Lumary (Tuya) Recessed Light RGBIC
It did work!
Albeit there is some weirdness going on with brightness that causes the LEDs to flash random colors, and a bit of flickering. I thought it might have had something to do with WS2812B vs WS2812.
Here is my current config so far I am using to test:
esphome:
  friendly_name: "Basement Ceiling Light Row 2 Col 2"
bk72xx:
  board: cbu
logger:
  baud_rate: 115200
  level: DEBUG
output:
  - platform: libretiny_pwm
    pin: P8
    frequency: 10000 Hz
    pin: P7
    frequency: 10000 Hz
light:
  - platform: cwww
    cold_white_color_temperature: 6500 K
    warm_white_color_temperature: 2700 K
    cold_white: output_cold
    warm_white: output_warm
  - platform: beken_spi_led_strip
    rgb_order: RGB
    # 		"gmkb": 60,"gmkg": 60, "gmkr": 80,
    # color_correct: [80%, 60%, 60%]
    pin: P16
    num_leds: 36
    chipset: ws2812
    effects:
      - addressable_scan:
      - addressable_rainbow:
      - addressable_color_wipe:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
      - lambda:
          name: My Custom Effect
          update_interval: 5s
          lambda: |-
            static int state = 0;
            auto call = id(my_light).turn_on();
            // Transition of 1000ms = 1s
            call.set_transition_length(1000);
            if (state == 0) {
              call.set_rgb(1.0, 1.0, 1.0);
            } else if (state == 1) {
              call.set_rgb(1.0, 0.0, 1.0);
            } else if (state == 2) {
              call.set_rgb(0.0, 0.0, 1.0);
            } else {
              call.set_rgb(1.0, 0.0, 0.0);
            call.perform();
            state += 1;
            if (state == 4)
              state = 0;
ota:
  platform: "esphome"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  #use_address: xxx.xxx.xxx.xxx
captive_portal:
mdns:
  disabled: true
api:
  reboot_timeout: 0s
web_server:
  local: true
text_sensor:
    version:
  - platform: wifi_info
    ip_address:
  - platform: debug
    device:
    reset_reason:
button:
  - platform: factory_reset
    name: Reset to Factory Settings
  - platform: restart
debug:
  update_interval: 5s
  - platform: debug
    free:
    loop_time:
  - platform: uptime
I did toodle around with OpenBeken WS2812B control via PixelAnime driver last night. The lights were smoother, brightness worked correctly, and colors were more inline with default behavior.
I am gonna poke around their driver and see how it may overlap with belken_spi_led component.
This is great news, if it isn’t too much to ask - could you do a write up of what you did so a newb like myself could replicate it? I would love to get these things off of the tuya infrastructure.
I can do that next weekend!
But overall:
  1. Use tuya-cloudcutter and push OpenBeken as custom firmware
    – Choose the Lumary 4" Ceiling Light as your tuya-cloudcutter device profile
  2. For OpenBeken module config
    – P7 = PWM
    – P8 = PWN
    – Change startup command text: backlog startDriver SM16703P; SM16703P_Init 36; startDriver PixelAnim
  3. Perform OpenBeken home assistant mqtt discovery
I do plan on figuring out how to make the lights as smooth on esphome as it is for OBK.
Any update here? I am invested!
I have flashed these, with OpenBeken - but I have no been able to get the cfgpins to work. Do you have any insight?
I’m also running into some issues. @LearningESP - could you please share more in depth info on what you did, before it’s lost to time? Also, did you have any luck with ESPhome?
Maybe you have to set up lightpartitions? Like with this device: Using LSC 3203632.1 RGBIC+CCTIC Ledstrip with ESPHome - ESPHome - Home Assistant Community Also based on SM16703 chip.
@twoenter post reinvigorated me to play with this again… thank you!
A working ESPHome config is below:
esphome:
bk72xx:
  board: cbu
logger:
  level: INFO
output:
    pin: P8
    frequency: 20000 Hz
    pin: P7
    frequency: 20000 Hz
light:
  - platform: cwww
    constant_brightness: true
    rgb_order: RGB
    # color_correct: [80%, 60%, 60%, 100%]
    # gamma_correct: 2.8
    max_refresh_rate: 16ms
    pin: P16
    num_leds: 36
    chipset: SK6812
    effects:
      - addressable_scan:
ota:
  - platform: esphome
    password: "REDACTED"
wifi:
  fast_connect: true
  use_address: 192.168.XXX.XXX
  ap:
    ssid: "Basement-Light-Row-2-Col-2"
captive_portal:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
  encryption:
    key: "REDACTED"
web_server:
  local: False
  js_url: http://REDACTED:8123/local/www.js
  version: 3
text_sensor:
    version:
    ip_address:
    dns_address:
  - platform: debug
    device:
    reset_reason:
button:
  - platform: restart
debug:
  update_interval: 5s
  - platform: debug
    free:
    loop_time:
  - platform: uptime
