Anyone there?
for magic mirror alone normally when you want to install modules you have to be in magic mirror modules directory then git clone the modules you want.
I canāt install any module with the addon , and it seems no one can help
Can you access magic mirror folder from ssh to do git clone the modules?
Furthermore, I read from the read me of this post. The way to install or use the module is
"gitupdate": true,
"npmupdate": false,
"npminstall": false,
"modules": [
{ "name": "MMM-OnScreenMenu", "git": "https://github.com/shbatm/MMM-OnScreenMenu" }, <--- this is the MMM-OnScreenMenu module
{ "name": "DailyXKCD", "git": "https://github.com/Blastitt/DailyXKCD.git" } <-- this is DailyXKCD modules
So may be you donāt need ssh at all, Just put the modules you need and the link of the module.
Yes, i read the docs, try two different modules, but cant make it to work, i guess something Is missing
@lerroy_b Hey, been out of town. Will look at it this week. That was copy pasta and did not test sorry.
@fernandex00 can you show my my configuration? All you should need to do is updated the modules with the ones you want and add to the config the modules and its settings and restart the addon.
I added the Quote of the Day module without too much trouble. You donāt need to install any other dependencies (to my knowledge). Here is my Hass.io plugin configuration and \config\magicmirror\config\config.js files. You need to edit the config.js in order to place the module somewhere on the Magic Mirror front-end.
Hass.io plugin:
{ "gitupdate": true, "npmupdate": false, "npminstall": false, "modules": [ { "name": "MMM-quote-of-the-day", "git": "https://github.com/Sispheor/MMM-quote-of-the-day.git", "cmd": "" }, { "name": "MMM-pages", "git": "https://github.com/edward-shen/MMM-pages.git", "cmd": "" }, { "name": "MMM-iFrame", "git": "https://github.com/alberttwong/MMM-iFrame.git", "cmd": "" }, { "name": "MMM-homeassistant-sensors", "git": "https://github.com/leinich/MMM-homeassistant-sensors.git", "cmd": "cd $MIRROR_APP_PATH/modules/MMM-homeassistant-sensors && wget https://github.com/Templarian/MaterialDesign-Webfont/archive/master.zip && unzip master.zip" }, { "name": "MMM-HASS", "git": "https://github.com/sytone/MMM-HASS.git", "cmd": "" } ] }
config.js file:
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: [], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "imperial", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "MMM-quote-of-the-day", position: "top_left", config: { language: "en", updateInterval: "1d" } }, { module: "currentweather", position: "top_right", config: { location: "YOURCITYHERE", locationID: "CITYNUMBERHERE", //ID from http://www.openweathermap.org/help/city_list.txt appid: "b7f4d1141e7b5d0cc4f877bff213f823" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "YOURCITYHERE", locationID: "CITYNUMBERHERE", //ID from http://www.openweathermap.org/help/city_list.txt appid: "b7f4d1141e7b5d0cc4f877bff213f823" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://rss.nytimes.com/services/xml/rss/nyt/US.xml" }, { title: "Reddit", url: "https://www.reddit.com/r/worldnews.rss" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
hi, sorry for the delay,here is my config for example this 2 modules
"name": "MMM-GoogleFit",
"git": "https://github.com/amcolash/MMM-GoogleFit.git",
"cmd": ""
"name": "PushbulletNotes",
"git": "https://github.com/maliciousbanjo/PushBulletNotes.git",
"cmd": ""
and this in the config,js
module: 'MMM-GoogleFit',
position: 'position',
config: {
// If desired
module: "PushBulletNotes",
header: "Notifications",
disabled: false,
position: "bottom_left",
config: {
accessToken: "my token",
numberOfNotifications: 5,
displayNotificationIcon: true,
displayMessage: true,
displayCount: true,
fade: true,
maxMsgCharacters: 50,
maxHeaderCharacters: 32
now, i uninstall the addon, and try to install again, but i get this error
ERROR (SyncWorker_14) [hassio.docker.addon] Can't build 64f57845/aarch64-addon-magic_mirror:0.23.3: The command '/bin/sh -c git clone --depth 1 -b master https://github.com/MichMich/MagicMirror.git . && npm install --unsafe-perm' returned a non-zero code: 1
Iāve been having issues with modules that access the Hassio API not loading. MMM-homeassistant-sensors and MMM-HASS are the two that Iād like to use, but are not displaying properly. MMM-HASS worked briefly, but MMM-homeassistant-sensors has never worked.
My config.js file is largely untouched; it is set up as follows:
module: "MMM-HASS",
config: {
host: "hassio/homeassistant", // Special docker ha api proxy
port: "",
https: false,
devices: [
{ deviceLabel: "PiHole",
deviceReadings: [
{ sensor: "sensor.pihole_ads_blocked_today", icon: "wi wi-thermometer", suffix: " blocked ads"},
{ sensor: "sensor.pihole_dns_queries_today", icon: "wi wi-humidity", suffix: " queries"}
{ deviceLabel: "Weather",
deviceReadings: [
{ sensor: "sensor.owm_temperature", icon: "wi wi-thermometer", suffix: "Ā°", notification: "INDOOR_TEMPERATURE"},
{ sensor: "sensor.owm_humidity", icon: "wi wi-humidity", suffix: "%"}
{ deviceLabel: "Hassio",
deviceReadings: [
{ sensor: "sensor.processor_use", icon: "fa fa-tachometer-alt", suffix: "%"}
module: 'MMM-homeassistant-sensors',
position: 'top_right',
config: {
url: 'http://hassio/homeassistant/api/states', // Special docker ha api proxy
prettyName: false,
stripName: false,
values: [{
icons: [{
"default": "chip"
sensor: "switch.living_room_lamp",
icons: [{
"state_off": "lightbulb-outline",
"state_on": "lightbulb-on-outline"
My MM log gives me the following errors:
Request URL: http://hassio/homeassistant/api/states/sensor.pihole_ads_blocked_today
Request URL: http://hassio/homeassistant/api/states/sensor.pihole_dns_queries_today
Request URL: http://hassio/homeassistant/api/states/sensor.owm_temperature
Request URL: http://hassio/homeassistant/api/states/sensor.owm_humidity
Request URL: http://hassio/homeassistant/api/states/sensor.processor_use
The Hassio System Log gives me the following:
18-09-02 20:34:47 WARNING (MainThread) [hassio.api.proxy] Unknown HomeAssistant API access!
What am I missing?
Hi!
I am trying out your addon. Got everything to start without any error messages but when i open Magicmirror screen it does not show anything i only see a black screen.
I have not done anything with the config file. Do i need to do this before anything will show?
This is my config.
"gitupdate": true,
"npmupdate": false,
"modules": [
"git": "https://github.com/sytone/MMM-OnScreenMenu.git",
"cmd": ""
"git": "https://github.com/Blastitt/DailyXKCD.git",
"cmd": ""
"cmd": ""
"cmd": ""
"name": "MMM-HASS",
"cmd": ""
hi, i fresh install hassOS, and get the same error, it appears that the addon is not compatible with hassos, i get this error
ERROR (SyncWorker_13) [hassio.docker.addon] Can't build 64f57845/aarch64-addon-magic_mirror:0.23.3: The command '/bin/sh -c git clone --depth 1 -b master https://github.com/MichMich/MagicMirror.git . && npm install --unsafe-perm' returned a non-zero code: 1
It is working for me on HassOS v. 1.9 and hassio v. 0.77.2. Sorry, but Iām not sure why itās not working for you.
i tried several times trying to install, even a restore from a snapshot, not working
You need to allow local API access for the plugin. This should be automatic but there are changes to authentication in HA that I have not looked at.
Thanks for the lead. Iāll look into this.
sorry for the late response, i go back to hassio from hassos, managed to install magic mirror, add the same module quote of they day with your exact config file and in the addon, it wont appear, i think something is missing in my config
this is the config
"gitupdate": true,
"npmupdate": false,
"modules": [
"cmd": ""
"cmd": ""
"cmd": ""
"cmd": ""
"name": "MMM-HASS",
"cmd": ""
"cmd": ""
"name": "PushBulletNotes",
"git": "https://github.com/maliciousBanjo/PushBulletNotes.git",
"cmd": ""
"name": "internet-monitor",
"git": "https://github.com/ronny3050/internet-monitor.git",
"cmd": ""
"cmd": ""
this is config.js
/* Magic Mirror Config for HASS.IOSample
* Orginal by Michael Teeuw http://michaelteeuw.nl
* MIT Licensed.
* When running in HASS.IO the address and ipWhitelist need to be
* empty and any access mcontrols need to be on the host
* and not in the container.
var config = {
address: "", // Empty as running in a docker container.
port: 8080, // Update port in HASS.IO configuration and not here.
ipWhitelist: [], // Empty as in docker container, ACL from the host.
// The settings below are for a basic setup, please modifiy as needed.
language: "en",
timeFormat: 24,
units: "metric",
customCss: "css/custom.css",
modules: [
module: "alert",
position: "top_bar"
module: 'MMM-OnScreenMenu',
position: 'bottom_right',
config: {
touchMode: true,
enableKeyboard: true,
menuItems: {
notify1: { title: "Home",
icon: "eye",
notification: "PAGE_CHANGED",
payload: 0 },
notify2: { title: "Comics",
icon: "eye",
payload: 1 },
notify3: { title: "Home Assistant",
icon: "eye",
payload: 2 }
module: "MMM-pages",
config: {
modules: [
[ "calendar", "clock","weatherforecast","currentweather","newsfeed", "MMM-HASS", "MMM-homeassistant-sensors" ],
[ "DailyXKCD" ],
[ "MMM-iFrame" ],
[ "MMM-GoogleFit" ],
[ "PushBulletNotes" ]
excludes: ["alert", "updatenotification", "MMM-OnScreenMenu"],
module: 'internet-monitor',
position: 'top_center',
header: 'Internet Monitor',
config:{
type: '',
maxTime: 20000,
updateInterval: 0,
verbose: false,
displayStrength: true,
displaySpeed: true,
strengthIconSize: 80,
maxGaugeScale: 100,
module: 'MMM-iFrame',
position: 'fullscreen_below', // This can be any of the regions.
config: {
url: ["http://192.168.0.19:8123"],
updateInterval: 60 * 60 * 1000,// Refresh every 60 minutes
width: "100%",
height: "1000px"
module: "DailyXKCD",
position: 'top_left',
config: {
invertColors: true,
showTitle: true,
showAltText: false
module: "clock",
module: "calendar",
header: "Holidays",
config: {
calendars: [
symbol: "calendar-check-o ",
url: "http://www.calendarlabs.com/templates/ical/US-Holidays.ics"
symbol: "calendar-check-o",
url: ""
url: ""
module: "compliments",
position: "lower_third"
config: {
locationID: ""
config: {
locationID: """
config: {
// If desired
module: 'PushBulletNotes',
header: 'Notifications',
disabled: false,
position: 'bottom_left', // Or any valid MagicMirror position.
config: {
accessToken: 'mytoken',
displayCount: true,
fade: true,
position: "lower_third",
config: {
language: "es",
module: "newsfeed",
config: {
feeds: [
url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml",
title: "Los Tiempos",
url: "http://www.lostiempos.com/rss/ultimas"
title: "Arstechnica",
url: "http://feeds.arstechnica.com/arstechnica/index?format=xml"
module: "MMM-HASS",
config: {
host: "192.168.0.19", // Special docker ha api proxy
port: "8123",
apipassword: "pss",
https: false,
devices: [
{ deviceLabel: "Exterior",
deviceReadings: [
{ sensor: "sensor.dark_sky_temperature", icon: "wi wi-thermometer", suffix: "Ā°"},
{ sensor: "sensor.dark_sky_humidity", icon: "wi wi-humidity", suffix: "%"}
{ deviceLabel: "Interior",
deviceReadings: [
{ sensor: "sensor.temperature_158d0001a2c279", icon: "wi wi-thermometer", suffix: "Ā°", notification: "INDOOR_TEMPERATURE"},
{ sensor: "sensor.humidity_158d0001a2c279", icon: "wi wi-humidity", suffix: "%"}
{ deviceLabel: "Internet",
deviceReadings: [
{ sensor: "sensor.speedtest_ping", icon: "fa fa-tachometer-alt", suffix: ""}
config: {
url: 'http://192.168.0.19:8123/api/states?api_password=pass', // Special docker ha api proxy
prettyName: false,
stripName: false,
values: [{
icons: [{
"default": "chip"
sensor: "binary_sensor.motion_sensor_158d00014dc0e8",
icons: [{
"state_off": "run",
"state_on": "run-fast"
sensor: "switch.phone",
icons: [{
sensor: "switch.tablet",
icons: [{
icons: [{
"default": "weather-fog"
icons: [{
"default": "oil-temperature"
icons: [{
"default": "weather-windy"
I need some help. The addon is installed correctly and I can see it in a browser. But how can I display it on the same raspberry pi with hassio? When I plug in the monitor and switch to HDMI it doesnt show.
Im going bananasā¦ cant figure out what āSpecial docker ha api proxyā-URL to use
module: "MMM-HASS",
config: {
host: "what goes here?", // Special docker ha api proxy
port: "and here?",
https: false,
devices: [
deviceReadings: [
{ sensor: "sensor.medel_temp_ute", icon: "wi wi-thermometer", suffix: "Ā°"},
{ sensor: "sensor.weather_humidity", icon: "wi wi-humidity", suffix: "%"}
deviceReadings: [
{ sensor: "sensor.kitchen_temperature", icon: "wi wi-thermometer", suffix: "Ā°", notification: "INDOOR_TEMPERATURE"},
{ sensor: "sensor.kitchen_temperature", icon: "wi wi-humidity", suffix: "%"}
config: {
url: 'and also here?', // Special docker ha api proxy
prettyName: false,
stripName: false,
values: [{
icons: [{
"default": "chip"
sensor: "sensor.kitchen_motion_sensor",
icons: [{
"state_off": "run",
sensor: "light.bedroom",
icons: [{
sensor: "light.dining",
icons: [{
sensor: "light.guest_room",
icons: [{
sensor: "light.hallway",
icons: [{
sensor: "light.kitchen",
icons: [{
sensor: "light.living_room",
icons: [{
sensor: "light.sink",
icons: [{
I struggle a lot in the end managed to do it, in mmm-hass the host in my case Is the ip of the rbp 192.168.0.7 the port Is 8123 of home assistant and in the mmm-homeassistant-the URL Is the complete path http://192.168.0.7:8123 hope it helps
