Maybe my question wasn’t clear. I tried the automation above and I did not understand the “system_path”. Am I to substitute the system path in the automation with the “true system path” i.e. /config/www/mail_and_packages/? I have read the new docs and see that the example camera setup still points to mail_today.gif. Since the name was changed to random, I never see this file in my mail_and_packages directory. I must be missing a step.
Would you mind sharing your config? Since the update, I’m also struggling. I have the gif method configured and cannot for the life of me get the image back in the card.
I only have the lovelace card and the integration configured, no automation. Is it required, or is that only for the camera to refresh the image?
Thanks, that’s what I understood, but I wanted to be certain.
My card looks like this, but the image is blank. I found the gif is in the /config/www/mail_and_packages folder and it’s new for today. It’s still the random string of characters, but it’s the only gif in there, so it should display:
What you have should be sufficient for the GIF. If you were attempting the camera entity, you must create one like the previous posts describe. You are currently providing it a sensor, not a camera.
I did clear the cache, as well as attempt on other browsers. Still no luck.
Should I have the external image use checkbox ticked? If I don’t, could I use the mail_image_system_path sensor instead, or is the mail_image_url required?
To use the GIF in the card, yes. To use the GIF in certain notification services, yes. To use a Camera entity, no.
Using the GIF in the card requires a URL, sensor.mail_image_url is required for the gif_sensor. You use also have either (or both) Internal_URL or External_URL configured in the general section.
Using the camera requires you set up a local file camera which requires a local file path, sensor.mail_image_system_path is required for the camera entity
Please read through the new section for the USPS Informed Delivery for additional details.
Thanks @moralmunky, you are a gentleman and a scholar. I really appreciate your patience with me/us on this and your clear explanations. I’ll continue toying with it.
In the future, if there is a new release, I just need to follow the above procedure, and then click “install” in the lower right and my integration will be updated to the latest?
FWIW when I ran thru the UI to create the automation:
- alias: "Update USPS Mail Camera Path on Hass Restart"
- platform: state
entity_id: sensor.mail_updated
- platform: homeassistant
event: start
- service: local_file.update_file_path
data_template:
entity_id: camera.mail_usps
file_path: "{{ states('sensor.mail_image_system_path') }}"
For some reason the UI wouldn’t let me select camera.mail_usps and had no entries, however I set it anyways and image looks to be working fine now with the image.
EDIT: Yes I had created the local_file camera too.
This morning the mail and package card showed the pictures of the three items being delivered. I just checked now and it shows the NO Mail picture. I understood that this updated at 12 Midnight. It is 5:45PM EST. Not sure what caused this, but it was not me as I was out all day and did not look at Home Assistant until just now.
Any chance your instance restarted? The email was deleted or moved out of the folder you were watching? Does the USPS Mail sensor still show 3 mail pieces?
