if you need help with using that PM me and I can probably talk on the landline, I’m in the west midlands.
Richard
bachoo786
(Bachoo786)
April 25, 2019, 4:29pm
42
Thanks a lot for that please check this topic which I had created for my water heater. At the moment everything is working fine but like I said earlier I wanted to switch to Shelly.
Hi
My hot water system (UK) at home uses 2 immersion heaters which are connected to a standard timer to heat the water in the tank as and when required.
The immersion heaters stop heating the water when the target temperature is reached i.e. 50C in my case (this can obviously be changed by turning the dial in the immersion heaters).
The issue: I do not have hot water at home when all the hot water is used up and therefore I wanted to find out if there is anything I could do to set the heaters…
