Map values for an input_select?
Update on sensor.sensitivity:
attribute sensitivity has been added to the Hue CC https://raw.githubusercontent.com/robmarkcole/Hue-sensors-HASS/master/custom_components/sensor/hue.py
following our discussion on Hue motion sensors + remotes: custom component
and Github https://github.com/robmarkcole/Hue-sensors-HASS/pull/108
so now this template sensor is possible based on the binary_sensor created by the Hue CC:
  corridor_motion_sensor_sensitivity:
    friendly_name: 'Corridor sensitivity'
    value_template: >
      {{state_attr('binary_sensor.corridor_motion_sensor','sensitivity')}}
UPDATE
Added a HA interface to the selection of daylight threshold of the motion sensor in the Hue App, using the same rest command I use for the sensitivity. Which is possible because of the templatable format of the command which takes its variable from a script.
36
31
for completeness sake, here’s the (almost) full package:
# Package Hue Sensitivity and Threshold by @mariusthvdb
# see community discussion on https://community.home-assistant.io/t/map-values-for-an-input-select/94354/5
# and https://community.home-assistant.io/t/hue-motion-sensors-remotes-custom-component/27176/687?u=mariusthvdb
# big help by @pnbruckner @Martso @cicero222 and @petro.
# https://community.home-assistant.io/t/input-select-enhancement-support-maps-key-value-pairs/94391
# jan 25 2019
homeassistant:
  customize_glob:
    sensor.*_motion_sensor_sensitivity:
      templates:
        icon: >
          if (state === '0') return 'mdi:numeric-0-box-multiple-outline';
          if (state === '1') return 'mdi:numeric-1-box-multiple-outline';
          return 'mdi:numeric-2-box-multiple-outline';
        icon_color: >
          if (state === '0') return 'grey';
          if (state === '1') return 'blue';
          return 'red';
    sensor.*_motion_sensor_threshold:
      icon: mdi:altimeter
      templates:
        icon_color: >
          if (state > 25000 ) return 'rgb(85, 0, 0)';
          if (state > 20000) return 'rgb(255, 0, 0)';
          if (state > 15000) return 'rgb(255, 165, 0)';
          if (state > 10000) return 'rgb(0, 128, 0)';
          if (state > 7500) return 'rgb(255, 211, 30)';
          if (state > 5000) return 'rgb(255, 255, 0)';
          if (state > 25000) return 'rgb(30, 144, 255)';
          if (state > 1000) return 'rgb(30, 255, 255)';
          return 'rgb(47, 0, 0)';
  customize:
    script.set_hue_sensitivity:
      action_name: 'Set'
      icon: mdi:settings
    script.set_hue_threshold:
      action_name: 'Set'
      icon: mdi:settings
    input_select.select_hue_sensitivity:
      templates:
        icon: >
          if (state === 'Low') return 'mdi:numeric-0-box-multiple-outline';
          if (state === 'Medium') return 'mdi:numeric-1-box-multiple-outline';
        icon_color: >
          if (state === 'Low') return 'grey';
          if (state === 'Medium') return 'blue';
          return 'red';
    input_number.slide_hue_threshold:
      templates:
        icon_color: >
# Scripts and Commands
# https://community.home-assistant.io/t/hue-motion-sensors-remotes-custom-component/27176/698?u=mariusthvdb
rest_command:
  set_hue_command: #not named sensitivy because the command can be used to set other entities/attributes also
    url: !secret url_set_hue_command
    method: put
    payload: '{{ data }}'
script:
    alias: Set Hue sensitivity
      service: rest_command.set_hue_command
      data_template:
        command: config
        type: sensors
        data: >
          {% set mapper =
            { 'Low':'0',
              'Medium':'1',
              'High':'2' } %}
          {% set state = states('input_select.select_hue_sensitivity') %}
          {% set sensitivity = mapper[state] if state in mapper %}
          {"sensitivity": {{sensitivity}} }
          {% set mapper =
            { 'Laundry':'22',
              'Dining table':'52',
              'Auditorium':'44',
              'Frontdoor':'60',
              'Dorm':'56',
              'Corridor':'5',
              'Corridor terrace':'33',
              'Master bedroom':'48',
              'Corridor Office':'28',
              'Control room':'7',
              'Attic':'12' } %}
          {% set state = states('input_select.select_hue_motion_sensor') %}
          {% set id = mapper[state] if state in mapper %}
          {{id}}
  set_hue_threshold:
    alias: Set Hue threshold
      data_template:
        command: config
        type: sensors
        data: >
          {"tholddark": {{states('input_number.slide_hue_threshold')|int}} }
          {% set mapper =
            { 'Laundry':'25',
              'Dining table':'53',
              'Auditorium':'45',
              'Frontdoor':'61',
              'Dorm':'57',
              'Corridor':'6',
              'Corridor terrace':'34',
              'Master bedroom':'49',
              'Corridor Office':'29',
              'Control room':'9',
              'Attic':'13' } %}
          {{id}}
# Inputs
input_select:
    name: select Hue sensitivity
    options:
      - Low
      - Medium
      - High
  select_hue_motion_sensor:
    name: select Motion sensor
    icon: mdi:run-fast
    options:
      - Laundry
      - Dining table
      - Auditorium
      - Frontdoor
      - Dorm
      - Corridor
      - Corridor terrace
      - Master bedroom
      - Corridor Office
      - Control room
      - Attic
input_number:
    icon: mdi:altimeter
    name: Slide Hue threshold
    min: 0
    max: 30000 #hue max = 65534 but makes slider max ot of scale, since max is almost identical to 30000
    step: 2500
# Sensors
# Sensitivity sensors
#not used anymore, replaced by attributes sensitivity in CC HUE binary sensor
#  - platform: command_line
#    name: Laundry sensitivity
#    command: !secret get_laundry_config
#    value_template: >
#      {{ value_json.config.sensitivity }}
#    name: Auditorium sensitivity
#    command: !secret get_auditorium_config
#    value_template: >
    sensors:
      laundry_motion_sensor_sensitivity:
        friendly_name: 'Laundry sensitivity'
        value_template: >
          {{state_attr('binary_sensor.laundry_motion_sensor','sensitivity')}}
      dining_table_motion_sensor_sensitivity:
        friendly_name: 'Dining table sensitivity'
        value_template: >
          {{state_attr('binary_sensor.dining_table_motion_sensor','sensitivity')}}
      auditorium_motion_sensor_sensitivity:
        friendly_name: 'Auditorium sensitivity'
        value_template: >
          {{state_attr('binary_sensor.auditorium_motion_sensor','sensitivity')}}
      # etcetc
# Threshold sensors
    sensors:
      laundry_motion_sensor_threshold:
        friendly_name: 'Laundry threshold'
        value_template: >
          {{state_attr('binary_sensor.laundry_motion_sensor','threshold')}}
      dining_table_motion_sensor_threshold:
        friendly_name: 'Dining table threshold'
        value_template: >
          {{state_attr('binary_sensor.dining_table_motion_sensor','threshold')}}
      auditorium_motion_sensor_threshold:
        friendly_name: 'Auditorium threshold'
        value_template: >
          {{state_attr('binary_sensor.auditorium_motion_sensor','threshold')}}
      #etcetc
# Groups
group:
  set_hue_sensitivity_sensor:
    icon: mdi:run-fast
    control: hidden
    name: Set Hue sensitivity sensor
    entities:
      - input_select.select_hue_motion_sensor
      - input_select.select_hue_sensitivity
      - script.set_hue_sensitivity
  set_hue_threshold_sensor:
    icon: mdi:altimeter
    control: hidden
    name: Set Hue threshold sensor
    entities:
      - input_number.slide_hue_threshold
      - script.set_hue_threshold
  hue_sensitivity_sensors:
    name: Hue sensitivity sensors
    control: hidden
    icon: mdi:numeric
    entities:
      - sensor.laundry_motion_sensor_sensitivity
      - sensor.dining_table_motion_sensor_sensitivity
      - sensor.auditorium_motion_sensor_sensitivity
      - sensor.frontdoor_motion_sensor_sensitivity
      - sensor.dorm_motion_sensor_sensitivity
      - sensor.corridor_motion_sensor_sensitivity
      - sensor.corridor_terrace_motion_sensor_sensitivity
      - sensor.master_bedroom_motion_sensor_sensitivity
      - sensor.corridor_office_motion_sensor_sensitivity
      - sensor.control_room_motion_sensor_sensitivity
      - sensor.attic_motion_sensor_sensitivity
  hue_threshold_sensors:
    name: Hue threshold sensors
    control: hidden
    icon: mdi:numeric
    entities:
      - sensor.laundry_motion_sensor_threshold
      - sensor.dining_table_motion_sensor_threshold
      - sensor.auditorium_motion_sensor_threshold
      - sensor.frontdoor_motion_sensor_threshold
      - sensor.dorm_motion_sensor_threshold
      - sensor.corridor_motion_sensor_threshold
      - sensor.corridor_terrace_motion_sensor_threshold
      - sensor.master_bedroom_motion_sensor_threshold
      - sensor.corridor_office_motion_sensor_threshold
      - sensor.control_room_motion_sensor_threshold
      - sensor.attic_motion_sensor_threshold
# Notes
