !secret mi_air_token
model: zhimi.airpurifier.mb3
input_number:
mi_air_purifier_favorite_level:
initial: 0
min: 0
max: 14
step: 1
input_boolean:
mi_air_purifier_paused:
name: Air Purifier Paused
initial: off
icon: mdi:air-filter
binary_sensor:
sensors:
mi_air_purifier_mode_off:
friendly_name: "Purifier Off"
value_template: "{{ is_state('fan.mi_air_purifier_3h', 'off') }}"
mi_air_purifier_mode_auto:
friendly_name: "Purifier Auto mode"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 0) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_silent:
friendly_name: "Purifier Silent mode"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 1) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_favorite:
friendly_name: "Purifier Favorite mode"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 2) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_fan:
friendly_name: "Purifier Fan mode"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 3) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_fan_1:
friendly_name: "Purifier Fan mode 1"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 3) and is_state_attr('fan.mi_air_purifier_3h', 'fan_level', 1) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_fan_2:
friendly_name: "Purifier Fan mode 2"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 3) and is_state_attr('fan.mi_air_purifier_3h', 'fan_level', 2) and is_state('fan.mi_air_purifier_3h', 'on') }}"
mi_air_purifier_mode_fan_3:
friendly_name: "Purifier Fan mode 3"
value_template: "{{ is_state_attr('fan.mi_air_purifier_3h', 'mode', 3) and is_state_attr('fan.mi_air_purifier_3h', 'fan_level', 3) and is_state('fan.mi_air_purifier_3h', 'on') }}"
sensors:
value_template: >
{{ 0 }}
{%- else -%}
{{ value }}
{% endif %}
/config/automations/airpurifier.yaml
# Air Purifier favorite level change
- id: air_purifier_favorite_level_change
alias: Air Purifier favorite level change
description: ''
- entity_id: input_number.mi_air_purifier_favorite_level
platform: state
condition:
- condition: state
entity_id: binary_sensor.mi_air_purifier_mode_favorite
state: 'on'
- data_template:
level: '{{ states(''input_number.mi_air_purifier_favorite_level'') | int }}'
- id: air_purifier_favorite_level_update
description: ''
- entity_id: fan.mi_air_purifier_3h
platform: state
condition: []
- data_template:
# Air Purifier set favorite level based on PM2.5
- id: air_purifier_set_favorite_level_based_on_PM2.5
alias: Air Purifier set favorite level based on PM2.5
description: ''
- platform: numeric_state
above: '50'
below: '50'
below: '40'
below: '30'
below: '20'
below: '10'
- minutes: '/2'
platform: time_pattern
condition:
- condition: state
state: 'on'
- data_template:
level: >
{% if states("sensor.mi_air_purifier_air_quality_pm25") | int > 50 -%}
11
{%- elif states("sensor.mi_air_purifier_air_quality_pm25") | int > 40 -%}
9
{%- elif states("sensor.mi_air_purifier_air_quality_pm25") | int > 30 -%}
8
{%- elif states("sensor.mi_air_purifier_air_quality_pm25") | int > 20 -%}
6
{%- elif states("sensor.mi_air_purifier_air_quality_pm25") | int > 10 -%}
4
{%- else -%}
2
{%- endif %}
# PAUSE
- id: air_purifier_pause
alias: Air Purifier pause
description: ''
- platform: state
entity_id: binary_sensor.door_contact_sensor_contact
to: 'on'
- platform: state
entity_id: binary_sensor.window_contact_sensor_contact
to: 'on'
condition:
- condition: and
conditions:
- condition: state
entity_id: input_boolean.mi_air_purifier_paused
state: 'off'
- condition: state
state: 'on'
data: {}
- service: fan.turn_off
data: {}
mode: single
# RESUME
- id: air_purifier_resume
alias: Air Purifier resume
description: ''
- platform: state
to: 'off'
- platform: state
to: 'off'
condition:
- condition: and
conditions:
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'on'
- service: input_boolean.turn_off
data: {}
- service: fan.turn_on
data: {}
mode: single
# LEAVE HOME
- id: air_purifier_leave_home
alias: Air Purifier leave home
description: ''
- platform: state
to: not_home
entity_id: device_tracker.shiis_iphone
condition:
- condition: state
state: 'on'
- data: {}
mode: single
# RETURN HOME
# - id: air_purifier_return_home
# alias: Air Purifier return home
# description: ''
# trigger:
# - platform: state
# from: not_home
# to: home
# entity_id: device_tracker.shiis_iphone
# condition:
# - condition: state
# entity_id: fan.mi_air_purifier_3h
# state: 'off'
# action:
# - service: fan.set_speed
# data_template:
# speed: 'Silent'
# mode: single
# PRE-CLEAN BEFORE RETURNING HOME
- id: air_purifier_pre-clean
alias: Air Purifier pre-clean
description: ''
- platform: time
at: '15:00'
condition:
- condition: and
conditions:
- condition: state
state: not_home
- condition: state
state: 'off'
data_template:
speed: 'Favorite'
mode: single
# CLEAN AFTER CLOSING WINDOWS
# - id: air_purifier_auto-clean_window
# alias: Air Purifier auto-clean window
# description: ''
# trigger:
# - platform: state
# entity_id: binary_sensor.window_contact_sensor_contact
# from: 'on'
# to: 'off'
# condition:
# - condition: and
# conditions:
# - condition: time
# after: '8:00'
# before: '23:00'
# entity_id: input_boolean.mi_air_purifier_paused
# state: 'off'
# state: 'off'
# action:
# data_template:
# speed: 'Favorite'
# mode: single
# CLEAN ABOVE 50 PM25
description: ''
above: '50'
for: 00:01:00
- platform: time_pattern
minutes: '/5'
condition:
- condition: and
conditions:
- condition: time
after: '8:00'
before: '23:00'
- condition: state
state: home
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
state: 'off'
- condition: state
entity_id: binary_sensor.headset_presence
state: 'on'
- condition: state
entity_id: binary_sensor.mi_air_purifier_mode_fan
state: 'off'
- condition: numeric_state
above: 50
data_template:
speed: 'Favorite'
data_template:
level: 11
mode: single
# SWITCH TO SILENT AT 10 PM25
- id: air_purifier_auto-clean_silent
alias: Air Purifier auto-clean silent
description: ''
below: '10'
for: 00:01:00
minutes: '/5'
condition:
- condition: and
conditions:
- condition: state
state: 'on'
below: '10'
- condition: state
state: 'on'
# data_template:
# speed: 'Silent'
data: {}
mode: single
# SWITCH TO SILENT FOR SLEEP
- id: air_purifier_sleep
alias: Air Purifier sleep
description: ''
entity_id: sensor.pc_power
below: '30'
condition:
- condition: and
conditions:
- condition: time
after: '23:00'
before: '08:00'
- condition: state
state: 'off'
- condition: state
state: 'on'
# data_template:
# speed: 'Silent'
data: {}
mode: single
Dashboard
cards:
- type: picture-elements
image: local/images/mi-air-purifier-3h.png
elements:
- type: state-label
attribute: aqi
style:
top: 21%
left: 73.3%
min-width: 40px
min-height: 40px
text-align: center
transform: 'translate(-50%, 0)'
background-color: 'rgb(0, 2, 0)'
border-radius: 20px
- type: image
state_image:
'on': local/images/mi-air-purifier-3h_on.png
'off': local/images/mi-air-purifier-3h_off.png
style:
top: 38%
left: 73.3%
- type: state-label
attribute: average_aqi
prefix: 'Average PM2.5 '
suffix: ' μg/m³'
style:
top: 12%
left: 60%
transform: 'translate(-100%, 0)'
text-shadow: '1px 1px 2px black, 0 0 25px rgb(41, 41, 41)'
- type: state-label
attribute: filter_hours_used
prefix: 'Filter used '
suffix: ' hrs'
style:
top: 25%
left: 60%
- type: state-label
attribute: filter_life_remaining
prefix: 'Filter remaining '
suffix: '%'
style:
top: 38%
left: 60%
- type: state-label
attribute: purify_volume
prefix: 'Purified volume '
suffix: ' m³'
style:
top: 51%
left: 60%
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_auto
title: Auto
icon: 'mdi:calendar-sync'
tap_action:
action: call-service
service_data:
speed: Auto
style:
top: 75%
left: 6%
background-color: 'rgb(41, 41, 41)'
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_silent
title: Silent
icon: 'mdi:fan-minus'
tap_action:
service_data:
speed: Silent
style:
top: 75%
left: 16%
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_favorite
title: Favorite
icon: 'mdi:fan-chevron-up'
tap_action:
service_data:
speed: Favorite
style:
top: 75%
left: 26%
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_fan_1
title: Fan level 1
icon: 'mdi:fan-speed-1'
tap_action:
service_data:
level: 1
style:
top: 75%
left: 36%
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_fan_2
title: Fan level 2
icon: 'mdi:fan-speed-2'
tap_action:
service_data:
level: 2
style:
top: 75%
left: 46%
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_fan_3
title: Fan level 3
icon: 'mdi:fan-speed-3'
tap_action:
service_data:
level: 3
style:
top: 75%
left: 56%
border-radius: 20px
- type: state-icon
entity: binary_sensor.mi_air_purifier_mode_off
title: 'Off'
icon: 'mdi:fan-off'
tap_action:
service_data:
style:
top: 5%
left: 6%
border-radius: 20px
- card:
entities:
- entity: input_number.mi_air_purifier_favorite_level
type: entities
conditions:
- entity: binary_sensor.mi_air_purifier_mode_favorite
state: 'on'
type: conditional
/config/www/images/
Optional PM sensor
Hardware used:
- wemos d1 mini
- pms7003
Replace all instances of sensor.mi_air_purifier_air_quality_pm25 with sensor.bedroom_pm_pm_2_5um in automation file.
ESPHOME config:
substitutions:
devicename: esp_env02
human_devicename: Bedroom PM
esphome:
platform: ESP8266
board: d1_mini
on_boot:
- switch.turn_on: pms_set
- delay: 3s
- switch.turn_off: pms_set
#<<: !include common/common.yaml
<<: !include common/time.yaml
<<: !include common/wifi.yaml
<<: !include common/api.yaml
<<: !include common/ota.yaml
<<: !include common/web_server.yaml
<<: !include common/text_sensors.yaml
logger:
level: DEBUG
baud_rate: 0
esp8266_store_log_strings_in_flash: false
interval:
- interval: 60s
then:
- if:
condition:
- lambda: 'return id(purifier_favorite).state == false;'
then:
- delay: 3s
- interval: 10s
then:
- if:
condition:
- lambda: 'return id(purifier_favorite).state == true;'
then:
- delay: 3s
- !include common/sensor/wifi-signal.yaml
- !include common/sensor/uptime.yaml
- platform: pmsx003
type: PMSX003
pm_1_0:
name: ${human_devicename} PM 1.0µm
accuracy_decimals: 0
filters:
- throttle: 3s
- delta: 1
pm_2_5:
name: ${human_devicename} PM 2.5µm
filters:
- throttle: 3s
- delta: 1
pm_10_0:
name: ${human_devicename} PM 10.0µm
filters:
- throttle: 3s
- delta: 1
binary_sensor:
- !include common/binary_sensor/status.yaml
- platform: homeassistant
internal: true
switch:
- !include common/switch/restart.yaml
- platform: gpio
internal: true
pin: GPIO0
uart:
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
Hi @Tomaae. Nice work and I have added it on the top of this topic. Indeed, calling a service instead of “double” automation (input to and from the purifier) could be very useful to avoid ping pong. Some of the automations are really interesting like silence during the night hours and off/on when a window is open. Also the work on graphical interface.
I am having some additional ideas and will try to add my input on your work on the next days. Could you also post a picture with favorite level selection?
Oh yeah, I forgot to add notes about extra automation I have.
I want to expand on them too. Like changing favorite level when enabling fav mode, instead of just time based and maybe reworking whole time based model to “above/bellow” triggers.
I’m also integrating separate PM sensor based on ESPHOME and pms7003 which will be located further away from my purifier so I can have it work more effectively. It is also far more responsive compared to build in one.
Favorite level selection is the same as yours, I have not yet found a way to integrate it into picture elements.
I have integrated a simplified version of yours to test functionalities. Indeed calling the service is better than “double” automation.
but I am now thinking on something a little bit different to present also the aqi colored. I have pictures ready but let see when I am going to have time to integrate them
Oh yes, using services works reliably. Before I switched to services, I had previous settings return back about 80% of the time. But that could be issue with 3H and its unreliable wifi.
Using color for AQI is nice, I just used it to indicate on/off status. Its really simple to implement tho, if you want to use it in that way.
But if you use image so large, there may not be space for status text and control buttons without having it feel crowded.
Hi, I figured out how to add favorite and fun as conditional.
This is still working progress to add aqi colors, humidity and temperature like on purifier display.
Below is the work so far based on your template:
new sensor in configuration.yaml
friendly_name: "Favorite Level"
# value_template: "{{ state_attr('fan.mi_air_purifier_3h', 'favorite_level') }}"
value_template: >
{% if state_attr('fan.mi_air_purifier_3h', 'favorite_level') == None %}
{{ 0 }}
{%- else -%}
{% endif %}
icon_template: "mdi:weather-windy"
Dashboard:
image: local/images/mi-air-purifier-3h.jpg
elements:
- type: image
state_image:
'on': local/images/mi-air-purifier-3h_on.jpg
'off': local/images/mi-air-purifier-3h_off.jpg
style:
top: 32%
left: 73.3%
- type: state-icon
title: 'Off'
icon: 'mdi:power-standby'
tap_action:
service_data:
style:
top: 5%
left: 6%
border-radius: 20px
- type: state-label
attribute: aqi
style:
top: 21%
left: 73.3%
min-width: 40px
min-height: 40px
text-align: center
color: 'rgb(255,255,255)'
border-radius: 20px
- type: state-icon
title: Auto
icon: 'mdi:autorenew'
tap_action:
service_data:
speed: Auto
style:
top: 40%
left: 6%
border-radius: 20px
- type: state-icon
title: Silent
icon: 'mdi:power-sleep'
tap_action:
service_data:
speed: Silent
style:
top: 40%
left: 16%
border-radius: 20px
- type: state-icon
title: Favorite
icon: 'mdi:heart'
tap_action:
service_data:
speed: Favorite
style:
top: 40%
left: 26%
border-radius: 20px
- type: state-icon
title: Fan
icon: 'mdi:fan'
tap_action:
service_data:
speed: Fan
style:
top: 40%
left: 36%
border-radius: 20px
- type: conditional
conditions:
- entity: binary_sensor.mi_air_purifier_mode_fan
state: 'on'
elements:
- type: state-icon
title: Fan level 1
tap_action:
service_data:
level: 1
style:
top: 70%
left: 16%
border-radius: 20px
- type: state-icon
title: Fan level 2
tap_action:
service_data:
level: 2
style:
top: 70%
left: 26%
border-radius: 20px
- type: state-icon
title: Fan level 3
tap_action:
service_data:
level: 3
style:
top: 70%
left: 36%
border-radius: 20px
- type: conditional
conditions:
state: 'on'
elements:
- type: state-label
entity: sensor.mi_air_purifier_favorite_level
style:
top: 70%
left: 26%
min-width: 40px
min-height: 40px
text-align: center
color: 'rgb(255,255,0)'
border-radius: 20px
- type: icon
icon: 'mdi:plus'
tap_action:
service: input_number.increment
service_data:
style:
top: 75%
left: 36%
border-radius: 20px
- type: icon
icon: 'mdi:minus'
tap_action:
service: input_number.decrement
service_data:
style:
top: 75%
left: 16%
border-radius: 20px
Oh, thats a great idea, I will try it out too. Hopefully 3H will play nicely with it.
I have also implemented all those automation changes I mentioned. Its really smooth now and very fast. Specially with external sensor.
I have added code for that one too, but thats WIP as I want to add more sensors there. That wont have any effect on purifier tho.
PS: is new sensor really needed? cant it be handled by input_number.mi_air_purifier_favorite_level?
Haven’t figured out how to display the favourite value using input number as integer and not decimal like 4.0, 7.0. I was tried this also initially. So that was the ideea it came to me in order to display integer values.
