looks like whole left part of chip is not used.
from pin 1 to pin 14 on your photo.
you have a very good soldering skills. pins are so small.
Has anyone using the M5 PoESP32 device managed to get OTA updating via Ethernet to work after the initial hardware upload?
@dweston Did you read this information? It worked for me:
See post #13 - link (solution = SOLVED part)
@klim123123 be carefull not all pins are ‘playing’ nice; had an issue with a pull-up on pin 25 but did go well on pin 12…
I tried flashing using “esphome flasher”, “esphome web” and “esptool.py”, all 3 methods indicated that flash was erased and the firmware was uploaded. However, the LEDs on the ethernet port do not light up. When using the esphome flasher, it indicated rtcwdt_rtc_reset.
What am I missing here? Was there specific parameters I should be using on esptool?
Cheers
Joe
