M5Stack Dial - ESP32-S3 Smart Rotary Knob
Hey, I tried, but it doesn’t work when I change something in my sensor. However, if I leave it out, it works. Strange, but I need to take a closer look. Just like I still need to figure out how to add a new page, like you did. Have you also been working with the RFID reader sensor or not yet?
I would avoid updating to the latest version of esphome for the time being if you can. It seems to make everything poorly behaved, and all of my S3 devices will only boot up I connect via a usb-c cable and connect the logger (via com ports).
Additionally, there are changes to the way the polling component of the display works, and the remote github repository hasn’t been updated.
Digging into it at the moment.
Looks like esphome 2023.12.3 fixes the issues… partially. You just need to update the external component reference to my repository where I updated the gc9a01 component
external_components:
  - source: github://dgaust/esphome@gc9a01
    components: [ gc9a01 ]
can not update this erro ?
Failed config
touchscreen.lilygo_t5_47: [source <unicode string>:91]
  Couldn't find any component that can be used for 'display::Display'. Are you missing a hub declaration?.
  platform: lilygo_t5_47
  interrupt_pin:
    number: 14
    mode:
      input: True
      output: False
      open_drain: False
      pullup: False
      pulldown: False
    inverted: False
    ignore_strapping_warning: False
    drive_strength: 20.0
  i2c_id: bus_internal
  on_touch:
    then:
      - logger.log:
          format: touched
          args: []
          tag: main
          level: DEBUG
  update_interval: 50ms
  address: 0x5A
Remove the whole code. It’s not relevant, wrong touchscreen.
This section is for the RFID reader Jarne.
rc522_i2c:
  address: 0x28
  on_tag:
    then:
      - rtttl.play: "success:d=24,o=5,b=100:c,g,b"
      - homeassistant.tag_scanned: !lambda 'return x;
When I scan a new NFC card, HA adds it to my tags list.
I think you are missing some punctuation. But besides that, I have not been able to get this to work. I am wondering why…the rc522 doesnt respond at all. Are you doing some other setup besides the i2c?
When you say doesn’t respond at all, what are you testing with?
It will only work with RFID cards and tags operating at 13.56MHz.
I2C setup -
i2c:
  - id: bus_internal
    sda: GPIO11
    scl: GPIO12
  - id: bus_porta
    sda: GPIO13
    scl: GPIO15
#  interrupt: 14
Setup for reader - rtttl wont work unless you have all the other components setup.
It can be commented out for testing.
rc522_i2c:
  address: 0x28
  on_tag:
    then:
      - homeassistant.tag_scanned: !lambda 'return x;'
Output from logs on reader with device discovery on I2C and when a new card is scanned.
[10:00:24][C][logger:443]: Logger:
[10:00:24][C][logger:444]:   Level: DEBUG
[10:00:24][C][logger:445]:   Log Baud Rate: 115200
[10:00:24][C][logger:447]:   Hardware UART: USB_CDC
[10:00:25][C][i2c.arduino:053]: I2C Bus:
[10:00:25][C][i2c.arduino:054]:   SDA Pin: GPIO11
[10:00:25][C][i2c.arduino:055]:   SCL Pin: GPIO12
[10:00:25][C][i2c.arduino:056]:   Frequency: 50000 Hz
[10:00:25][C][i2c.arduino:059]:   Recovery: bus successfully recovered
[10:00:25][I][i2c.arduino:069]: Results from i2c bus scan:
[10:00:25][I][i2c.arduino:075]: Found i2c device at address 0x28
[10:00:25][I][i2c.arduino:075]: Found i2c device at address 0x38
[10:00:25][I][i2c.arduino:075]: Found i2c device at address 0x51
[10:00:25][C][i2c.arduino:054]:   SDA Pin: GPIO13
[10:00:25][C][i2c.arduino:055]:   SCL Pin: GPIO15
[10:00:25][I][i2c.arduino:071]: Found no i2c devices!
[10:00:36][D][rtttl:051]: Playing song success
[10:00:36][D][rc522:263]: Found new tag '04-77-42-C4-08-43-70'
It is very random when it will respond. About 1 out of every 20 taps/waves it registers. I just had to keep trying to get it to work…but I wouldn’t say that means it is working. I wonder what tuning it needs…
Making some progress with a touch driver… not accurate at all, but it’s registering!
It looks like quite a bit of work is going into this m5Dial device.
I ordered a few to have a play with and am struggling to get it to install on the device.
It looks like things have changed with how a display registers now with the latest versions of ESPhome.
“ValueError: Component ID my_lcd was not declared to inherit from Component, or was registered twice. Please create a bug report with your configuration.”
From reading others have had a similar issue, but with existing devices that they were just wanting to update.
This was the example of what needed to be changed…
In the last release of ESPHome, some small changes were done to the display component, to make subcomponents leaner. With those changes, compilation breaks if a display is trying to register as a component itself (this is now done automatically when registering the display).
Also, DisplayBuffer now automatically inherits from PollingComponent, so there is no need to explicitly inherit from that.
This is probably a breaking change if someone uses a lower version of esphome after this is merged.
From the above example does anyone have any ideas how to actually fix the yaml that has been shared in the above posts?
Thanks heaps!
I am facing the same issue:
INFO ESPHome 2023.12.5
INFO Reading configuration /config/esphome/m5dial1.yaml...
INFO Generating C++ source...
  File "/usr/local/bin/esphome", line 33, in <module>
    sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
  File "/esphome/esphome/__main__.py", line 1041, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 1028, in run_esphome
    rc = POST_CONFIG_ACTIONS[args.command](args, config)
  File "/esphome/esphome/__main__.py", line 458, in command_run
    exit_code = write_cpp(config)
  File "/esphome/esphome/__main__.py", line 192, in write_cpp
    generate_cpp_contents(config)
  File "/esphome/esphome/__main__.py", line 204, in generate_cpp_contents
    CORE.flush_tasks()
  File "/esphome/esphome/core/__init__.py", line 679, in flush_tasks
    self.event_loop.flush_tasks()
  File "/esphome/esphome/coroutine.py", line 246, in flush_tasks
    next(task.iterator)
  File "/esphome/esphome/__main__.py", line 184, in wrapped
    await coro(conf)
  File "/data/external_components/c9069712/esphome/components/gc9a01/display.py", line 77, in to_code
    await setup_gc9a01(var, config)
  File "/data/external_components/c9069712/esphome/components/gc9a01/display.py", line 56, in setup_gc9a01
    await display.register_display(var, config)
  File "/esphome/esphome/components/display/__init__.py", line 119, in register_display
    await cg.register_component(var, config)
  File "/esphome/esphome/cpp_helpers.py", line 56, in register_component
    raise ValueError(
using:
esphome:
  friendly_name: m5dial1
  on_boot:
    priority: 100
    then:
      - logger.log: "Startup - Backlight on"
      - lambda: |-
          id(oledbacklight).set_level(0.7);
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "APIKEY"
ota:
  password: "otapassword"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "M5Dial1 Fallback Hotspot"
    password: "HL2GnCGseKUb"
captive_portal:
globals:
  - id: screenwidth
    type: int
    restore_value: no
  - id: max_rotary_value
    type: int
    restore_value: no
    initial_value: '1'
  - id: min_rotary_value
    type: int
    restore_value: no
    initial_value: '100'
  - source: github://the-smart-home-maker/esphome-4cello@gc9a01
    components: ["gc9a01"]
i2c:
  - id: bus_internal
    sda: GPIO11
    scl: GPIO12
  - id: bus_porta
    sda: 13
    scl: 15
#  interrupt: 14
image:
  - file: mdi:volume-low
    resize: 80x80
font:
  - file: "gfonts://Roboto"
rc522_i2c:
  address: 0x28
  on_tag:
    then:
#touchscreen:
#  - platform: lilygo_t5_47
#    interrupt_pin: GPIO14
#    i2c_id: bus_internal
#    id: my_touchscreen
#    on_touch:
#      - logger.log: "touched"
spi:
  mosi_pin: GPIO5
  clk_pin: GPIO6
display:
- platform: gc9a01
  reset_pin: GPIO8
  cs_pin: GPIO7
  dc_pin: GPIO4
  rotation: 90
  pages:
    - id: page1
      lambda: |-
        float screenheight = it.get_height();
        float screenwidth = it.get_width();
        float halfscreenheight = screenheight / 2;
        float halfscreenwidth = screenwidth /2;
        it.image(halfscreenwidth, halfscreenheight -55, volume_notmute_80, ImageAlign::TOP_CENTER);
        it.filled_circle(halfscreenwidth -12, 225, 3);
        it.circle(halfscreenwidth, 225, 3);
        it.circle(halfscreenwidth +12, 225, 3);
#  on_page_change:
#      - to: page1
#        then:
#          - sensor.rotary_encoder.set_value:
#              id: rotaryencoder
#              value: !lambda 'return id(workshop_volume).state * 100;'
#          - component.update: my_lcd
binary_sensor:
  - platform: gpio
    pin: GPIO42
  - platform: rotary_encoder
    max_value: 100
    min_value: 0
    pin_a:
      number: GPIO40
      mode:
       input: true
       pullup: true
    pin_b:
      number: GPIO41
      mode:
       input: true
       pullup: true
    accuracy_decimals: 1
    on_value:
      - lambda: |-
    on_clockwise:
      - display.page.show_next: my_lcd
    on_anticlockwise:
      - display.page.show_previous: my_lcd
light:
  - platform: monochromatic
    output: oledbacklight
    default_transition_length: 250ms
output:
  - id: oledbacklight
    platform: ledc
    pin: GPIO9
    #pin: GPIO21
    max_power: 1
    min_power: 0
Was fixed here
hallo what you full code ? can you pleas deel this ?
My code is not going to help much Jarne as it’s custom to my setup, very much still a work in progress and there is a lot of unnecessary code for customizing for yourself.
I am using the Smart Knob for controlling media player volume, ventilation fan sped and dust extractor speed for my workshop. I have not completed the dust extractor page as I still need to integrate to my PLC.
The pages are changed by buttons on a keypad a 4 x 3 keypad installed beside the smart knob. I have automations in Home Assistant to revert the page back to volume control after 10 seconds so the vent fan or dust extraction can be changed via the smart knob, but then it reverts back to volume control.
Not sure if other people have tried the external I2C connectors, but I could not get it to work at all. I need to look at the schematics to see if it has internal pull ups.
esphome:
  friendly_name: workshop-rotary-test
  on_boot:
    priority: 100
    then:
     - lambda: |-
          id(page1binary).publish_state(true);
          id(page2binary).publish_state(false);
          id(page3binary).publish_state(false);
        # Formatted:
     - logger.log:
         format: "Vent fan Speed is %.1f"
         args: [ 'id(vent_fan_speed).state' ]
api:
  encryption:
    key: API_KEY
ota:
  password: OTA_PASSWORD
globals:
  - id: screenwidth
    type: int
    restore_value: no
    type: int
    restore_value: no
    initial_value: '1'
    type: int
    restore_value: no
i2c:
  - id: bus_internal
    sda: GPIO11
    scl: GPIO12
  - id: bus_porta
    sda: GPIO13
    scl: GPIO15
#  interrupt: 14
esp32:
  framework:
    type: arduino
# Enable logging
logger:
  level: DEBUG
color:
  - id: my_red
    red: 100%
    green: 3%
    blue: 5%
  - id: my_green
    hex: 59981A
  - id: my_blue
    red: 3%
    green: 5%
    blue: 100%
  - id: my_yellow
    hex: FFFF00
  - id: my_light_blue
    hex: 145DA0
  - id: my_light_red
    hex: fc6d6d
  - id: my_light_orange
    hex: FD7F20
  - id: my_light_yellow
    hex: B58B00
image:
  - file: mdi:volume-variant-off
    resize: 40x40
    resize: 40x40
  - file: mdi:fan
    resize: 40x40
  - file: mdi:weather-tornado
    resize: 40x40
    resize: 80x80
  - file: mdi:fan
    resize: 80x80
  - file: mdi:knob
    resize: 80x80
    resize: 80x80
    resize: 80x80
font:
  - file: "fonts/arial.ttf"
wifi:
  ssid: WIFI_SSID
  password: WIFI_PASSWRD
captive_portal:
rc522_i2c:
  address: 0x28
  on_tag:
    then:
spi:
  mosi_pin: GPIO5
  clk_pin: GPIO6
display:
- platform: gc9a01
  reset_pin: GPIO8
  cs_pin: GPIO7
  dc_pin: GPIO4
  rotation: 90
  pages:
    - id: page1
      lambda: |-
        if (id(mediaplayermute).state == "on")
          it.image(halfscreenwidth, halfscreenwidth -55, volume_mute_80, ImageAlign::TOP_CENTER);
        else
          it.start_clipping(0, ((id(beam_volume).state * -1) * 300) + 155, 250, 250);
          it.filled_circle(halfscreenwidth, screenheight, 255, my_light_yellow);
          it.end_clipping();
        it.printf(halfscreenwidth, halfscreenheight + 35, id(roboto40), TextAlign::TOP_CENTER, "%.0f%%", id(beam_volume).state * 100);
    - id: page2
      lambda: |-
        it.image(halfscreenwidth, halfscreenheight - 55, fan_80, ImageAlign::TOP_CENTER);
        it.printf(halfscreenwidth, halfscreenheight + 35, id(roboto24), TextAlign::TOP_CENTER, "%.0f%%", id(vent_fan_speed).state);
        it.circle(halfscreenwidth -12, 225, 3);
        it.filled_circle(halfscreenwidth, 225, 3);
        id(page1binary).publish_state(false);
        id(page2binary).publish_state(true);
    - id: page3
      lambda: |-
        it.image(halfscreenwidth, halfscreenheight - 55, cyclone_icon_80, ImageAlign::TOP_CENTER);
        it.filled_circle(halfscreenwidth +12, 225, 3);
        id(page3binary).publish_state(true);
  on_page_change:
      - to: page1
        then:
              value: !lambda 'return id(beam_volume).state * 100;'
binary_sensor:
  - platform: gpio
    pin: GPIO42
    on_press:
        - if:
            condition:
              - display.is_displaying_page: page1
            then:
              if:
                condition:
                  lambda: return id(mediaplayermute).state == "off";
                then:
                  - logger.log:
                      format: "The mediaplayer sensor reports value %s"
                      args: [ 'id(mediaplayermute).state' ]
                  - homeassistant.service:
                     service: media_player.volume_mute
                      entity_id: media_player.workshop
                      is_volume_muted: 'true'
                else:
                  - logger.log:
                      is_volume_muted: 'false'
  - platform: homeassistant
    entity_id: binary_sensor.keypadkey_6
    on_state:
      then:
        - display.page.show: page2
    entity_id: binary_sensor.keypadkey_9
    on_state:
       then:
          - display.page.show: page3
    entity_id: binary_sensor.test_binary
    on_state:
       then:
          - delay: 10s
          - display.page.show: page1
    name: "Page 1 Active"
    name: "Page 2 Active"
    name: "Page 3 Active"
    max_value: 100
    min_value: 0
    pin_a:
      number: GPIO40
      mode:
       input: true
       pullup: true
    pin_b:
      number: GPIO41
      mode:
       input: true
       pullup: true
    on_clockwise:
       - rtttl.play: quick_e:d=4,o=5,b=100:16e6
    on_anticlockwise:
       - rtttl.play: quick_d:d=4,o=5,b=100:16d6
    attribute: volume_level
light:
output:
  - id: oledbacklight
    platform: ledc
    pin: GPIO9
    #pin: GPIO21
    max_power: 1
    min_power: 0
  - platform: ledc
    pin:
      number: GPIO3
# Enable ringtone music support
rtttl:
  output: buzzer_out
text_sensor:
    name: "Media Player Mute"
    attribute: is_volume_muted
    on_value:
      then:
    name: "Vent Fan Status"
    entity_id: switch.vent_fan
    on_value:
    name: "Vent Fan Speed"
    entity_id: input_number.vent_fan_speed
    on_value:
Great! your config helped me get going a lot. Thanks
Do you use an automation to actually change the volume? and if so why did you not map it directly to the media player volume?
Thanks heaps, i missed the new repo URL
Yeah I use an automation that selects the variable to be changed - Volume, Fan Speed, etc, depending what page is showing on the rotary encoder. But it’s still very much a work in progress. The example earlier from dgaust shows another working method.
Again, huge thanks to @dgaust for sharing his code and work on this.
I have touch semi working on this, but currently just getting gibberish from the i2c registers. I think that the touchscreen is at address 0x38 and the RTC at 0x51 based on experimentation and the ft3267 documentation and examples. Definitely need some additional work, but I’ve not had much opportunity over the holidays.
I can however change the page based on a touch, which is useful (although sometimes reads two touches).
You can try it by updating the external components reference to - the refresh just means you’ll always get the most latest version when you compile
    components: [ gc9a01, ft3267_touchscreen ]
    refresh: 0s
And then define the touchscreen as below.
ft3267_touchscreen:
  address: 0x38
  on_release:
    then:
For the rotary encoder, I then have it setup to do some stuff depending on what page it’s on. Setting the light brightness works, but it’s really dumb at the moment. It needs some checks for when brightness is at its min/max, but it works well enough.
    pin_a:
      number: GPIO40
      mode:
       input: true
       pullup: true
    pin_b:
      number: GPIO41
      mode:
       input: true
       pullup: true
    on_clockwise:
      - if:
          condition:
          then:
                service: light.turn_on
                  entity_id: light.great_room_dimmer_4
                  brightness: !lambda int brightness = id(dimmersensor_brightness).state + 15; return brightness;
      - if:
          condition:
            - display.is_displaying_page: page2
          then:
                service: climate.set_temperature
                  entity_id: climate.doris
                  temperature: !lambda return (id(climatedevice_setpoint).state + 1);
      - if:
          condition:
            - display.is_displaying_page: page3
          then:
                service: media_player.volume_up
                  entity_id: media_player.living_room
    on_anticlockwise:
      - if:
          condition:
          then:
                  brightness: !lambda int brightness = id(dimmersensor_brightness).state  - 15; return brightness;
      - if:
          condition:
          then:
                  temperature: !lambda return (id(climatedevice_setpoint).state - 1);
      - if:
          condition:
          then:
                service: media_player.volume_down
Great with the touchscreen - Thanks !
I get this however:
INFO Updating https://github.com/dgaust/esphome.git@gc9a01
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Failed config
ft3267_touchscreen: [source <unicode string>:57]
  Too many candidates found for 'i2c_id' type 'i2c::I2CBus' Some are 'bus_internal', 'bus_porta'.
  address: 0x38
  interrupt_pin:
    number: 14
    mode:
      input: True
      output: False
      open_drain: False
      pullup: False
      pulldown: False
    inverted: False
  on_release:
    then:
