Hi there…
I recently got an m5stack-atom-echo and flashed it following the instructions : $13 voice assistant for Home Assistant
So far so good, the m5stack-atom-echo appeared in Homeassistant.
Then I installed the ESPHome AddOn (2024.7.1) which recognized the m5stack-atom-echo.
Here I clicked on the only option “Adopt” and then selected “Install”.
There is some log output which ends with the following lines:
INFO Uploading /data/build/m5stack-atom-echo-23cd88/.pioenvs/m5stack-atom-echo-23cd88/firmware.bin (1835616 bytes)
ERROR Error binary size: Error: The OTA partition on the ESP is too small. ESPHome needs to resize this partition, please flash over USB.
After clicking “close” on the log-window the m5stack-atom-echo seems to be adopted, but if i try to update/install again, i get the same error.
So ist seems i cannot ota-update / install the m5stack-atom-echo from ESPHome.
Is this correct? Or i’m doing something wrong?
II thought I could integrate the m5stack-atom-echo into ESPHome and manage it, i.e. update it.
