M5Stack Atom Speaker Kit
I just reconfigured a m5stack Atom with the default “Media Player” template from the official webpage: Ready-Made Projects — ESPHome (Media Player > m5 stack)
Setup is OK (despite the compilation warnings wrt deprecated fastLED components –I got rid of the warnings by replacing the “light” section, cf. below)
Anyway, I can’t get any sound played out of the Echo device… only got instead some kind of white noise, letting me suspect that the sound can’t be properly decoded or sthg??
Eventually, i am loading this config on the Atom device:
substitutions:
  friendly_name: M5Stack Atom Speaker Kit b87824
# packages:
#   m5stack.atom-speaker-kit: github://esphome/firmware/media-player/m5stack-atom-speaker-kit.yaml@main
esphome:
  name_add_mac_suffix: false
  friendly_name: ${friendly_name}
esp32:
  board: m5stack-atom
  framework:
    type: arduino
api:
  encryption:
    key: !secret esp32_pico_echo_key
ota:
wifi:
  ssid: !secret wifi_ssid
  use_address: !secret esp32_pico_echo_ip
  domain: !secret domain
  ap:
    ssid: !secret wifi_fb_ssid
    password: !secret wifi_fb_password
web_server:
  port: !secret port
# # Enable logging
logger:
#   logs:
#     component: DEBUG
captive_portal:
improv_serial:
i2s_audio:
  i2s_lrclk_pin: GPIO21
  i2s_bclk_pin: GPIO22
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: GPIO25
    mode: mono
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    on_click:
      - media_player.toggle: media_out
    on_press:
      then:
        - homeassistant.service:
            service: tts.google_translate_say
              entity_id: media_player.ipad
              message: !lambda |-
                return "this is a test";
              entity_id: media_player.esphome_web_b87824_b87824_m5stack
              message: !lambda |-
                return "this is a test, this is a test, this is a test";
        - light.toggle: ws2812b_led_strip
# light:
#   - platform: fastled_clockless
#     name: None
#     pin: GPIO27
#     chipset: SK6812
#     num_leds: 1
#     rgb_order: grb
light:
  - platform: esp32_rmt_led_strip         # Define a programable light for the onboard led
    rgb_order: GRB
    pin: GPIO27                           # Onboard LED PIN
    num_leds: 1
    rmt_channel: 0
    chipset: SK6812
When pressing the onboard button:
  • ‘media_player.ipad’ is properly playing the "this is a test’ sentence (so no issue with DNS routing, etc…)
  • but no sound on the Atom Echo device (or rather: some white/noisy sound)
Also: trying to play a wave file directly from HA service (developer tools > Services), give me the same outcome:
  • ok on the ipad
  • nok on the Atom device
   media_content_id: https://file-examples.com/storage/fe17d655216606dd89d5226/2017/11/file_example_WAV_1MG.wav
   media_content_type: audio/wav
   # entity_id: media_player.ipad
my conclusion: mp3 format/codec can’t be the root cause.
Since I am pretty sure it was working fine “before” (well, actually: quote: "it’s playin’! " :wink: ), are you guys aware of any recent changes in ESP IDF / Arduino / ESP Home, about this? and is there a mitigation already ?
When I try to output sound on the U055 speaker my M5StickC glitches, I think because the Display and Speaker consume too much power (despite being plugged into USB).
Have you seen this problem before?
If I turn off the display the speaker SEEMS to work.
unfortunately the template available now on the web for media player contains bad values for I2S pins.
You need to use these:
i2s_audio:
  - id: i2s_audio_bus
    i2s_lrclk_pin: GPIO33
    i2s_bclk_pin: GPIO19
media_player:
    i2s_dout_pin: GPIO22
looks like the binary is built with the right values, but the configuration associated is wrong.
