I thought so too, both with exact same subject. First one received at 5:30 this morning and states “Hello, USPS expects to deliver your package on Wednesday, March 18, 2020 between 12:45pm and 4:45pm.”
The second one was received at 8:32 this morning and states “Hello, Your item is out for delivery on March 18, 2020 at 7:10 am in City, State Zip. USPS expects to deliver your package today between 12:45pm and 4:45pm.”
I’m on the latest beta version and all of my sensors show up as unavailable with this error in the logs
Error while setting up mail_and_packages platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 179, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/config/custom_components/mail_and_packages/sensor.py", line 60, in async_setup_entry
CONF_SCAN_INTERVAL: entry.data[CONF_SCAN_INTERVAL]
KeyError: 'scan_interval'
The previous update just made the Amazon sensor unavailable but now they all are.
I think i have some old sensors, which are making some entities of the integration have _2 in the sensor name. I think this is messing up the lovelace card. I don’t have anything in my configuration.yaml.
The gui will not let me delete any of old “sensor” entities (box is greyed out). Any ideas? I manually edited the lovelace card for now
go into the integration and configure the card. The new scan interval needs to be set. I’ve added those instructions to the beta releases text for others.
If they are left over from an older version you may have to remove them manually. These are not official instructions and may be the wrong way to accomplish this.
BACK UP HASS
Make a backup of your hass installation
remove the mail and packages integration
open .storage/core.entity_registery
search for the stuck entities and remove their entry
So with the changes to the UI I am having trouble getting the mail card to show up. I think it has something to do with moving the resources stuff that is in my raw config but I am not sure where/how it needs to be moved. Can anyone point me in the right direction.
The official announcement for 0.107 states that if you were storing your resources manually in a Lovelace YAML file they now need to be moved to the lovelace: section in configuration.yaml. If you were managing Lovelace through the front end (configure UI > Raw Configuration editor) they would be moved automatically to the Lovelace front end configurator (Configuration > Lovelace Dashboards > Resources). I you do not see the resources listed there for the mail and packages custom card please add them in the Configuration > Lovelace Dashboards > Resources configuration area.
@fuzzymistborn, The mail and packages custom card continues to function in .107 without any additional modification or added cards. I’m not sure which cards need support from the preloader card you mention.
Is there anyway to use the “All Mail” folder in gmail? The reason I ask is I have emails received into a few different folders and they don’t show up in my “Inbox”. All mail does show up in the “All Mail” folder. It is an option in the drop down list, but I don’t seem to get any sensors to show up like I would if I use a different folder.
Any help would be appropriated and I am loving how this project is moving along!
From the information you provided, I can only inform you that neither the custom component or custom card for mail and packages provide a picture glance card. You may have been using a custom picture glance card in your installation that is no longer functioning due to the recent HA update. As suggested on GitHub we recommend using the built in home assistant picture glance card to display the camera component (if you have added it) set to live.
If you are using other custom cards in your installation please reach out to the developer that provided them.
