I’ve updated to latest version, and made tests again: all works as expected, thanks!
Hi @Sbyx,
thank you so much for this really helpful blueprint!
I’m kickstarting a small project which aims to create a curated collection of reliable, documented and high quality blueprints, which could eventually become a valuable resource both for Home Assistant newcomers and experienced users.
I published Awesome HA Blueprints as a website which can be easily browsed, but the codebase, including the list of blueprints, is available in this GitHub repository. The project is still in its early stages but I hope many blueprints will be added in the upcoming weeks and months.
Here’s the original thread:
It would be amazing to have this blueprint in the collection.
If you’ve time and you’re interested in contributing and helping the project, it would be great if you could submit your blueprint by opening a Pull Request there. Also, I could take care of adding it to the list if you’d like to.
Just let me know.
Thank you for your time!
Hi @epmatt
thanks for the feedback and your effort. I wouldn’t mind submitting this or my other blueprints to some sort of list of curated blueprints but I am afraid submitting the actual blueprint code and maintaining it in some Git repository is too much overhead besides keeping the code in a Gist and synchronizing it here in the forum manually.
I just wanted to thank you for this automation! I’ve added all sensors manually to a list via AppDaemon so far. It works well but man this is better! Many thanks.
I just wanted to jump on and say thanks for the Blueprint. With the updates, is that something we need to manually do when you update it?
Yes we do, currently. See Low battery level detection & notification for all battery sensors. I´m sure the dev team will provide some kind of update notification or even mechanism, currently it´s a manual process. “Never change a running automation” right
Thank you for your feedback @Sbyx,
there is no intention to provide a substitute to the blueprint exchange category here on Home Assistant forums, which I think it’s really an amazing place to receive feedback and share the progress of blueprint development. But the main benefit of having a GitHub repository is that this approach ensures all blueprints submitted there follow the same code and quality standards, receive proper testing and have extensive documentation. Moreover, it’s easier to track changes and contributions.
The project is still at the beginning so I’m not sure how it will look in the long run. But to make it short, the core idea is to provide users a place where they can easily find good blueprints, without searching in the whole blueprint exchange, which is seeing lots of new threads being opened every day.
Btw if you have any suggestions I’d be really happy to hear your voice. This is probably off topic here, so we can continue the discussion in the original thread.
It would be really nice to receive a PR for this and your other blueprints, all of them would be a great addition to the collection. Also, if you’d like to try to maintain them inside the project’s GitHub repo, it would definitely be a good test to verify whether this approach really brings too much overhead to blueprint development.
Thank you for your time and effort!
Great blueprint, thanks for contributing it. In fact I was working on something similar and you beat me to it.
My small variation on this theme is as follows:
- Don’t make the user type their own notification template “…{{sensors}}…” etc. Instead just ask them to pick a mobile device to notify.
- Always send a persistent notification as well.
- List device count in the message to it more obvious if devices are missing. i.e. “x out of y devices have low battery”
- Format the message a bit more cleanly (one device per line), and show ‘all devices ok’ if they are all ok.
- Default to Saturday morning
I couldn’t get the device exclusion to work (not sure why) but I wasn’t using it so I removed that.
Feel free to merge any of these ideas as you see fit!
This is a bit of a random question, and apologies up front as this template is on the cusp of my understanding, but could this template be easily adapted for an attribute of “battery_level” instead of “battery”?
It actually doesn’t read attributes at all but only dedicated battery sensor entities (states) atm.
…so you would need to create a new entity out of/based on an existing attribute first. Not very nice but for only a few sensors it might be a workaround. Does not scale obviously.
My main problem is I don’t have a device or know about one that works this way so it is hard for me to test.
Thank you! Really works. But one question, I get a message, but this message does not say which sensor is transmitting this message? Am I doing something wrong? Thanks for the response!
Hello
Thanks for a great blueprint. but I am getting an error message in the log after adding the blueprint
Logger: homeassistant.config
Source: config.py:415
First occurred: 10:59:19 AM (2 occurrences)
Last logged: 10:59:19 AM
‘* Invalid config for [automation]: Failed to load blueprint: Unable to find tube0013/battery_alert_10_entities.yaml (See /home/homeassistant/homeassistant/configuration.yaml, line 32).’
‘* Invalid config for [automation]: Failed to load blueprint: Unable to find sbyx/low-battery-level-detection-notification-for-all-battery-sensors.yaml (See /home/homeassistant/homeassistant/configuration.yaml, line 32).’
I have now tried to delete the Blueprint automation and the Blueprint from my system, but the error is still there. Can someone help?
You probably need to manually remove the sections referring to the blueprints from your automation.yaml and then reload automations or restart HA.
The automation works fine when executed, but the blueprint creates 2 errors in the log after restarting HA:
2021-01-12 15:41:37 ERROR (MainThread) [homeassistant.components.automation] Blueprint Low battery level detection & notification for all battery sensors generated invalid automation with inputs OrderedDict([('day', '0'), ('actions', [OrderedDict([('service', ''), ('data', OrderedDict([('message', 'Low battery warning for: {{sensors}}')]))])])]): Service does not match format <domain>.<name> for dictionary value @ data['action'][0]['default'][0]['service']. Got None
Is it possible to correct this?
Hi there,
the automation worked fine for a couple of days, but since today it is giving me low battery warnin even if no device reaches the threshold!
Any idea on this?
CU
Chris
The issue is with your action section not the blueprint itself. You need to set the service call to something like notify.xyz depending on what your configured notification services are.
That is what I did!
I am calling the service: notify.homeassistant_message, the sending a telegram message to my phone!
I didn’t change the config of the automation, it was running perfectly for a few days. Today it started sending me the message. Even if I execute the automation manually I am getting the telegram message!
@lilienthal9 that last reply was meant for MasterAeon’s post above yours
as for your issue: does the message contain any sensor names? do you have any errors in the HA logs under settings?
