@mdijkens @neojudgment: added a new issue for this: Reload entity state & lat/long from Hass websocket subscription · Issue #120 · nathan-gs/ha-map-card · GitHub
@mdijkens @neojudgment it should be fixed in v1.12.0.
Hi Nathan,
I did the update and everything seems to work!
If I see a problem I will send you a feedback
Thank you very much Nathan.
Pascal
I’m not sure if this is related or I’m doing something wrong, but the icon does update but moves out of the window.
This is my configuration:
ype: custom:map-card
history_start: 12 hours ago
card_size: 10
zoom: 16
maxZoom: 20
focus_entity: device_tracker.tesla_location
follow_focus: refocus
entities:
- entity: device_tracker.tesla_location
color: purple
history_show_dots: false
gradual_opacity: 1.4
display: icon
history_line_color: green
Also (first time user of the card): can I change the width of the card?
If I increase the size anything above card_size=5 it only increases the hight.
That config looks good, can you share a screenshot of when it moves outside of the map? The follow_focus: refocus
should prevent that.
Don’t have a screenshot right now, but what you basically would see is the map centered on the position where the car was when the page was refreshed (manually) for the last time, with the track going outside of the window to the actual position of the car.
I’m on the latest version of HomeAssistant 2025.1.3 using Map Card v1.12.0.
Cleared cache and tried on Safari, Firefox and Edge.
To be fully accurate this my full config currently:
type: custom:map-card
card_size: 6
zoom: 16
maxZoom: 20
entities:
color: purple
display: icon
history_line_color: purple
- entity: zone.work
display: icon
color: green
focus_on_fit: false
- entity: zone.home
display: icon
focus_on_fit: false
Your device_tracker.tesla_location
also needs the focus_on_fit: true
That doesn’t make a difference unfortunately. I read in the documentation that it is " true" by default anyway?
So I now have this configuration that is only updating the viewport when manually refreshing the browser (I removed the other entities to be sure they don’t interfere).
card_size: 6
zoom: 18
maxZoom: 20
entities:
focus_on_fit: true
color: purple
display: icon
As said, this does not work unfortunately.
But what is the difference between the working of:
and
follow_focus: contains
(none of these seem to have effect).
Very stupid error in the docs:
It needs to be:
focus_follow: refocus
not follow_focus
Will make an update to the docs…!
Just to comment on this question. I also find this.
I manually add the lines below to my card and it gives me a full view. (Using the sections layout method).
grid_options:
columns: 45
rows: 12
@santiniuk that might be a nice thing for the README, do you want to create a github PR for that?
If a “full view” is same as “show for a whole screen”:
then just define “columns: full” like here:
entities: ...
grid_options:
columns: full
rows: 8
but a value for “rows” depends on a particular viewport.
Another question is - WTH using sections instead of a Panel view?
So I am trying to get my mower to show on a GPS Map. Plugin installed ok and working well with default openmap.
Browse layers and find one I like - Leaflet Provider Demo
var Stadia_AlidadeSatellite = L.tileLayer('https://tiles.stadiamaps.com/tiles/alidade_satellite/{z}/{x}/{y}{r}.{ext}', {
minZoom: 0,
maxZoom: 20,
attribution: '© CNES, Distribution Airbus DS, © Airbus DS, © PlanetObserver (Contains Copernicus Data) | © <a href="https://www.stadiamaps.com/" target="_blank">Stadia Maps</a> © <a href="https://openmaptiles.org/" target="_blank">OpenMapTiles</a> © <a href="https://www.openstreetmap.org/copyright">OpenStreetMap</a> contributors',
ext: 'jpg'
I think I have set this up right
history_start: 24 hours ago
entities:
- device_tracker.luba_vs7a22mp_luba_vs7a22mp
tile_layer_options:
maxZoom: 20
grid_options:
columns: 48
rows: 16
tile_layer_url: https://tiles-eu.stadiamaps.com/tiles/alidade_satellite/{z}/{x}/{y}{r}.jpg
tile_layer_attribution: >-
(Contains Copernicus Data) | © <a href="https://stadiamaps.com/"
target="_blank">OpenStreetMap</a>
however I get an invalid authenticaion error
Any one got any ideas?
cheers!
A 401 and the message Invalid Authentication probably points to an issue with authentication. Probably you need to add a key (api_key as option) Authentication - Stadia Maps Documentation
Thanks have generated one - now to try and work out how to add it!
cheers
Stuart
PS If anyone has any ideas for a better satnav option I am all ears.
Something like this:
tile_layer_options:
api_key: KEY
tile_layer_url: https://tiles-eu.stadiamaps.com/tiles/alidade_satellite/{z}/{x}/{y}{r}.jpg?api_key={apikey}
Works great thanks! Although the satellite picture is slightly off, more things to learn on how to correct it.
I just want to take a moment to say thanks to @nathan.gs for developing this. The card is exactly what I was looking for.
The date selection is amazing. Obviously my recorder only goes back so far (which I’m thinking about increasing just for my device tracking entities) or if anyone knows how to have them logged into long term stats let me know!.
Living in France the default map isn’t too my liking, luckily the government has a great map portal that checks all my boxes (yaml below)
zoom: 13
focus_entity: device_tracker.niro_ev_19_location
tile_layer_url: >-
https://data.geopf.fr/wmts?REQUEST=GetTile&SERVICE=WMTS&VERSION=1.0.0&STYLE=normal&TILEMATRIXSET=PM&FORMAT=image/png&LAYER=GEOGRAPHICALGRIDSYSTEMS.PLANIGNV2&TILEMATRIX={z}&TILEROW={y}&TILECOL={x}'
entities:
- entity: device_tracker.niro_ev_19_location
color: "#16335c"
