The history feature of this card makes it incredibly useful, thanks for the work on this!
I live on a boat, and I have zones for where home (the boat) and the anchor location are. I’m updating the zones via various automations.
When I drop the anchor and let out chain, I set the radius of the anchor zone. Then I also set a larger radius for the anchor alarm (if the boat goes outside of the outer radius, HA shouts at me over all of my devices).
Having the visualization of the inner and outer circles is useful, as is the visualization of the boat location over time.
Is there a way to draw the inner and outer circles on your map card so that I can just have a single card on my dashboard?
Here is an example config I’m using (API keys redacted):
type: custom:map-card
focus_entity: zone.home
zoom: 6
card_size: 10
entities:
- entity: zone.home
display: icon
tile_layers:
- url: >-
https://maps.openweathermap.org/maps/2.0/weather/1h/PR0/{z}/{x}/{y}?appid=<I have replaced this with my actual API key>
options:
attribution: <a href="https://openweathermap.org/">OpenWeatherMap</a>
apikey: <I have replaced this with my actual API key>
It’s not displaying anything and I’ve tried a few different values. Does the attribution key need to be altered in some way?
To be sure we’re working toward the same goal…I’m trying to get Map 2.0 (not 1.0) working.
The 1.0 config seems to work with the {apikey} placeholder (as you mentioned) or explicitly replacing it with the actual api key (as I had it) since apikey: is specified on the third line.
For 2.0 (see link I posted above) I tried the same config as what you posted (that’s where I got it from initially) but replaced the 1.0 URL with the 2.0 URL. So, I’m asking if something else (e.g. attribution) also needs adjustment to get 2.0 to work. If so, what are those adjustments?
